Question about Vetta RT33
Totally dead after winter storage with battery removed even with new battery inserted. Any hope?
The battery cell has failed or a bad contact
so clean them with a burnish pen its gota be a bad contact
check out some images and solutions in google
https://www.google.co.uk/search?q=Vetta+RT33&tbm=isch&tbo=u&source=univ&sa=X&ei=KkBBVdKVPIOE7gbE4IHADw&ved=0CC4QsAQ&biw=1138&bih=510
i use the £1 shops you get a whole card of like 4 of each type of thin cells
so.. this is the issue
and the pics shows you how to change it out
but the trick is not too touch them with your fingers
or youll discharge the cells fast!!!
1 second charge gone...
use plastic tweezers ... to handle small cells
or some rubber glove etc ... surgical gloves
Posted on Apr 29, 2015
I need a manual for a Bluetooth Kross speaker GY509
Yes battery could be totally dead beyond charging .
May 04, 2018 | Cars & Trucks
Why won't it start after winter storage?
Hi, Lucy if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 3 years or older when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and replace the battery.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove your air cleaner and clean and re-oil per Mfg. specifications.
6. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
8. Replace spark plug with a new one and check for spark.
Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 18, 2016 | GAS Motorcycles
The computer will not turn on it is totally dead
Remove the battery and use only the charger. It should work... If not could be a bad charger.
May 01, 2015 | ASUS Eee Computers & Internet
CAMERA WILL NOT POWER UP EVEN WITH FULLY CHARGED BATTRIES
Try non-rechargeable batteries, and try testing your rechargeable batteries because they do wear out.
Sep 19, 2014 | Cameras
I charged my batterie because it was dead from winter storage and as soon as it was charged and put back on I have had nothing but troubles with my alarm system going off even when driving, what is the...
I would have the battery tested to see if it has a dead cell first . Some times this will happed especasly if its over 4 or 5 years old and if it was left on a cement floor during storage witch will conduct electricty and damage the battery If the cells are OK in the battery then start checking the connections to the battery bolth posivite and negitive to the battery . If it worked before storage there is realy no reason it shouldn't work after storage . Also look for mice damage the little bastards will eat anything in the winter including the jackets off your wires so look for signs of then Good luck with it
Jun 06, 2012 | 2004 Chrysler Crossfire
2004 A4 batter dead and cannot access the hood
Insert the key inside door lock and turn the key in counter clockwise direction, in order to manually unlock the driver door.
Please rate my response. Thanks!
May 15, 2010 | 2004 Audi A4
The battery was removed for winter storage. When
Check battery voltage ... if it is not 11.5 or more - replace it.
Apr 11, 2010 | 2003 Suzuki VL 800 Volusia
I attempted to tender my motorcycle battery over the winter but I discovered that it did not stay plugged in all winter. The meter on the tender says it is full charged but when I installed the battery the...
Unfortunately, bike batteries seem to **** out from one season to the next due to material build-up (from vibration) in the bottom of the battery case which causes the cells to discharge even when recharged through the storage period. The meter on your charger (unplugged) is reading battery voltage, but if you turn on the headlight, the voltage would show very low. Try charging the battery at 2 to 4 amps rate overnight (about 6 hours) and see if the battery recovers. If it fails rapidly, get a new battery. Hope this helps!
Mar 19, 2010 | 2008 kawasaki Ninja 250R
I Have a Keeway Supershadow 250, after storing it for the winter, without any preping, the bike wouldn't start, so i jump started it from my car left it run for about an hour but then it just cut out with...
I had the same problem... (what i did is)
- take out the battery,
- clean the dust & dirt from the top of battery
- remove the plastic which seals the battery (yes, the one clearly marked "DO NOT OPEN") but do pay attention not to damage it.
- replenish with distilled water
- charge and after charge check whether the level of distilled water is OK
- put back the plastic seal and close it firmly
mount it .. and have fun ..
Jun 07, 2009 | 2008 Keeway Superlight 125 II
Vetta RT33 Logo
439 people viewed this question
Top Vetta Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Vetta Cycling Expert? Answer questions, earn points and help others
