How can I clean the scanner so I don't get lines on the photo copies?
    Master:
  • 456 Answers
Make sure the lid is closed tightly ( stand something on top ) also the lines could be through the resolution of the scanner. go in to the scanner settings and turn the resolution up. dirt wont cause lines but smudges would look like shadows when copied
Posted on Apr 29, 2015
How do I get rid of the lines when I make copies. It dose not happen if I print a scan
If you are using the ADF ( automatic document feed ) for your copies, raise the scanner cover and clean the strip window to the left of the main platen. If you are using the platen for copies and getting lines where scans are clean - you have a physical issue and it should be checked out by a technician.
Apr 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
My epson stylus nx105 shows a black vertical line when scanning but not printing
THE BLACK SCANNED LINE IS PROBLEM OF THE SCANNER CARRIAGE AND HAVE TO BE CHANGE.
May 18, 2014 | Epson Stylus Photo R300 InkJet Printer
Lines on copies when scanning and copying on Canon 3480i optics cleaned, Help
Are the lines you are getting from banding? Are these lines there when you print a photo from the computer as well? If so then the printhead probably needs to be re-aligned.
Don
Oct 08, 2013 | Canon Office Equipment & Supplies
I have a minolta ep2030 and when i hit copy all i get is black page.
- clean the scanner optics
- if this don't work check and replace drum cleaning blade
Jul 26, 2012 | Minolta EP1030/1030F CS/PRO Copier
When I print colored copies on my Office Jet L7680 All in One, there are red lines through the photo. I have changed the cartridges but still have the lines. Can you help?
check heads of printer. clean it,check paper path and clean it internally.try to upgrade your system software.if the computer generated prints are OK but copies are effected then you must be check, clean or replace scanner unit.
Mar 03, 2011 | HP Office Equipment & Supplies
Colored lines on a copy page
To fix the colored lines on a copy page do the below steps
  1. Disconnect the power cord, wait five seconds, and then plug it back in. This will reinitialize the unit and force the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the unit must be serviced.
  4. Verify that the alignment page is placed on the scanner glass or in the automatic document feeder (if equipped) correctly. Place the printed side down.
  5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
Dec 10, 2010 | HP OfficeJet k60 All-In-One InkJet Printer
HP Scanjet N6010 Once documents are scanned a line appears on the scanned copy
The lines on a scanned document are typicaly caused by dirt on the scanning glass. To clean it use the following steps.
1. Unplug unit.
2. Open the fron access door from the top.
3. Clean both top and bottom **** glass that run the width of the scanner.
The glass can be cleaned with a lint free cloth and a mild glass cleaner.
Jul 21, 2010 | HP Scanjet N6010 Photo Scanner
Brand new fax when we send a fax it is received at the other end fuzzy or blurry. Tried a different phone line and still the same. Cleaned glass on scanner
Slight possibility that your sending in Photo Mode, most likely the machine was damaged during shipping and the CCD unit or scanner is out of alignment. Just make a copy....if it comes out blurry then it is the scanner. I would return it for another machine. If the copy comes out nice and clear then there is nothing wrong with the scanner.
Oct 22, 2009 | Brother IntelliFax-4100e Fax
Pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
66 people viewed this question
k24674
jasbo
jasbo
