A Master Collection designer Thermocast cast acrylic double bowl kitchen sink with a rich high gloss finish that is easy to clean with non-abrasive cleaners.
Put on rubber gloves. Spray the sink with a nonabrasive commercial kitchen cleaner, covering all surfaces of the sink with the spray.
Dampen a sponge in warm water. Wipe the sponge over the sink, scrubbing at any visible dirt.
Rinse the sink with warm water and then dry it with a clean towel.
Fill the sink with warm water and add 1 tsp. of chlorine bleach per gallon of water, once a month. This will sanitize the sink, and is recommended by Thermocast. Let the bleach-water mixture remain in the sink for 15 minutes, then drain the sink. Rinse.
5
Apply liquid automotive polish to a clean, soft cloth. Wipe the cloth over the sink to remove any scratches that may have occurred. Buff the sink using a circular motion. Rinse.
Abrasive cleaners may scratch Thermocast sink surfaces--using abrasive cleaners may also void the warranty.
If they are very superficial, you can use a mild abrasive like Bon Ami or Bar Keeper's Friend. Follow instructions carefully, especially with the latter.
I've decided to "black" mine out with a high gloss black. First I'm going to take the grill off & see if I can use airplane paint remover on a small area to remove the coating that is bubbling.
If so, then i'll primer the surface & repaint it as is since it should be smooth after the remover works and I scrape it down and wash it clean.
You could then leave it once the clearcoat is removed, re-coat it with clearcoat, or paint it any color, even to match. Automotive spray paint is available at auto-parts stores for this type of material, just get the right can of spray paint.
If I find the paint remover won't work without hurting the actual grill, I'll use some fine grit sandpaper and prep the surface, then primer it and paint it high gloss black. Color choice is optional of course!
Rinse after every use. Sanatize with Bleach once a month. Use a soft cloth or sponge and liquid soap to remove residue. Scratches can be buffed and polished with a liquid based auto polish to maintain High Gloss finish. Do not use abrasive cleaners which will dull the finish. If you have used the sink in a non-normal usage and stained it, it can not be repaired under most circumstances. If you have not voided the warranty, you may be eligible for a replacement from the company.
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly. Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Get yourself a "microfiber" cleaning cloth. Search the web & you will find many suppliers online as well as cleaning guides. These cloths are indispensable for glass, TV & computer monitors as well. They are also environmentally friendly as you only need to use a little water with them (no cleaning agent) or even just dry.
