Question about Maytag Neptune MAH5500B Front Load Washer
Washer only had cold water hooked up to it. Sounds like the washer fills with water but my clothes do not get wet.
I thought the error code was ne
    Genius:
  • Maytag Master
  • 1,585 Answers
Pressour switch
Posted on Apr 30, 2015
jsrock516
  • 5911 Answers
SOURCE: Hot water fill problem
Replace or clean your water inlet valve. It appears that the hot water solenoid has either become clogged, or had failed. You can find a replacement at repairclinic.com. Type in your COMPLETE model number in the Search window and there will be two of them located under the "Water Valve/Float" heading. Depending on WHICH type of valve you have, a replacement costs between $28 and $74. Refer to the part illustrations to make sure you are ordering the correct part. If you require assistance in accessing the inlet valve, let me know. I hope this helps you.
PS If you attempt to clean the valve, you will need to turn off the water supply and disconnect the hoses. Check the inlet screens for sediment or debris.
Posted on May 28, 2008
duby1990
  • 367 Answers
SOURCE: MY WASHER FILLED UP WITH WATER, BUT THEN IT JUST QUIT WORKING.
I believe it is your lid switch. I have replaced 3 this week. If you get me the model number i can tell you for sure. Another thing that caused this is the motor to go bad. Do you smell a burning smell when it is trying to run after the fill up? If not get me the model number and i will get you the part number for the lid switch.
Posted on Nov 21, 2008
Just_Bobz
  • 448 Answers
SOURCE: spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Posted on Feb 21, 2009
SOURCE: Maytag Neptune Error COde "nd"
I had the exact same problem. nd code (no-drain) at the end of the cycle and when I opened the door the machine was still full of water. I took the back panel off the washer and disconnected the drain hose from the pump. (You're going to get quite a bit of water gushing out at you so be prepared with towels or a shop vac.) At this point you should see a little rubber disc over the end of the section you just exposed on the pump. This is a little drain flap. Just lift it up and you should be able to see into the pump a little bit. At this point I poked around in there with my finger and found a hair pin stuck in the pump! I wasn't able to get it out from this end of the pump so I disconnected the big rubber boot which connects the wash drum to the pump. Then I was able to twist the pump (counter clock-wise) and release it from the washer base. I didn't have to disconnect any wires and was then able to see into the other side of the pump and pull the hairpin out. Put everything back together and it's worked fine ever since. I've never even looked inside a washing machine before but it really was really fairly simple. Now my husband really does think I'm a domestic Goddess. I said he should take me out to dinner with the money we saved on a service call!!
Posted on Mar 18, 2009
This is now the 3rd time this has happened. The 1st 2 times it cost me ~$100 to have a technician come in and fix.
This time, I did it easily. For my Maytag Neptune washer, I removed the back panel (2 screws). On the bottom tray is the water discharge pump. On the output side of the pump there is a small cavity under the rubber flapper where a nickle fits perfectly. I removed the nickle, reattached the output drain line. started it up ...
and viola! the problem solved.
Posted on Jun 28, 2009
The NF light comes on
The nF error code stands for "No Fill."
If you have just installed your washer and it will not fill, or the display shows nF, check the following:
  • Make sure the door to the unit is tightly closed.
  • Make sure that both the hot and cold water lines are connected (cold to the cold and hot to the hot)
    • Note: If you do not have a hot water source, you can hook up the cold water source to the cold input on the back of the washer and another cold water source to the hot input on the back of the washer (but NEVER a hot water source to the cold water input on the back of the washer).
Oct 14, 2012 | Samsung WF337AA Front Load Washer
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
After washing -washer slowly fills with water and runs out the door--not every time it is used. First noticed clothes still wet needing to run spin cycle--then washer leaked on floor over week end and...
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer is on making hum sounds but clothes are not all getting wet
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jan 24, 2011 | GE WSXH208A Front Load Washer
Warm water filling up washer, with no hot water hooked up to wash
exactly
it will maintain 60 degrees but cycling hot cold
thermistor
Sep 29, 2009 | Maytag Performa PAV2200
Rinse cycle water level
I would cheak your drein hose ithey should be higher then the tub of washer.If not remove hot and cold hoses from tap and washer and clean screens or get ne ones good luck:)
Apr 04, 2009 | Whirlpool CAM2752RQ Coin Operated...
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
F20 Error code
be sure to ck fill hoses make sure both are turned on all the way ..remove hose at washer end ckd screen inside inlet for sand/rust/gunk pull screen out to clean and be sure to reinstall it or you're asking for trouble down the road..also ck faucet end just in case someone installed one there 2..by the way just having cold water only on will cause same problem
Aug 26, 2008 | Kenmore 46462 Front Load Washer
Kenmore Oasis HE Washer
problem started when washer started itself up twice in the middle of the night....after that the washer seems to have problems figuring out what it wants to do...when running a wash it will start, run for 2 minutes then start scanning numbers...it does not land on a code...it will spin, stop, start...sears has replaced the mother board 3 times....and we will be phoning them again as it has not fixed the problem..one other time it did not spin properly and clothes were wet...we have a dedicated surge protector on it...we have had our electrical checked and no problems there...sears confirmed that as well..the techs have given up on it and don't know what to do with anymore...it is still under warranty and now costing sears more to service it then replace it....time for them to do the right thing and "take it back"...very disappointed in this washer...wish me luck when i call them again...they must be sick of hearing from me....lol
Apr 26, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
