When the tv has been unplugged it won't come back on.
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 30, 2015
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
TV won't come back after pushing wrong button on remote.
Try unplugging the TV.. After you plug it back in it may be OK. I had a similar problem were I could not turn on the TV (JVC). The owners manual specified in the troubleshooting section to unplug for 1/2 hour. I left it unplugged overnight and the next day plugged it in and it was fine.
May 21, 2013 | Televison & Video
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I've owned for approx 3 yrs. Today I was watching a show on my Panasonic TH-50PZ80U and all the sudden the sound went away. From the lowest volume setting to the highest, no noise at all...Please...
Hello!
First move: unplug your broadcast provider's box, wait for a minute, then plug it back into power source. I mean: leave all the connections intact, just unplug from power source. It might be just power cord or power adapter. If that's not the case, please do the same with TV. Unplug it from wall outlet, wait a minute, plug it back in. It's a next step, if your "box" won't take care of the problem. If that won't take care of the issue, refer to owner's manual for "reset" procedure. Worst case scenario: you might need to replace main board inside or your TV.
good luck,
Thanks,
Alex.
Oct 09, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Who is liable for s replacement tv if electrical company turns power off and on during a storm and the tv won't come back on?
have you unpluged the power from the tv and the outlet for a few minutes? then plugged it back in?
Jul 25, 2011 | Sanyo Televison & Video
My Sony bravia kdl55hx800 lcd 3d tv won't turn on
try unplugging your t.v for a few minutes, then plug it back in. if it continues check your owners manual or google your issue. this might be the red flash of death. hopefully unplugging it works. good luck!
May 18, 2011 | Sony Televison & Video
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
We won a new sony tv, after setting it up, i was adjusting the color,when tv wentBLACK with white lines running thru it,unable to get picture again.thanks chuck
Tries unplug,replug the tv back like an hour.Now,the tv is resetting itself back to factory setting.The tv should work again.If not,the tv Tuner signal board have problems.Tv is less than a year old wright?Call Sony Corp. for a warrenty repair.
Oct 17, 2010 | Sony Televison & Video
Televison & Video Logo
Top Televison & Video Experts
