Question about Top Vacuums
I need the top ring that holds the water bottle upright. Any suggestions?
    Top Expert:
  • Top Master
  • 44,428 Answers
A long bungee cord might help since we do not know make or model hard to search for stuff online
Posted on Apr 29, 2015
The cap will not come off of the tank
The black thing that looks like a sports bottle top has a screen at one end to filter the solution. It gets tightly wedged into the solution bottle - pry it out (carefully). You could try a knife to (very carefully) pry it loose from the solution tank. Just don't cut yourself or deform the tank top.
Nov 28, 2011 | Bissell 1770 Quicksteamer II Upright...
WATER WILL NOT COME OUT
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
Nov 22, 2010 | Bissell 7901-R Clearview Proheat Plus...
My bissel proheat is not releasing the soap when the trigger is pulled
Try these suggestions to get your machine working properly:
Aug 13, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have Bissell 7920. The water is not being
Jul 14, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Does not spray the water and cleaning solution
If these suggestions do not solve the problem, have a technician at a local BISSELL Authorized Service Center inspect your machine.
To locate your nearest BISSELL Authorized Service Center, go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Jun 17, 2010 | Bissell 1699 ProHeat Clear View Upright...
Sprayer not working
If these suggestions do not solve the problem, contact a technician at a local BISSELL Authorized Service Center inspect your machine.
To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
Jun 15, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Top water bottle want stay in
The black base that the bottle sits in is broke. You can use hot glue to replace the bottle. I would suggest buying a new tank from hoover because the style of tank you have has a known design flaw. They have redesigned the tank to be stronger. You could trying calling the Hoover company and complaining. I know that has worked in the past.
Apr 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Water Leakage
Check the water bottle. Ours has been doing the same but putting a bit of j cloth between what they call the o ring and the cap fixed it. Really you need a new bottle assembly
Jun 13, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Smartmix bottle
The cap and insert at the bottom of the bottle may need to be replaced, or you could have a problem with the smart mix asm. You would have to remove the top cover to get to it. Does the smart mix knob stop where it is supposed to or does it go all of the way around, if it does, then the stop on the knob is broken.
May 25, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
Top Top Vacuums Experts
Vernon Taylor
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Top Vacuum Expert? Answer questions, earn points and help others
