Question about Carrier Cycling
Need bracket to hook up carrier to bike - Carrier Cycling
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
Www.youtube.com/watch?v=oyMx0eXHVdg
If you need further help, reach me via phone at https://www.6ya.com/expert/cynthia_0eebb7da17b33b5e
Posted on May 02, 2015
Bobbin case won't close, error message coming up that hook system won't engage.
1. The bobbin carriers usually have a spring on top and little parts on each side. The carrier must be installed so the holders on each side are keeping it from spinning either direction.
2. Rotate the hand wheel until the opening is noticeable. This is where you need to install the carrier.
3. While installing, the spring must be pulled up slightly to get the carrier under the spring.
4. Try to rotate using the hand wheel. There should be no rotation back and forth. Don't make the edge brackets too tight against the carrier. The thread has to go through this area.
5. Once you have finished this put the bobbin in. Now, it should work.
Apr 03, 2015 | Sewing Machines
Tip
How to Remove and Replace the Bottom Bracket on an Indoor Cycling Bike
Following is a basic guideline of removing and replacing the bottom bracket on an indoor cycling bike. Due to the different brands of indoor cycling bikes and designs for bottom brackets, the following should only be used as a guideline. If any of the information is not exact to the bike being serviced, refer to the service manual or call Sportsmith for further help.
Common Tools Needed:
Phillips Screw Driver
Set of Allen Wrenches (standard and metric)
Bottom Bracket Tool
Cotterless Crank Puller Tool
9/16" Socket
Ratchet Wrench
Pedal Wrench
Crescent Wrench
You will begin by removing the outside belt/chain guard by using either or both the Phillips screw driver and Allen wrenches. It may be necessary to remove the drive side pedal (using the pedal wrench) in order to completely remove the outside belt/chain guard.
Once the belt/chain guard is removed, you will need to remove the belt/chain. If the unit is belt driven, you can simply "walk" the belt off the pulley by pushing the belt to the outside while turning the crank backwards. **CAUTION: PINCH POINT ** If the unit is chain driven, most use a continuous chain that can be "walked" off the sprocket just like the belt. **CAUTION: PINCH POINT ** Some chains may use a connecting link and can be separated at the connecting link to remove the chain. The connecting link is different in appearance from all other chain links.
Now it is time to remove the crank arms. How to Use a Cotterless Crank Puller Tool
It works best to place the bike upside down for best leverage to remove the bottom bracket. (If placing the bike upside down, ensure proper seat adjustment for best bike balance.) Begin removing the bottom bracket from the drive side of the bike. This side has a reverse thread. You will need to turn right to loosen and remove the bottom bracket. Place the teeth of the bottom bracket tool into the teeth of the bottom bracket cup. Using the ratchet wrench or crescent wrench to turn the bottom bracket tool, you will turn right to loosen and remove the bottom bracket. (If removal of the bottom bracket is difficult, it helps to use a crescent wrench in combination with a bolt threaded into the bottom bracket shaft to hold the tool in place while applying pressure to break the bottom bracket loose.) Remove the bottom bracket from the frame. Remove the bottom bracket cup and/or lock ring from the non-drive side of the bike. This is a standard thread. You will turn left to loosen and remove this bottom bracket cup and/or lock ring.
Install the new bottom bracket from the drive side and tighten flush to the frame. Install the bottom bracket cup and/or lock ring to the non-drive side and tighten.
Re-install the crank arms and pedals. Make sure the crank arm bolts are tightened to the proper torque. If unsure of proper torque specs, refer to the equipment service manual or call Sportsmith.
Re-install the belt/chain onto the pulley/sprocket. If belt/chain was "walked" off the pulley for removal, it can be "walked" onto the pulley/sprocket by placing the belt or chain along the bottom of the pulley/sprocket. Carefully, turn the crank arm forward while lifting on the belt/chain. **CAUTION: PINCH POINT ** Continuing turning the crank forward until the belt/chain is in place.
Re-install the outside chain guard and test the unit. Ride the bike without tension and test with tension. Ensure functionality and feel of the ride. Make any adjustments if necessary
Removing and Replacing Bottom Bracket on Indoor Cycling Bike
on Mar 11, 2015 | Exercise & Fitness
Bottom bracket need replaced. needs a new crank set. what size if the bottom bracket and what size crank set is recommended, or does the bottom bracket need to come out to find the size. bought the...
impossible to tell you without knowing the bike brand and model and year, although you have provided that 1999.
If you take into a bike shop, which is the usual place to purchase the parts you need, they will be able to tell you what size Bottom Bracket will fit your bike, also what options you will have for replacement cranks and bottom bracket. This could be a very complicated issue when replacing with parts that are 11-12 years newer, the shop will be best equipped to give you all your options.
Apr 07, 2011 | Cycling
How do you take the spar tire off the bottom of a 2000 hond passport
hi not sure on your vehicle? but if spare wheel is on a crrier under rear of car ? then to remove it lift up the carpetin boot near the rear crossmember that hatch locks onto you will/may see a head of bolt in a dished hole this bolt head is same size as wheel nuts so use wheel brace and turn bolt anticlockwise as you would to remove wheel nuts keep turning bolt til it stops this actually lowers the carrier with wheel spare then you will see thet there is a hooked bracket at end of bolt just lift carrier and move hook off you can now lower carrier/spare wheel off reinstall is reverse proceedure now a word of advice? lubricate the threaded lowering bolt b4 refit of carrier and do not run vehicle without a wheel on the carrier as carrier can/will jump off hook
Dec 20, 2009 | 2000 Honda Passport
How to install a child carrier in my bycicle?
Depending on which carrier......It should just hook right onto the back wheel area(beside the hub)...
Good Luck
Jun 24, 2009 | Carrier Bike Bicycle Kids Childs Seat Baby...
Bell child seat (carrier)
p100645reg.jpg The top should anchor to the seat post bolt, the bottom two should clamp onto the rear triangle. you should have the seat, a spoke guard, two clamps, and seat post bolt mounting bracket. if you received all the pieces. Hope this is of some help. Ed
Apr 27, 2009 | Bell Sports Deluxe Child Carrier
Is parkway receiver mount bike carrier right for mercedes s320
hi,better to consult your dealer,if your model can fit your bike carrier,dealer have a special equipment manual for every mb model
Mar 22, 2009 | 1999 Mercedes-Benz S-Class
Cycling Logo
168 people viewed this question
Top Carrier Cycling Experts
Michial Gueffroy
Bill Boyd
Are you a Carrier Cycling Expert? Answer questions, earn points and help others
