Power on problems
My television has started requiring me to press the power button twice to turn it on. After the first press I hear clicking and noises from the set but it does not turn on and the red indicator light blinks. After waiting for the noises to stop I press the power swith again and the set turns on. This occurs whether I use the remote or power switch on the television.
A few months ago I had a similar problem where the set would not turn on at all. Service was called (1 week before my 2 year warranty expired) and they replaced many boards and finally determined that the "D" board needed replacement. It worked fine for many months after this repair.
  • 1 more comment
  • hypersynergy Nov 20, 2007
    Hey I have the same problem. It started a while back after a 'brown out' on my utility service, I read about 40VAC at my service. The TV started out with faint horizontal bars that got worse in time. Next it started to go off intermittently especially when cold, often requiring several starts to stay on.. Today it decided to not start at all simply kicks back out.
    I had been told that the power supply on these TV's were not replaceable not easily serviceable, it this correct? I am an alarms, controls and instrument technician and have some basic knowledge here. If I can ID a bad component is it likely to be something I can get from say Jameco or Hutchfield, ie: not proprietary? I'm gonna pack the tools home tomorrow to check it out, any tips?
    TV= 27" Samsung TXL279F
    Oh I forgot to mention that I found a 2-3.5kHz signal being introduce onto my service whenever the TV is plugged in, ie it does not have to be on. It does however run higher with the TV on than off.
  • goochiam Aug 24, 2008
    I bought my television set about 4 yrs ago . And just within the last yr. i have noticed that we had to press the power button several times before it would turn on . It got so bad that we had to start unplugging the set and plugging it back in and press the power button at the same time so it'll start. We also heard crackle noises coming from the set . I think that part of the reason it has been doing this is because the family watches the set and turns off the cable and not the t.v. it looks like the t.v. is off but the power is still on. Now our t.v. does not turn on at all . I think it can be fix. Can anyone help me out?
  • 87 Answers
Having to press the power button multiple times before the set comes on is usually caused by low standby voltages in the power supply or bad connections on the printed circuit board. The "D" board is not your problem. Most likely there is bad capacitor in the 9 volt standby supply.
Posted on Nov 15, 2007
Turn off headset, press and hold power button till light flashes blue and red continously.
Release power button and press it twice. You will hear a Chinese voice prompt.
Press twice again to hear English voice prompt.
Press and hold till it turns off.
Turn it back on and connect to phone.
Oct 12, 2016 | Jabra Solemate Mini Portable Bluetooth...
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
TV Rarely Starts
Check all the solder terminal at its main power regulator section circuit. Any loose solder terminal can poise this type of problem. Resolder all the suspected solder terminals by applying a little more solder. If you wish to get more details, check this site.
Apr 22, 2013 | Hitachi 32UX01S TV
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Yamaha Amp DSP A-3090 Power/function/Remote
These issues can only be fixed by an audio-tech.
Do a websearch around your area for a repair person
Sep 30, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
I have a phillips universal CL034 remote control and i dont know the code or how to program it to my television
without knowing the brand of the tv i have to give you generic instructions on how to program the remote without knowing the codes:
  1. Turn your tv on manually
  2. on the remote press TV once
  3. Press and hold the set button until the LED red light blinks twice, then release the set button
  4. enter 9-9-1. the led will blink twice
  5. aim the remote at the tv and slowly alternate between pressing POWER and TV. Stop when the TV turns off after pressing power.
  6. lock in the code by pressing and releasing the set button. the led will blink twice.
Jul 02, 2008 | Televison & Video
Comcast Remote Control Code
comcast sucks and its tech support are a bunch of idiots. the book that comes with the remote is wrong (and for some reason no one in tech support knows this). the remote requires 5 digit codes and all the codes in the book are 4. typing the number 1 in front of any of the codes in the book, for any device and manufacturer, should fix this problem.
Jan 28, 2008 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
