Question about Cuisinart DGB-550BK Grind and Brew 12-Cup Automatic Coffeemaker
There are always fresh grounds in the basket tray or on top of carafe
Slow dripping and ground cup is extremely hot
Have you tried cleaning your coffee maker? If not just fill half of the carafe with white vinegar and let it brew. Keep basket in during cleaning but no filter needed. After running the vinegar through the brew cycle, fill the carafe with plain water and run fresh water through about 3 to 4 times. I do this every 4 to 6 months. I have a light on my coffee maker that lets me know when I need to clean it. I hope this helps.
Feb 27, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
Cleaning the coffee maker
Cleaning a coffee maker is simple.
Fill the carafe with 9-10 cups of Water and 1 cup drain cleaner.
Put a paper filter in the basket. Run the cycle. You will see lots of garbage in the carafe. Repeat with the same water.
Next dump the water into the sink and refill the carafe with fresh water.
Run again, several times to flush out the acid. remove the basket and scrub it clean. Your coffee maker should run like new.
Jan 30, 2014 | Rival Programmable 12-Cup Coffee Maker
The cuisinart repeated;y clogs and sprays water
The two most common reasons for overflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
Lately whether I put in pre-ground beans or whole beans, 1/2 the pot while dripping, leaks all over the counter, Help!
If water is leaking from the very bottom of the machine, your unit is broke and you need to call Cuisinart. If it is just overflowing the caraffe/basket:
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I clean it everynight but it still leaks coffee grins and coffee all over the place...this is the second coffee maker of its kind that i have had and they both have done the same thing. This only happens...
Jul 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Don't understand how it works
This coffee maker has a hot water reservoir that heats and stores hot water so it can brew coffee faster. Once you fill the reservoir by pouring a potful of cold water into the top, you can turn on the switch at the side of the unit and in about 10 minutes the water in the reservoir will be hot. I usually leave this switch turned on to keep the water in the reservoir hot. The front switch turns on the pot warmer at the front of the unit, so it should be turned off unless you are making coffee or keeping a pot warm. To make a fresh pot, put a filter and ground coffee in the removable filter basket, slide the basket into the unit, place an empty carafe on the warming burner and using a separate container pour fresh water into the filler at the top of the unit. The fresh water displaces the hot water in the reservoir and voila, the coffee carafe starts to fill. The amount of fresh water you added is the amount of coffee you will end up with, less a little bit that might have evaporated if you only make coffee every morning or less often. Most units have a plunger under the filler lid that keeps the fresh water from going in to the hot water reservoir until you close the lid, so close it after pouring in the water. Also, turn off the front switch if the carafe is getting low or empty, as it can get hot enough to crack the carafe. If you're not going to be using the coffee maker for several days, turn off the side switch or unplug the unit to save energy and reduce evaporation from the reservoir. I love mine. It makes great coffee and is much quicker than the drip type.
Apr 14, 2009 | Bunn NHB Coffee Maker
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
Mar 29, 2009 | Coffee Makers & Espresso Machines
Coffee grounds leaking out of the basket
When you are grinding your own beans or use certain types of coffee, you need to use a flow restrictor sprayhead. If you will contact customer service, a flow restrictor sprayhead can be sent out to you at no charge and this will eliminate the problem you are having.
Mar 03, 2009 | Bunn Thermal Carafe Coffee Brewer
Cuisinart DGB-550BK Grind and Brew 12-Cup Automatic Coffeemaker Logo
151 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
