Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have a 46" Sony Bravia TV that has colored verticle lines about 2-3" wide just left of center.
Verticle lines about 2-3' wide just left of center
  • Sony Master
  • 6,694 Answers
Yor tv have problem with T con board. T con board is one which drives the pixels of the LCD panel. If any of the driver satge in the T con board is faulty then this problem can occur.
Some times bad contacts on the connections of the t con board can cause same problem. Remove the tv and find out the t con bard. Remove the connections to it and the reconnect the connections. Then check, if the problem remains the same then the tv need a new T con board.
You have didn't mentaioned any model number of your tv. So it is not possible to show you exactly how T con board looks.
Normally in all lcd tvs the tcon board is place on the bottom or top middile position. Which will be cover with metal cover or aluminium foil.
Here I have added a link which will lead you to the picture of T con board for toshiba.( Not exact one)
T con
http://electro-medical.blogspot.in/
Posted on Apr 30, 2015
Sony KDL40EX400 has (2) 2 inch wide vertical color bars about 4 inches from the left side of the screen. Purchased July 2010
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 22, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How much cost to repair vertical color lines on sony bravia 46 tv
Please confirm if your model no. is KDL-46s2000 to assist you further on your problem.
Oct 05, 2011 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
My Sony BRAVIA KDL-46V3000 Television has messed up colors on left side when first turning it on.....after 5 or 10 mins the picture is normal.. Also without turning on the receiver (only TV) can't select...
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Nov 15, 2009 | Sony BRAVIA KDL-46V3000 Television
A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Nov 09, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lines across tv
try cleaning T-CON Board to Lcd panel cable
Jul 23, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Verticle lines for picture
You need to describe these lines better. Are they moving or stationary? Are they very fine lines with sharp edges or are they more like bands with soft edges? How many lines do you see, and how wide are they (compared to the screen width)?
Fine lines that are stationary: defect in the electronics causing a vertical row of pixels to be dead or stuck. Can only be fixed by replacing major parts.
Broad lines with soft edges that move: could be electrical "hum" interference. Make sure you are using a grounded (3-pin) power plug, and that the outlet is properly wired. (Take the TV to a another location and see if the problem goes away).
Make sure you don't have fluorescent light fixtures nearby--they can interfere with the picture if the bulbs or ballast is defective. Could mean tecon board or display is bad which means replacing both in a sony if they are bad i recomend buying a new tv because it is not cost effective to replace these.
Jul 13, 2009 | Sony Televison & Video
COLOR TV SETTINGS
get a thx optimizer disc and put it in your dvd and set..baby set...
Apr 19, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
118 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
