Question about Vizio XVT473SV 47" 1080p 240Hz Tru LED VIA Internet Apps HDTV
Can I use a T-CON board from a 55 model for my 47 model?
    Top Expert:
  • Vizio Master
  • 74,871 Answers
No. You can't. Both will be different.
Posted on Apr 30, 2015
Testimonial: "I meant using a T-Con board from a XVT553SV on my XVT473SV. Both TVs are from the same series model."
I have a 47 Philips flat screen model #47pfl5708/f7 . the screen went dark when I turned it on. It flickers a little but nothing shows up I was wondering if it was the main board or the t-con board?
It is possible, the T-con board does produce the image you see but trying to fix this by guessing is a really bad idea. I would just buy a new TV and avoid the chance you are not correct about defectivethe part.
Oct 20, 2016 | Philips Televison & Video
My Phillips 47 LCD TV is loosing picture but is keeping sound.
Main board feeds the t con board. However try the flash light test on set because it might just be the inverter board that powers the backlighting.
Mar 17, 2016 | Televison & Video
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Where do the two ribbon cables that come off the main board and run down to center of the frame on my LG 55 inch tv model # 55lm7600-ua I only see a place to attach one of the cables.
I changed the t-con and ribbons on the 55" model precedeing this one and both ribbons terminated at the t-con board, check that it is not hidden beneath a large aluminum square metal plate
Dec 02, 2015 | LG Televison & Video
I have a 47 inch LG model 47LN5400 and obviously the back light is no longer working. There are 3 boards, power, main, and T-con. Can anybody tell me which board I should replace?
One suggestion may be to check the ShopJimmy videos on YouTube. There is a flashlight test you can perform. I remember someone who had a similar problem as yours and they were directed toward the T-con board.
May 18, 2015 | LG Televison & Video
White dots on screen
Most likely T-Con PCB. Part Number varies (See Below)
http://www.shopjimmy.com/tvs/tv-t-con-boards?restrictBy[known+models]=VIZIO+E550VL
Nov 25, 2013 | Vizio E550VL 55 in. LCD HDTV
Vizio t-con board
You haven't given the exact model number to your Vizio TV here. There are so many types of T con baords. images of two of them are attached. Contact the nearest authorised service center for Vizio to get an orginal replacement board.
May 11, 2012 | LG 47LG50 47 in. LCD HDTV
On 47-inch Westinghouse monitor, where is the T-con board located?
hi,
There will be a strip wire from the Mother boad to the display section, it will ends in the T Con board. Normaly in lcd monitors the T Con board will be shielded with aluminum sticker foil, in the lower middile section of the monitor.
ok
Jun 21, 2011 | Westinghouse VM47F140S LCD TV
I have a 47" Vizio
This problems the tv serveral vertical lines show up on the LCD screen panel by itself?Yes,the tv board that call the T-CON decodering board is dying.The T-CON decodering board it sit at the middle bottom of the LCD screen panel.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.If these vertical lines cause by an object or a person by hitting the LCD screen panel,tv is not repairable,because the LCD screen panel is dead not worth replacing because the LCD screen panel are 90% important to the tv and cost the same as a new tv.
Mar 26, 2011 | Vizio VO47L 47 in. LCD TV
Vizio XVT473SV 47" 1080p 240Hz Tru LED VIA Internet Apps HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
