Question about Black and Decker USA Black & Decker 2.7 cu ft Compact Refrigerator Black BCF27B
Won't stop running even on the off position on temperature. Freezes everything
    Top Expert:
  • Black and De... Master
  • 42,705 Answers
The "o" position is as cold as you can get
try setting up around 4 and see what happens
Posted on Apr 30, 2015
Power freeze light does not come on
Hi rigbyrr - The Power Freezer light indicates that the freezer is properly connected to electrical power. Is there power to the unit? The light glows even when the temperature control is turned to OFF. Let's try reprogramming the freezer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the unit back. If the issue persists, check to ensure that the appliance temperature control is in the ON position and that the plug is not loose and tightly pushed into electrical outlet. If everything is properly set then in this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your unit.
Jul 06, 2013 | Frigidaire Freezers
The freezer won't keep normal -10F temperature, but stays at -35F to -40F at all times
Thermostat or start relay is defective and causing the compressor and fans to run all the time. Here is a manual for all models=> HERE
Sea Breerze
Feb 10, 2013 | True 49 cu. ft. / 1388 liter Commercial...
FFU14FC4AW3 keeps on running. Will not stop, even it is full and everything is frozen solid.
Try checking the Temperature Control:Testing Temperature Control
Test the control for continuity using a multi tester. Set the multi tester to the ohms setting X1. Place a probe on each terminal. Turn the control to warmest setting or off. The multi tester should display a reading of infinity. If the control does not have an off position, the reading should be near the infinity end of the scale. Now change the control to the coldest setting and retest. The display should read zero ohms. If the control does not pass both of these tests, the switch should be replaced.
Aug 27, 2012 | Frigidaire Freezers
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Freezer used as a frige?
it may be possible. Turn the temperature on the lowest setting and see what happens. If it still freezes everything up then it is not posible. If it doesn't freeze everything , then check the temperature with any temp probe. It should run at somewhere between 36 and 38 degrees. This is the normal cool setting on a refrigerator.
Nov 07, 2009 | Freezers
I have an older commercial upright Hobart freezer. The freezer seems to operate fine, cycling but always returning the compartment to zero degrees, until all of a sudden the temperature went up, well...
In most cases, an evap that freezes up is either an air flow problem or no defrost cycle. Older Hobarts have mechanical defrost time clocks. It could be locked up i.e., not running so no defrost cycle.
It could be coming out of defrost too early because the sensor that monitors the evap temp is not working properly.
The door could not be closing. If left cracked open, it will freeze up every time as unit never hits temp., keeps unit running. Warm air is seeping in and the moisture freezes on evap.
Lastly, the defrost heater(s) may not be working. Burned out, shorted, broken wire, etc.
Good luck and hope this helps.
Mar 28, 2009 | Victory Commercial Freezer VSF-3
Freezer drain freezes, and constant clicking noise
This clicking noise is a bad relay.
Get it serviced before you run in to a real problem
Jan 29, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
My fridge freezes everything
If the temperature outside the refrigerator drops below the temperature inside such as in a non heated garage the things in the refrigerator will freeze. Short of moving the refrigerator to a temp controlled place there is not much you can do about it.
Jan 07, 2009 | Freezers
Black and Decker USA Black & Decker 2.7 cu ft Compact Refrigerator Black BCF27B Logo
163 people viewed this question
Top Black and Decker USA Freezers Experts
mike cooper
richie46
Bill Boyd
Are you a Black and Decker USA Freezer Expert? Answer questions, earn points and help others
