Question about Measuring Tools & Sensors
WHERE CAN I FIND A WIREING DIAGRAM FOR TROY BUILT RIDEING MOWER WITH B&S MOTOR
WIREING DIAGRAM FOR B&S ENGINE INTEK 18.5 HP, TWIN CYL.,MOD 407777, TYPE O174-E, C 030908YG
  • 376 Answers
SOURCE: Stratton Briggs Stratton Intek V - Twin Engine 21
The oil is contaminated with water. Change oil and filter, if it has one.
Posted on Jun 14, 2009
  • 225 Answers
SOURCE: Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Posted on Jun 21, 2009
  • 3 Answers
SOURCE: i have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Posted on Jul 20, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
kel1guy2002
  • 3740 Answers
SOURCE: how do set valve lash
Turn the motor until the piston is at TDC. Look through the spark plug hole. piston to top of the cylinder. Then set them like you would any OHC rocker arm. BE very careful with the exhaust valve adjustment. There is like a mini disc on top of the valve stem spring keeper. If you get it too loose on a vertical engine it can drop out and it will take you forever to find the little bugger!
Below is only a recommendation....
I don't know how many hours that are on this engine your working on but... I would recommend you hand lap the valves with grinding compound if you know it has high engine hours. It will make it easier to start and have more power. The exhaust valves on these engines get very noteable black gunk buildup in the seat to the point you can not see the "valve to seat" mating ring on the valve head. The heads are not hard to remove... (One at a time) just time consuming. It can be a chore getting the valve push rods aligned with the engine horizontal. Most of the time and I know good Mechs don't like to hear this.. you can reuse the cyl head gasket on this model due to the design. Once in a while they break not very often.
The valve springs have keyhole locks on the keeper.
Thanks for using FixYa,
Kelly
Posted on May 01, 2010
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to know the weight of the motor oil
sae 30 in winter sae 40 in summer i preffer rotela
Aug 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Does a briggs 18 hp twin 2 have a oil filter its a late 90's model mtd riding mower
Most likely yes. It will look like a car oil filter. It looks like a round can that is screwed to the engine.
Mar 17, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
142 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
