Question about Ingenico iCT220 Payment Terminal
What does Warning key pressed [80000000] mean
What does warning key pressed [80000000] mean
You have a Trojan on your computer (a virus that collects personal information and / or other activities you do).
you need to remove it... follow this and get the tool and download it. Then run the program and follow the instructions.
http://community.norton.com/en/forums/trojangen2-80000000-pop-ups
Apr 29, 2015 | Computers & Internet
Tip
PC faster Trick
how do the pc faster withe the notepad?
1)open notepad and clear everything
2)type these "mystring=(80000000)"
3)save it to desktop :"ram.vbe"
4)go to desktop and double click it and there you go, you will notice your computer is alot faster and internet brows does take as long to load
on Sep 10, 2010 | Computers & Internet
I could not open internet explorer when i click on it it's open box firewall warning and security warning then it show to activate now a security protection and they ask me about registration e mail...
You got infected with a virus that is trying to trick you in paying for it - it has blocked IE so that you can't search for help using the pc.
There is only one thing left to do - reinstall Windows. At the Dell screen press and hold ctrl, right after the Dell screen goes away hit F11. Select restore from there and follow the process.
Jul 14, 2011 | Dell Inspiron Mini 10 Notebook
Can i get a code to unlock my sony ericsson c905
Yes You can get the Code to unlock the Mobile Phone,you need Network Unlock code means Get from here Theunlockspot and You need Security or password Unlock code means get from Service provider,Following the Instructions below and Unlock Sony Ericsson C905 from Network Lock.
Sony Ericsson C905 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Sony Ericsson C905 mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson C905 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson C905 without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson C905 does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2 & 4. We mean by "Down Arrow" to direct the Jogdial down! In the Sony Ericsson W950i and some other models, the down arrow button/key would be located on the side of the phone.
May 25, 2011 | Sony Ericsson W910i Cellular Phone
IN ORDER TO FORMAT MY INSPIRON 2200, SHOULD I PRESS F1 OR F2?
The actual key to start using Dell PC restore is to press Ctrl key and the F11 key at the same time when you see the Dell logo
Warning: This will initiate dell PC restore, and can completely wipe out all user created files and folders, meaning you will loose all data on your computer (pictures, mails, address book, documents etc)
Dec 10, 2010 | Computers & Internet
What does it mean when it says Drum near end
It means the drum has nearly reached the end of it's useful life, just a warning before it says it is all used up. If quality is still good you can open the front door and press the menu or options key and tell it it's a new drum and keep printing until the print quality fades.
Oct 26, 2009 | Brother MFC-8870dw Wireless Multifunction...
H5-01 code
First thing H5 means you've had 5 continues jams at or before your fuser unit. So the first thing you need to do is make sure you all your paper out of the machine and double check the fuser unit for paper as well as the transfer belt unit for paper on it or behind it. You can simply remove it by first removing your fuser unit (lock is under fuser, a turn dial) then pull the transfer belt out and tilt up. **** Warning**** use caution when removing belt as to not damage the unit. After you do all this you will need to reset the code.
Press the buttons in the following order :
#/P key (program) - Asterisk (*) key -CLEAR key -
Asterisk (*) key - Ready for input of a main code of simulation
Type 14 with the key pad then press your copy key
Press execute then YES Once done press the CA key on the panel and the machine will restart.
Oct 01, 2009 | Sharp Office Equipment & Supplies
I am getting a "Drum Warning
Hi:
Follow this procedure. Press Menu key, then press these number keys 5 2 0 4 then press the down arrow key then press enter twice then press the stop key. This will clear the drum warnig and reset the drum counter.
Andrew
Jun 04, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
Memory full problem
You can hard reset your phone. Back up your data on your phone.
WARNING!!! ALL DATA ON YOUR PHONE WILL BE ERASE.
Here’s how to hard reset or format your Nokia N73 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see the hand animation is displayed.
And if you have time go to nearest service center and upgrade the firmware of your phone.
Jul 23, 2008 | Nokia N73 Cellular Phone
Ingenico iCT220 Payment Terminal Logo
636 people viewed this question
Top Ingenico Computers & Internet Experts
David Payne
David Payne
richie46
Are you an Ingenico Computer and Internet Expert? Answer questions, earn points and help others
