Question about Rokinon Cameras
How do I remove the card key lock on my Rokinon Fun Flix camera?
On camera mode I can't take pictures until I remove the card key lock
3 Suggested Answers
  • 95 Answers
SOURCE: My Canon A460 says the Card is locked. The lock
back up your data first,thenyou reformat the memory card in the camera.i guess you have formatted the memory card in another device.canon cameras generally do not accept cards that have been formatted in another device.then sitch off the camera and reinsert the memory card.
Posted on Jun 27, 2010
SOURCE: I have saved all my pictures on my computer, but
try this remove SD card from camera, put it into a SD USB converter, use this on the PC and Format the SD card FAT16, this should remove all data. return SD card to camera, the camera may then want to format the card itself, if so this is all OK.
Also ensure that the little protection switch, on the SD card if there, not all have one, is set correctly... toggle it if there.
Posted on Sep 10, 2011
How do i take "protected" (key sign) off pictures? I would like to delete some pictures off my camera. (DZ880)
Theres a button on the back of the camera with the protect sign push it again on that picture it will go away push on push off.
nothings permanent. Goodluck Ozout!
Jul 14, 2014 | Rokinon Cameras
Setting nikon d90
Turn the mode dial to "M". You control the shutter speed by turning the command dial, and you control the aperture by turning the aperture ring on the lens. The camera's exposure meter is shut off and won't help with the exposure. You can shoot a picture and look at it on the display to judge the exposure.
Feb 02, 2014 | Rokinon Cameras
Manual for a rokinon for DZ880
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 03, 2013 | Rokinon DC59 Digital Camera
I have saved all my pictures on my computer, but now the camera is saying the card is locked and I can not delete them from the SD card to clear it. The lock is not on on the SD card, I don't want to...
Sep 10, 2011 | Pentax Optio M50 Digital Camera
How to attach filters to a Rokinon 500mm/ 1000mm Mirror Lens for Canon EOS
For the Rokinon 500mm F/6.3 lens, you can either attach 95mm filters to the front or 34mm filters to the rear of the lens.
For the Rokinon 500mm F/8 lens, you can only attach 30.5mm filters to the rear of the lens.
To attach a filter to the rear of the lens, remove the lens from the camera (or take the rear lens cap off). There's a threaded screw mount just inside of where the lens fits onto the camera. Take your filter and screw it into place. Hand tighten until it's snug and doesn't project in the way---remember, you're going to want to take it off again later.
Jan 15, 2011 | Rokinon 500mm f63 Mirror Lens for Nikon...
How to you get the camera unprotected
It's not the camera, it's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 13, 2011 | Vivitar ViviCam 8025 Digital Camera
When i attach the rokinon 500mm f8.0 to my sony a-350 i get the following message: "no lens attached. shutter is locked." what do i do?
Set the shutter mode to "M" to control all funtionality of camera. NOTE: The Rokinon 500mm f8.0 don't have control of the f-number but is loked on the lenses, is unique. I hope i'm helpfull. ENJOY your lenses! i have the same!
Nov 16, 2009 | Sigma Zoom Normal-Telephoto 50-500mm...
What size of memory card and brand should I get for my new Rokinon E-Touch DZ1000
This camera has SDHC card expandable. With a minimum capacity of 4GB. So that means you can buy 4GB, 8GB ... whatever you budget.
Oct 03, 2009 | Rokinon DC59 Digital Camera
Computer doesn't see disney flix camera
Use a sd card in the flix, for the most part, camera's, phones, if they have a sd card,or memory card, the pc might see the card and load it as a drive, as you said you looked under my computer.
You should also get a cheap sd card reader, a few bucks,$5-6,
this way, if your pc does not see the card, you can put the card into the reader and plug it into the usb port, and import/export all day long. Not sure if this flix can format the card,read your manual,
but always format the card once(new card) with the flix, and never format the card with windows. Hope this helps.
Apr 08, 2009 | Digital Blue Disney Flix Camcorder (White)
Cameras Logo
37 people viewed this question
Top Rokinon Cameras Experts
Terry Leonard
Terry Leonard
Thomas Stauber
Thomas Stauber
Tony Parsons
Tony Parsons
Are you a Rokinon Camera Expert? Answer questions, earn points and help others
