Question about Craftsman Garden
Fuel line routing on craftsman blower vac serial number 9528n06419
  • 1,057 Answers
The small line goes to the fuel filter and the larger one is the vent to the fuel tank. The primer should have a large and small outlet and then you can put the small to small and the large to the large outlet. The fuel line from the tank goes to the carb. Hope this helps.
Posted on Oct 24, 2016
  • 302 Answers
SOURCE: Craftsman 2 cycle blower stalls.
Most Probably the problem lies in the adjustment of the carburettor. There are two needles in the carb one for lowend adjustment and one for high end adjustment. Your lowend adjustment seems fine. The highend needle needs to be adjusted. Following are some very detailed procedures for adjusting these types of carbs
If your machine has a carb other than a "Walbro" dont worry the procedures are same. I am sure if your engine has not completed its life span this will solve your problem.
Posted on May 19, 2010
  • 885 Answers
SOURCE: I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Posted on Nov 02, 2010
  • 718 Answers
SOURCE: When I prime the blower
You put something together wrong. Try again
Posted on Nov 13, 2010
  • 1545 Answers
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so
Posted on Feb 19, 2011
  • 7482 Answers
SOURCE: Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Posted on Oct 13, 2012
Where can I find a Diagram for a craftsman blower/vac carbuerator
Go to and enter the model number and it will give you a diagram for the carb. Hope this helps.
Aug 13, 2014 | Craftsman 4 Cycle Blower/Vac
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Hi jfkunz
Please rate me
Oct 12, 2012 | Craftsman Garden
Both lines from carb. are cracked..358.797550 craftsman blower/vac how hard is it to replace the 2 lines and I know one is for fuel, what is the other line for and where does it connect to from the carb. ...
Thin line is the fuel intake and is attached to the fuel filter. The other is the return, and should be placed on the tube below the primer bulb of the carburetor.
Sep 13, 2011 | Craftsman 4 Cycle Blower/Vac
I have a craftsman h horse chipper/vac and i cant
Focus on the carburetor main jet.
On a float bowl carburetor, remove the bolt holding the bowl to the carb body. This is the main jet, clean the jet with spray carb cleaner, and also spray upwards into the center of the carb.
I have listed some basics to double check, not all may apply to your application. If you need more detail let me know. rwvanlue
Fuel Related issues that take a certain amount of time to appear
Depending on make and model of mowers:
a) Fuel tank outlet plugged (some have a screen filter,
some are 90' angle and plug with rust and debris inside the corner of fitting)
b) Fuel lines collapse when they are routed thru fasteners and between frame and seat decks
c) Fuel cap vent clogged
d) Fuel filter clogged
e) any fitting that has an orifice that can trap debris or rust will eventually become clogged
f) fitting on the side of the carburetor
g) some systems have a filter inside the line at the opening of the carb inlet
h) fuel pump
i) vacuum hoses to fuel pump
j) debris under inlet needle/seat on carb
Nov 13, 2009 | Craftsman 4 Cycle Blower/Vac
Replaced carb I bought from Sears and still no gas to the plug.
Replace your fuel lines and fule filter (usually inside the tank). I have found a number of times that just heat and time will couse some problems with the inside of the fuel lines. Hope it helps!
Jun 24, 2009 | Craftsman 4 Cycle Blower/Vac
I need fuel lines for craftsman 358.797290 leaf blower
Whenever I cant find the exact stuff I need, try a local motorcycle shop. The fuel lines and such are very similar, often times you will end up with a higher quality fuel line for a few pennies more. Hope it helps!
Jun 22, 2009 | Craftsman 4 Cycle Blower/Vac
Model 358 craftsman blower, where is the fuel filter
Follow the fuel line from the tank to the carb. If it has one, its in that tubing line. There will prolly be a particle filter screen inside the tank to keep crud from getting to the carb. Other than that - there's really not much to the fuel system on these.
Garden Logo
194 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
