Question about Zanussi Washing Machines
Have zanussi washer, finished cycle, door opened. Tried to start another cycle, door opens and shuts readily but flashes door locked symbol and fails to let me set a programme
    Genius:
  • Zanussi Master
  • 1,585 Answers
The door locks faulty
Posted on Apr 30, 2015
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Maytag Neptune door will not open. Tried stop/pause for 2-minutes. Tried unplugging -basically tried all recommendations in the manual
Maytag's Neptune washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
1) Remove the bezel from the soap/bleach/fabric softener dispenser.
2) Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
* Some of the lock cords are now green or Orange
the lock has failed need to be repaired unless you can replace the lock assembly of what has failed.
Dec 25, 2010 | Washing Machines
Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Jul 19, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer won't start, stopped at beginning of cycle and the door lock flashed. after about 5-6 flashes the display read: FL. Tryed to start again, unplugged it for a while several times. nothing happens....
FL:
Failed to lock.
Trigger:
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
Action to be taken:
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
If you need to open the door.
neptopbezel.jpg 2) Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
Best of luck, Any questions just ask
Nov 26, 2009 | Maytag Washing Machines
Flashing lock symbol on front panel. machine wont operate
door latch switch or circuit is faulty. You will most likley have to pry door open and replace the switch. You can get parts and manual at repairclinic.com
Sep 16, 2009 | Zanussi FC1200W Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Oct 23, 2006 | Zanussi FLE1416W Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
