Question about Datamax DMX I-4308 - label printer - B/W - direct thermal / thermal transfer
Why won't the printer print more than 42 labels in one lot?
Request 70 labels from software program, only prints 42
SOURCE: Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Posted on Feb 12, 2008
SOURCE: printer not lining up and display doesn't work
You can adjust the display contrast by pressing and holding the MENU key for 10 to 20 seconds to modify the LCD contrast level.
SOURCE: Won't print labels
Ended up being the heating settings - they were to low, so when I hit print...it would spit out a label but nothing would be on it.
Problem solved!
Posted on Jun 10, 2008
  • 54 Answers
SOURCE: Regarding Datamax E-4203 - Won't print
Check to see that the label sensor is over the gap in the label. It is just under the head on the right hand side.
You might also have the unit configured incorectly. If you go to the Datamax site, you can download the printer config program, It is easier to use than trying to push the buttons in the correct order to configure the printer.
Also use at least a 6" long label, and print the config file to see if you are set correctly for gap mode if using die cut stock.
Posted on Feb 25, 2009
Nic61
  • 1073 Answers
SOURCE: s there any free software for running Datamax E 4203 Printer? it is meant for printing library barcode labels.
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
Posted on Apr 24, 2009
Zebra 105sl - printer does not print correct size
This sounds like a mismatch between the printer settings in the print driver and the label settings in your label design software.
In the printer driver - printer preferences- set the physical label dimentions.
Also set the printing defaults to the same settings.
In you design program ensure your label size is the same as the printer driver and also you can set the print preferences in the same program, ensure they all match and hey presto it works. But if nt then contact www,lancerlabels.co.uk, they will talk you through the problem on the phone. They will not charge for the advice.
Mar 17, 2013 | Zebra 105SL Thermal Label Printer
Failed to load the print preview or failed to print.
You need to run the Wasp software under an Administrative account or Right click the program Icon and select run as administrator (only need to do this 1 time, not over and over again). Once the program loads, set the label printer again by clicking file at the top left and selecting Setup Label Printer. Select your label printer. Now try printing the labels again.
Jul 19, 2012 | Wasp Technologies Inventory Control...
Cd label print, temp for full disk coverage
download all the utilities in the software that came with your printer. or download from the internet a program cd label printing. surf the internet.
Apr 02, 2012 | Canon Pixma MP800 All-In-One InkJet...
I want to print a label onto a DVD I am burning using my HP6180 All-in-one printer. Does anyone know how i can do it?
Your printer is not printing straight to a DVD, so you will have to buy self adhesive labels, print on them and then stick the label on the disc. Now, it all depends on what software you have available. Your might have software included with the Photosmart printer for CD/DVD label printing, check your installer CD that came with the printer. If you don't, and use Nero for burning DVDs, you may notice it has a label printing software that comes with it. You will need this type of software in order to print a label. If you don't have Nero, or any other label printing software you can try using some of the free ones that are out there, like Disketch 2.11. There's also a lot of free to try label printing software, like Acoustica CD DVD Label Maker which you can use for 15 days for free. If you have Photoshop and you're good using it, then this is another option to consider (you can download templates online).
Using a label printing software is pretty easy, most of them will have templates that you can open and just edit, or you can start with a blank design and add text and pictures to it. When you are finnished put the special label paper in the printer and click print. If you have special DVD labels make sure you specify that in the printing preferences before you print.
Dec 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Labels are printing in reverse
Whereas I do not have this same printer, the problem may be in the printer settings.  Go to your printer settings/properties and select printing preferences.  Select the "finishing" tab and look for "mirror" and see if the box is checked.  If checked, un-check it. If the mirror box is not checked there is a software glitch.  In this instance go to the "control panel" and select printers.  Delete the printer.  Download the most recent driver for your Operating System and re-install the software.
Try another label/envelope program: Avery has free downloads,  MS Word has a big listing of address printing, as does most word processors.  Check open source software such as open office.  Except for Word, there are a lot of free software out there.
If that does cure the problem, there could be a defect in the printer firmware.  Might need repairing or replacing.
Hope this helps.
May 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I-class cutting issues
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Label printers are always finicky. I have strtix printers where I work and they give off wacky errors too.
Sep 19, 2008 | Datamax DMX-I-4212 Label Printer
Dymo label 400 turbo.
THERE MUST BE PROBLEM IN THE INK OF THE PRINTER CHANGE THE INK N U WIL NOT FACE IT AGAIN
May 24, 2008 | Dymo LabelWriter 400 Thermal Printer
Page size for CD printing
I think that the CD/DVD printing ability depends on the software that epson bundles with the printer.
I had the EPSON R200 and i could only print CD's from the EPSON PrintCD software.
May 04, 2008 | Epson Stylus Photo R260 InkJet Printer
Labels
There are many software programs available for printing labels. What type of labels did you plan to print?
I recommend that you check out http://www.onlinelabels.com. You will find a large selection of blank labels ready for printing in your laser or inkjet printer.
They also provide the Maestro Label Designer at no charge to their customers. You can check out the software at the link below.
http://www.onlinelabels.com/maestro
Feb 24, 2008 | HP Photosmart 3210 Printer
Datamax DMX I-4308 - label printer - B/W - direct thermal / thermal transfer Logo
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
pkwc
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
