Question about Schwinn Original Airdyne
Changed battery, need to restore time and distance to alter
  • Schwinn Master
  • 918 Answers
To properly reset your mini computer to the specific mode you need please see Pg 8 - Pg 14 of this Airdyne manual from SportSmith I will be attaching a link of. Hope this helps.
http://www.sportsmith.net/images/product_support/schwinn/owners_manuals/AD4_Airdyne%20Evolution%20Comp%20Owners%20Manual.pdf
Posted on Jun 03, 2015
A windows update seems to have altered all my Function keys F1 through F12. I use these a lot as shortcut keys and want to restore them to how they were before - please, how do I do this (Windows 8)
TRy using the restore point that windows set just before the update. search for 'restore point', select the date/time you want and restore it to that time.
Dec 20, 2016 | Computers & Internet
Do i need to disconnect charger for a factory restore?
If you plan to restore or alter the OS in any way. ALWAYS have the charger powering the machine. If the power fails due to an exhausted battery, the system will be destroyed.
Jul 28, 2014 | HP Mini Computers & Internet
"sort by" ie distance or price on ebay is not working
On the right hand side of Ebay page you will see a sort by with a drop down list you might have to change it 2 times to get it to respond in the way you want it set soonest cheapest.
Above the drop down list in top right corner will be an Advanced tab where you can alter settings ending within hour ,postage nearest , items with in range .......
Hope this helps
Nov 17, 2012 | eBay Auctions
Hello, to protect my self from hackers I tried to look in the Internet for the best ways to protect my PC from hackers and I did see this way start - run - command.com - host ping - ping port - ping port...
You should have multiple restore dates if you have allowed the system to watch over changes. If so, you may have to go back in time more than just a couple of days to get things back in order. Also, before (!) making any system changes, you should at least create a new restore point or at best, back up your drive completely. Tampering with the OS shouldn't be done lightly.
Jun 15, 2011 | Yahoo Mail
Hello, Is it possible to reset the BIOS without removing the battery? The battery is on the other side of the motherboard.
If you have attempted to change something in your BIOS so you cannot alter or change any settings because the computer won't boot up properly, unless you have a CMOS reset button on your motherboard the only other way if you can't get into BIOS is to remove the CMOS battery, the CMOS battery is never on the otherside of the motherboard because all the connectors are always on one side of a motherboard
the CMOS battery is a silver flat battery, much like a thing watch battery, remove this battery for 15 seconds so there is no residual power left in the motherboard and then reinsert and reboot your computer
if you can get into BIOS there should be a restore to factory defaults settings in there somewhere.
Mar 20, 2011 | Jetway Mini-TOP HBJC600C99-52W-BW Intel...
I believe a belt fell off my car, making the steering extremely difficult, and also causing my red generator light to blink on and off. Can I still drive the car short distances without hurting the...
M mostly an expert on passat v6 engines but the it was the timing belt you wouldn't be going an inch over. M not sure if it use the same belt as timing belt but base on what you are describing yes the belt or fluid ( power steering) seem to be fault. No I would not drive it because of serious safety reason and also damage to steering parts and pump. if that belt broken off or damage that mean you timing could be on it's way. When that happen say good buy to the motor. The altering isn't charging the battery there for would show bad alternator sign. If the same belt turn the fan( if u have one) pump, ac, could signal those errors.
Dec 29, 2010 | 2000 Volkswagen Beetle
Replace motherboard battery..... what after i mean the BIOS settings
when the CMOS battery is replaced the default Bios settings are retained, if u made any custom changes to Bios then u will need to do them again, things like boot menu processor speed settings ect. are you clear on this, 99% of time it changes nothing since most users don't even know what Bios is or how to alter it.
Apr 30, 2010 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
I have changed my battery on my Echo F2 bike computer and the only thing operating is the clock? It is not measuring cadence k's etc? Do I need to do something other than change the battery?
try resetting by holding the mode button and reset button at the same time,if that don't work check the cable to sensor's,also the distance of sensor to magnet,try another battery? also check you have it in the right way up!
Nov 12, 2009 | Cyclone Cycling
Microsoft Intellimouse Explorer 2.0 Battery Problem
You say that this has been happening with a wired mouse as well?
In that case, you probably have a kind of virus/malware. Try this first:
http://housecall65.trendmicro.com/
Do a full system scan. You may have to temporarily disable/uninstall your current anti-virus if you have one already..
If not, try a system restore.
Jun 09, 2008 | Microsoft Wireless IntelliMouse Explorer
Schwinn Original  Airdyne Logo
258 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
michael
michael
Jim Goldsmith
Jim Goldsmith
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
