Question about Dryers
I need a replacement glass globe - Dryers
    Top Expert:
  • Dryers Master
  • 45,291 Answers
Any home improvement store that sells ceiling fans sells globes too or check on Amazon.com
Posted on Apr 29, 2015
    Genius:
  • 1,617 Answers
If it came with the fan, I need the make/model of fan.
Posted on Apr 30, 2015
Westinghouse ETL-ES-TurboSwirl-MN-WH09 ceiling fan glass globe part#
There is a chance is says on another light bulb,a little tag with a number.
Mar 09, 2014 | Hunter 23852 Classic Original Ceiling Fan
We purchased a Hampton Bay Southwind V Celing Fan from Home Depot and the glass globe over the light bulb was cracked. Where can we get a replacement? We can't find the information that was in the box.
You can find a replacement at Walmart, Lowes, or Home Depot.
Go to any of the above websites and run a search by entering "light kit replacement glass", or just plain "globe". It should cost between $ 3.50 - $10
good luck
Mar 24, 2011 | Computers & Internet
I need a new globe for my Hunter fan 28505 I think...
You can locate parts at hunterfan.com or call for parts at (901) 248-3237 This is the
technical service number given to me by the hunter rep a few years ago.
If you need a generic globe, they are available at home depot and lowes in the
replacement glass section "Angelo Glass"
All you need to do is measure the diameter of the
"fitter". This is the metal part the glass fits into and holds it, usually with 3 thumbscrews.
Mar 03, 2011 | Hunter Heating & Cooling
My glass globe/shade is damaged. I need to buy a a replacement. As far as I can tell the ss# is 0499 and the model looks like WL 62. I am reading upside down in a tight spot. The globe fits in housing 9...
You can probably find a replacement at Home Depot or Lowe's in the lamp department. They sell these globes as universal replacements rather than being specific to a particular model of fan. The 3 set screw holding method is pretty universal for ceiling fixtures and fans of all brands. If the current shade is not shattered, put a little tape on it and take it with you to the store. good luck, Al K
Dec 07, 2010 | Encon Industries (78018) Ceiling Fan
Flame does not flicke in my electric fireplace
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Nov 28, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
The glass light cover falls off when the fan is on. I have made certain that the cover was screwed in properly but the vibration of the fan loosens the cover. Any suggestions?
I would first tighten any screws that might be part of the vibration problem. They do work loose. As far as the globe goes, sounds like you might need some kind of spacer material between the glass globe and the frame it screws into. Perhaps a few pieces of small clear plastic hose. Try and wedge them between the globe and metal frame when screwing the globe back on. Make sure it is snug, but do not over tighten to the point where the globe breaks.
Aug 27, 2010 | Casablanca Fan Stealth 3211T Ceiling
I am looking for a replacement glass globe for my laurel woods westinghouse ceiling fan. Can you tell me where I MIGHT FIND ONE
Lowes and Home Depot each have many glass replacement globes that will fit most any ceiling fan light assembly.
You will need to know the diameter of the glass where it goes into the metal part of the light and the depth that the globe needs to be to clear the lgiht bulb.
Heatman101
Feb 26, 2010 | Dryers
I cannot remove light cover on ceiling fan to replace globe
There are usually small screws around the outside of the globe that screw into a recess on the globe with a rubber ring around it to keep the screws from hitting the glass.
Dec 31, 2009 | Sewing Machines
Bulb replacement 0 how do you get the glass cover off?
Les:
The globe is held on by three metal tension clips holding the globe to the base. To remove the globe, you need to pull down on the globe gently but firmly. Try pulling down on one side and then the other, sort of "wiggling" the globe off. Getting the globe back on can be a bit of a challenge, calling for you to get all three clips aligned in place before pushing the globe back up. A little patience and the job will go smoothly.
Hope this helps. If it does, please leave feedback! That is the only way I know if I am being of assistance or just wasting my time.
Oct 10, 2009 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Remove light globe from simpson harmony nova oven
The glass cover is a screw in. You will need to remove this by turning anti-clockwise to get to the globe.
Jun 01, 2008 | Ovens
Dryers Logo
102 people viewed this question
Top Dryers Experts
