How do I stop get my PC from booting and running in safe node.
Have recovered the system three (3) times. This does not work, please help I AM LOST........
  • 5,631 Answers
When in safe mode, run System Restore selecting a point BEFORE this issue started.
Please COMMENT if your result is positive
Posted on Apr 29, 2015
  • 3,957 Answers
Reboot and press F8. Select boot normally.
How do i run microsoft windows and dskchk safely as computer takes 3-4 times to boot
Hi
which operating system are you using if you are using vista please change it to windows 7 ultimate to nearest hardware shop,,,,,,etc
the correct command fro check disk is "chkdsk" with out quotes
if it asks again at boot time "chkdsk /r /f " (this for recover and fix the errors on boot time )
Thank you
HARSHA
Mar 01, 2015 | Microsoft Windows Vista Home Premium...
I need help recovering my EL 1200 emachine, when I boot it up it says that PXE-E61: Media test failure, check cable. I don't know what it is talking about. What can I do to get booted up. I don
check all data and power leads that attach from motherboard to your hard drive make sure they have dust free secure connections
if its a flat 40 pin ribbon type it will be the first to fail
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
Jul 15, 2012 | E-Machines eMachines Desktop PC
Please explain step by step how to reboot a computer into a safe mode?
to boot a system in safe mode restrt your computer as the computer starts press F8 you will see a set of command like safe node safemode command etc click safe mode you will see set of files running wait till the safe mode starts the you will be able to see the mouse icon then it will ask do you want the computer to start in safe mode click yes now you are in the safe mode section in safe mode section the system starts in defult setting you wont be able function somefunctions safe mode is for correctiong your computer or to remove unwanted software or hardware
Oct 26, 2010 | Computers & Internet
My asus Eee 1005 wont boot up unless i go to safe mode with networking, how do i fix this so I can boot up normally without using safe mode?
If it is booting up in safe mode and not booting up normally then it could be a driver fault or some sort of spyware virus.
Try using system restore in safe mode to restore the laptop to a time when it was working fine.
goto start bar, click on run and type msconfig, in here you can choose anystart up programs or services you dont need or use and stop them from starting, make sure you are positive you are stoping programs that you know are on your mechine.
Dont restart yet goto my computer c:drive, goto the windows folder and find a folder called prefetch open this folder and delete all of it contents, once done close out of all windows and restart the pc in normal mode hopfully the problem will be solved.
hope this helps and please post back what happens.
Aug 12, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Dell precision m4400 blue screening"system has recovered from a serious error"
"BSOD" also known as "Blue Screen of Death" occurs when system is not stable due to misconfiguration or driver incompatabilty or Virus or worm infection.
Method 1 :  Start your system by pressing F8 upon startup. Select "last know good configuration that works".check this one solve your  porblem.
Method  2 : Start your system by pressing F8 upon startup. Select "safe boot "and check if it work or able to log you into your Desktop.
Uninstalled any software or hardware you have recently added or installed.Click "Start", Select "Run", type "msconfig"
Again click "Startup" tab.Untick all the program thats loads during your system Boot up.
Method 3: Start your system by pressing F8 upon startup. Select "safe boot "and check if it works or able to log you into your Desktop.
Click "Start", and then select "All programs", then "Accessories".Select "system tools" and then "System Restore".Try to restore your PC to a point or date which you know it was working fine.
Method 4 : If none of the above workor you are able to boot it. Then download "Hiren's Boot CD"
Here is the link
http://hirens.longcomputerservices.com/Hirens.BootCD.10.1.zip
Download the file and burn the ISO image in a CD.Boot your system using that CD. It has lots of tools for repairing Windows, system restore, Data recovery etc.Check if it can fix your problem.
If Hiren's Boot CD can't fix it then Backup all your important datas and go for a new install.
Don't forget to create system restore point whenever you are going to make changes to your system.It will help you in recovering during the time of failure.
HAPPY NEW YEAR.
Dec 31, 2009 | Dell Mobile Precision M4400 Notebook
Acer aspire 5100 stops at agpcpq.sys and keeps rebooting. Will not boot up normally, safe mode, or any other way. Booted off of install CD and ran chkdsk /r. No luck.
Boot from the CD again and this time run chkdsk /f
This command will try to fix any errors with the file system and check for and recover bad sectors.
Hope this helps.
Aug 28, 2009 | Acer Aspire 5100 Notebook
Unable to boot
pls give the following detail
model of notebook
is not able to boot into any of the mode??
May 19, 2008 | Toshiba Satellite A25-S207 Notebook
Computers & Internet Logo
David Payne
David Payne
