Question about Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L
Brand new saw and it all of a sudden started making a ticking noise as the motor comes to a rest, why? How can I fix it or what could it be?
    Top Expert:
  • Bosch Master
  • 42,944 Answers
You fix!! you void any and all warranty you might have could be a piece of wood went where it don't belong look the blade area over good each tooth is ticking as it passes
Posted on Apr 29, 2015
    Top Expert:
  • Bosch Master
  • 10,875 Answers
The brake is trying to work or there is dust or something in motor
I have a bad ticking sound in the top end of my motor on my 1987 yamaha moto 4 250 how do i fix that
Hi, Austin I would love to help you with your engine noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have nice a day.
help bad ticking noise
2000 Warrior engine noise top end
How to remove the cylinder head off 4 stroke atv motorc
http://www.manualslib.com/manual/826392/Yamaha-Yfm250xl-C.html
Jul 08, 2016 | Yamaha Motorcycles
Tapping noise in engine
What's That Ticking Sound Coming From Your Car's Engine?
www.popularmechanics.com/.../whats-that-ticking-sound-coming-from-...
Apr 18, 2014 - My engine has developed a strange ticking sound. Its whisper-quiet before an oil change, and then makes a loud tapping after a new filter and ...
Engine Tapping - Auto Repair Help
www.auto-repair-help.com/auto_diagnostics/engine_tapping.php
ENGINE MAKES TAPPING NOISE WHEN STARTED by Mark Davidson. SYMPTOM SUMMARY The engine emits a tapping noise on start up. The noise may ...
Engine Ticking Clunking Noise - Repair - YouTube
? 9:37
https://www.youtube.com/watch?v=ilDtnJi_BS0
Mar 15, 2013 - Uploaded by knurlgnar24
One of my vehicles started making a rather disturbing sound so I went to investigate and to hopefully fix it.
Dec 02, 2015 | Cars & Trucks
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
Magic chef 10 cu fridge makes ticking noise but works fine
Some times refrigerators make a noise that sounds like a tick. It could be caused from the refrigerant flowing through the lines. This usually happens when the refrigerator first starts up and goes away after a few minutes. the other possibility is a fan motor blade taping the shroud from time to time. The refrigerant issue is not something that can be fixed. The fan blade issue could be fixed by moving the fan blade back or froward on the shaft a slight amount. If you have a 10 cu ft refrigerator it may not have a fan.
Apr 05, 2014 | Magic Chef Refrigerators
Makita Saw Bss610 stopped
It might be that the brushes have got stuck in the brush holders. Take them out and make sure they run free.
Jun 17, 2012 | Makita Saws
The dryer makes a new noise now when the drum is turning. It is a steady "tick -- tick -- tick -- tick --etc" which is laid over the normal sounds of the motor, the turning drum, and the...
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Dec 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My jeep is making a very loud tic noise coming from the motor...does this mean my motor is gone? How much am I looking at fixing this problem
ticking can be a few problems that are not terminal first check oil if low top off and see if noise quiets down if oil good than have oil pressure checked -may be clogging or bad oil pump-check check where the ticking is coming from if its the head area than possible need to clean repair or replace a valve train part-[clogged push rod ,bad/need adjustment rocker sticking /bent valve oil return clogging /sludge] if coming from front of engine check the pulleys and water pump or fan for damage or debris a ticking noise usually is a noise that can be repaired just need to pinpoint the location
Jul 10, 2010 | 1999 Jeep Grand Cherokee
Motor doesn't start makes ticking noise
It is most likely the starter,make sure the battery is up to par,and if so,the starter needs to be replaced.
Jun 06, 2010 | 1993 Nissan NX
2000 olds intrigue ticking noise in engine
need to check and make sure that there is enough oil in the car. make sure that the right grade of oil is in it. sounds like your hearing your lifters. does that sound go faster or get louder when you rev up motor a little?
Jun 27, 2009 | 2000 Oldsmobile Intrigue
My 97 excel has a rather loud ticking noise coming from the engine does anyone know what it is and how to fix it?
Check the oil! A ticking noise is most commonly a sign that there's a lack of oil running through the motor. Start the car and listen for general vicinity of the ticking noise. If the oil is fine and the noise is coming from the engine, there are oil additives that will quiet the noise. Ticking is also a sign of an old motor (guessing you have about 150K on this car) I hope this helps clarify your problem and wish you well with your car. All the best!
Greg
p.s. Please don't hesitate to post back regarding this issue or any other questions!
May 12, 2009 | 1992 Hyundai Excel
Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L Logo
288 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
