How do you change the password for your mac computer?
  • 3,957 Answers
Http://www.macworld.co.uk/how-to/mac-software/how-change-admin-password-mac-3535328/
Posted on Apr 29, 2015
I forgot the administrator password, there is a malware protection software I believe. Is there any way to recover password?
You need to restart with original media disk and then you can choose reset password from the apple menu bar.
Mar 14, 2015 | Apple 24" iMac Desktop
Remove password
system preferences - users and groups - select user - enter password - change password to blank
Mar 05, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Kocaso nb726a
Resetting a password without an additional account Use these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset.
"Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  6. Enter a new password.
  7. Click Save.
  8. Click the red button in the upper left corner to quit the application.
  9. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  10. Click Restart.
After following these steps, you need to update your keychain so that it recognizes the new password.
If your computer doesn't have an optical drive, connect it to a computer that does using Target Disk Mode, or use the Remote Install Mac OS X utility to start up the computer remotely. Resetting a user's password in Mac OS X v10.5 or earlier If you are using an earlier version of OS X, select your version number below for password reset instructions. Avoid setting a blank password for a user account when using these steps. Mac OS X v10.3 through 10.5.8
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" above.
  2. From the Apple menu choose System Preferences.
  3. From the View menu choose Accounts.
  4. Click the lock button if it appears locked; enter the administrator password.
  5. Select the name of the user whose password you want to change.
  6. Click the Reset Password button or the Change Password button.
  7. Enter a new password in both the New Password and Verify fields, and add a Password Hint if desired.
  8. Click the Reset Password button or the Change Password button.
  9. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Mac OS X v10.2 through v10.2.8 Use Accounts preferences to reset an account password.
  4. Click the lock button if it appears locked.
  5. Select the username whose password you want to change.
  6. Click Edit User.
  7. Navigate to the New Password field.
  8. Enter a new password in both the Password and Verify fields.
  9. Click OK.
  10. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Regardless of how many characters are actually in a Mac OS X v10.2 password, seven bullet characters (•••••••) will appear in the New Password and Verify fields the next time the password is edited. Mac OS X v10.1.5 or earlier Use the Users preference pane to reset a the password.
  3. From the View menu choose Users.
  5. Select the username whose password you wish to change.
  6. Click Edit User.
  7. Enter a new password in both the Password and Verify fields.
  8. Click Save.
Important: Passwords for administrator accounts should not be blank.
Regardless of how many characters are actually in the password, thirteen bullet characters (•••••••••••••) will appear in the Password and Verify fields the next time the password is edited.
Jan 01, 2014 | Computers & Internet
I have apple i book g4 i forgot my password.
Changing your administrator password
To change the administrator password, you must know the current administrator password. If you're logged in as the administrator, open Account preferences and click the Change Password button.
If you don't remember the password and automatic login is turned off, you can reset the administrator password using the Mac OS X User Install disc.
IMPORTANT: Because a user with the Mac OS X install disc can gain unrestricted access to your computer, you should keep the disc in a safe place.
To reset the administrator password using the Mac OS X disc:
  1. Insert the Mac OS X Install disc and restart the computer.
  2. When you hear the startup tone, hold down the C key until you see the spinning gear.
  3. When the Installer appears, choose Utilities > Reset Password.
  4. Follow the onscreen instructions to change the password.
  5. Quit the Installer and restart your computer while holding down the mouse button to eject the disc.
Be sure to change your login password in Keychain Access to match your new password.
Aug 05, 2011 | Apple iBook G4 Mac Notebook
I forgot my password
You can change the master (root) password with the Mac installation disk.
May 04, 2011 | Computers & Internet
Reset my administrator password
To reset the administrator password using the Mac OS X disc: step_1.gif
When you hear the startup tone, press and hold down the C key until you see the spinning gear.
When the Language Chooser appears, select your language and click Continue.
Choose Utilities > Reset Password.
You can change your login keychain password in Keychain Access to match your new account password to unlock your keychain when you log in.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 04, 2011 | Apple iBook G3 Mac Notebook
I need to change password on apple mac computer
To secure your Mac, it makes sense for an administrator password, which should be defined easily guessed by others. Mac Administrator rights higher than compared to other users. To keep secure your Mac to create their importance a strong password for admin or you can reset after a certain time.
Change Mac administrator Password
Aug 11, 2010 | Apple Computers & Internet
How can I find the admin password on my mac. I had a new hard drive put in my pc. I want to change some of the admin settings but I need the password. How can I find it or change it without knowing the...
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  2. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
  3. Select the user name of your original administrator account.
  4. Enter a new password.
  5. Click Save.
  6. Click the red button in the upper left corner to quit the application.
  7. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  8. Click Restart.
  9. After following these steps, you'll want to also follow the steps in this article.
Mac OS X v10.6: Resetting the original administrator account password on a Mac that has no optical drive
These steps require a second computer that has an optical drive.
Note: If the second computer is a Mac, make sure Mac OS X v10.5.3 or later is installed. If the second computer is a PC, make sure the DVD or CD Sharing Update 1.0 for Windows is installed.
  1. Open "Remote Install Mac OS X" from the Utilities folder.
  2. Follow the onscreen instructions.
Feb 10, 2010 | Apple MacBook PC Notebook
I just set up the password on my macbook to get rid of a network settings problem and now the computer is saying i am putting in the wrong password!!!! I powered off the computer and restarted thinking...
Ok well try this... Resetting a user's password in Mac OS X v10.3 or later
Note: For information about resetting a password in Mac OS X v10.2.8 or earlier, see the Additional Information section below.
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" below.
  6. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
  7. Enter a new password in both the Password and Verify fields, and add a hint if desired.
  8. Click the Reset Password button (Mac OS X v10.3 and v10.4) or the Change Password button (Mac OS X v10.5 or later).
    1. Enter a new password.
    2. Click Save.
    3. Click the red button in the upper left corner to quit the application.
    4. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
    5. Click Restart.
Feb 06, 2010 | Apple MacBook PC Notebook
Forgot my pass word on apple note book
HI there,
You can change your password with the original system disks that came with the computer. Put the discs in the computer, restart it holding down the "c" key to boot off the disk. Choose your language, then go up to utilities tab on the top and choose change password.
This will only change the login password, and not the keychain access passwords.
Cheers
Apr 29, 2009 | Apple iBook G4 Mac Notebook
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
