Question about Fellowes Voyager 125 Laminator
Need a gear box for a Fellowes Voyager 125 laminator
I need a gear box for a Fellowes Voyager 125 laminator, the bushing holding the main drive gear in place is worn out. Anyone know where I can get parts for this machine.
Hi, I have a one that the PCB board is gone, the motor and shredder is perfect. You can buy the top with the motor frame from me if you like. It works sometime in reverse, but the safety light does not come on. Alternative sell me your PCB card
Posted on May 18, 2015
  • Eugene Gee May 19, 2015
    I can sell you the PCB card. The customer bought a new laminator. You can contact me at e.gee39@yahoo.com
Why won't my laminator turn on?
There is a heating unit inside of a hot laminator. Sometimes when you use this machine for too long it can damage some of the internal components because most of those things are full of plastic. You may want to see if Fellows can take it back under warranty. If they can't you are going to have to get a new one.
Feb 05, 2017 | Fellowes Office Equipment & Supplies
Fellowes laminator
Plz try the "Jam free" lever located on the top LEFT of the laminator. You ca try to feed another film in....hoping it will force the pouch out. Otherwise, you will have to take the cover off and unroll the pouch from the inside rollers. Good luck!
Aug 20, 2014 | Fellowes Saturn2 125 Laminator
How do i get my Fellowes Venus 125 Laminator 5215901 to stop bleeping and heat up ?
Unfortunately, this message was posted in the section for paper shredders. If you still need an answer you will need to repost it.
Jul 16, 2014 | Fellowes Venus 125 Laminator 5215901
Beeping and not turning on
This is the second laminator of the same model that is beeping and not turning on. What do we need to do to get this machine operational?
Dec 18, 2013 | Fellowes Jupiter 125 Laminator 5215801
I have a fellowes laminitor and it will not feed
If the motor is running, then the cog that drives the roller system may have failed. Laminators built today are made with plastic (nylon) roller drive cogwheels that crack. Especially if the fed media is too thick. Put the machine into run mode and feed a single piece of card (a playing card will do) into the feed slot. Lightly hold the card and see if you can feel the card moving. To check if the motor is in reverse, feed the card into the output slot.
If you are handy with a screwdriver, then with it disconnected, remove the lid (about six screws underneath) and check the rollers for old lamination sheets that could be stuck to one of them. This would limit the feed gap between the rollers, preventing you from putting your media in.
Nov 23, 2013 | Fellowes Saturn 2 A3 Laminator Laminators
Laminator Jammed! I have a fellowes saturn 125 laminator. there is an item stuck inside that is not sticking out on either side, so cannot be pulled out, even when the reslease lever is pushed. can i...
once you take it apart it voids all warrants if you have any.
if you do not have any warrant parts than that the only way you are going to fix the issue.
here is what some one gave me some tips on disassembly of equipment. draw a picture of the device, mark the area of screw layouts, after separating the 2 parts draw diagram of each part, make foot notes on what you did, screw locations, parts removed, parts cleaned, PUT EVERYTHING IN A LINE IN THE ORDER OF REMOVAL PARTS, than work backwards and put everything back the way you took it apart, you should not have any extra parts and it should work fine. than if it every happens again you have your notes and information on hand to help you. you could try this site.
www.ask.com/
www.manualonline.com/
/mfg.name/make/model#/
www.mfg.name.wow/manuals/service/
www.manuals.wow.com/make/model#/service/repair/
www.disassembly.wow.com/mfg.name/make/model/instructions/
Mar 22, 2012 | Fellowes Saturn SL 125 12.5-Inch Laminator
I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Apr 05, 2009 | Fellowes PS60C-2 Shredder
A laminating sheet is stuck inside machine. You can't see it from either end and machine smokes when turned on now. It is a Fellowes EXL 125-2.
OOOOooooooooohhh!!!!!
Hate to tell you, BUT, the laminate is melted on the fuser. You learned the hard way, htere are specific laminates for different types of machines, the reason is because of the amount of heat it can tolerate. If you look in the back of the box it will tell you what machines they are good for, if yours is not listed, you should look at the manual or the website.
You will have to take it apart and remove the melted plastic, with hopefully minimal damage to your machine, otherwise the fuser will need to be replaced.
Sep 05, 2008 | Office Equipment & Supplies
Fellowes Voyager 125 Laminator Logo
288 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
