Question about LG Washing Machines
Why does my LG front load washer keep turning itself on every couple of minutes?
    Genius:
  • LG Master
  • 1,585 Answers
Try unpluging for 15mins
Posted on Apr 30, 2015
My LG wm1815cs turns itself off 10-20 minutes into a load of towels. I think it may be weight related but I am not getting any error code
Certain machines have specification, which the user must follow, if you do not adhere to, the machine will not work. if load is one of them, stick to regulated weight it can handle.
Feb 22, 2015 | LG WM1815CS Front Load Washer
LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
Jan 31, 2010 | LG WM2455 Front Load Washer
. I have a LG WD12126RD front load washer dryer
This is a heater error. The heater element is open and not working. This is usually the problem but it could be other things also. You need a service call from an LG tech.
Jan 11, 2010 | LG WD-12126RD Front Load Washer / Dryer
I'm getting the OE code and I've done the the line purge and filter clean a couple of time but I keep getting the error after the wash cycle when the machine try to drain the water I have an LG WM2701H8
try cutting way way down on your soap
front load washers seem to exhibit weird problems when oversoaping occurs
try one load with no soap at all
and then try using 1 tablspoon per load
barring that you may have a clogged pump
Oct 08, 2009 | LG WM-2277HW Front Load Washer
Error code LE on front load LG washer
This is a motor fault code. Sometimes it can be just a communication error, in which case you can try unplugging the machine for 20 minutes and see if it clears the problem up. More likely it is a fault in the motor itself. The most likely culprit would be a defective hall sensor. I will attach a photo of the sensor for you to see what it looks like. To access and replace the hall sensor, you have to remove the rotor and stator at the motor. Before going to this trouble, try the unplugging thing first and also check the connector on the main control board. It is the red connector next to the heat sink2.gif. Using a multimeter, check that the board is receiving a signal from the sensor. Hope this helps and best wishes.
Sep 02, 2009 | LG WM2277H Front Load Washer
LG WASHER
Unplug your machine for a few minutes or more and plug it back in. This will fix the LE error most of the time.
Apr 27, 2009 | LG WM-2277HW Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
35 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
