Question about Encore Garden
I have a 1999 encore mower with 22 hp kawasaki engine and it turns over fast but will not engage.Can you help.
    Top Expert:
  • Encore Master
  • 42,852 Answers
Sounds like you have a valve stuck in the open position or a bent / burnt valve
Posted on Apr 30, 2015
darjr
  • 378 Answers
SOURCE: My engine runs fine, but
check your fuel pump. Fuel pump problem.
Posted on Jun 14, 2009
  • 143 Answers
SOURCE: I have an MTD 22
Remove the drive wheels and check the gears inside, they could be worn and need renewing.
Stephen.
Posted on Jul 11, 2009
  • 602 Answers
SOURCE: swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Posted on Jun 14, 2011
2strokeJim
  • 577 Answers
SOURCE: I have a 60" Lesco
If it were me I would check the PTO switch with it running and use a dvm or test light to see if switch is working or defective , you could just have a bad wire connector at the switch or at PTO clutch ....look for discoloration or spread terminals, good luck
Posted on Aug 01, 2011
  • 6468 Answers
SOURCE: 21 HP kawasaki engine hard to start
might be time for a good carb cleaning
Posted on May 12, 2012
New engine Kawasaki 25 hp mower engine has fuel starter engages won't start. I pour gas in carb it starts and run for few seconds what up.
Carb is not feeding gas to motor. Rebuild or replacement is mandated.
If there is a switch on the gas line to the carb it has to be turned on.
Sep 05, 2015 | kawasaki Garden
Toro 22 hp kawasaki starting problems
sounds like the float is stuck to me . take carb apart and clean and reassemble
May 25, 2013 | Toro 42 In 22 Hp Kawasaki Vtwin...
Kawasaki engine 22 HP replaced with new starter and it still will not start
you need to check for power to the trigger wire to the solenoid a bad safety switch will not send power to the solenoid
Jul 16, 2012 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
I have a 21 HP Kawasaki on a 2007 Toro zero turn.Lately when I push the throttle forward the engine backfires and it will also backfire when I engage the blades it also backfires a lot louder when I shut...
the best thing to do is to clean or replace carb filter.. check spark plug for fouling clean or replace also if gas has been sitting in unit and stored outside I would drain gas because of water contamination..
May 26, 2012 | kawasaki Fh641v 21hp 21 Hp Riding Lawn...
Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Jun 04, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
22 horse kawasaki riding lawn mower will not run at full throttle unless the choke is engaged
That is not a good situation. Too rich of a fuel adjustment can wash the bores out on that engine and prematurely wear it out! You will likely need to have the carburetor linkage and plate adjusted so that full throttle operates without engaging the choke. (If this is a single lever that you slide from slow, idle speed to fast, then on to choke)
May 09, 2010 | Husqvarna Garden
Garden Logo
Top Encore Garden Experts
Roland W VanLue
Roland W VanLue
Mike Carew
Are you an Encore Garden Expert? Answer questions, earn points and help others
