Question about Baby Gear
I need the bracket that hold the carrier to my bike
Need bracket to hook up carrier to bike
www.youtube.com/watch?v=oyMx0eXHVdg
Apr 29, 2015 | Carrier Cycling
Tip
How to Remove and Replace the Bottom Bracket on an Indoor Cycling Bike
Following is a basic guideline of removing and replacing the bottom bracket on an indoor cycling bike. Due to the different brands of indoor cycling bikes and designs for bottom brackets, the following should only be used as a guideline. If any of the information is not exact to the bike being serviced, refer to the service manual or call Sportsmith for further help.
Common Tools Needed:
Phillips Screw Driver
Set of Allen Wrenches (standard and metric)
Bottom Bracket Tool
Cotterless Crank Puller Tool
9/16" Socket
Ratchet Wrench
Pedal Wrench
Crescent Wrench
You will begin by removing the outside belt/chain guard by using either or both the Phillips screw driver and Allen wrenches. It may be necessary to remove the drive side pedal (using the pedal wrench) in order to completely remove the outside belt/chain guard.
Once the belt/chain guard is removed, you will need to remove the belt/chain. If the unit is belt driven, you can simply "walk" the belt off the pulley by pushing the belt to the outside while turning the crank backwards. **CAUTION: PINCH POINT ** If the unit is chain driven, most use a continuous chain that can be "walked" off the sprocket just like the belt. **CAUTION: PINCH POINT ** Some chains may use a connecting link and can be separated at the connecting link to remove the chain. The connecting link is different in appearance from all other chain links.
Now it is time to remove the crank arms. How to Use a Cotterless Crank Puller Tool
It works best to place the bike upside down for best leverage to remove the bottom bracket. (If placing the bike upside down, ensure proper seat adjustment for best bike balance.) Begin removing the bottom bracket from the drive side of the bike. This side has a reverse thread. You will need to turn right to loosen and remove the bottom bracket. Place the teeth of the bottom bracket tool into the teeth of the bottom bracket cup. Using the ratchet wrench or crescent wrench to turn the bottom bracket tool, you will turn right to loosen and remove the bottom bracket. (If removal of the bottom bracket is difficult, it helps to use a crescent wrench in combination with a bolt threaded into the bottom bracket shaft to hold the tool in place while applying pressure to break the bottom bracket loose.) Remove the bottom bracket from the frame. Remove the bottom bracket cup and/or lock ring from the non-drive side of the bike. This is a standard thread. You will turn left to loosen and remove this bottom bracket cup and/or lock ring.
Install the new bottom bracket from the drive side and tighten flush to the frame. Install the bottom bracket cup and/or lock ring to the non-drive side and tighten.
Re-install the crank arms and pedals. Make sure the crank arm bolts are tightened to the proper torque. If unsure of proper torque specs, refer to the equipment service manual or call Sportsmith.
Re-install the belt/chain onto the pulley/sprocket. If belt/chain was "walked" off the pulley for removal, it can be "walked" onto the pulley/sprocket by placing the belt or chain along the bottom of the pulley/sprocket. Carefully, turn the crank arm forward while lifting on the belt/chain. **CAUTION: PINCH POINT ** Continuing turning the crank forward until the belt/chain is in place.
Re-install the outside chain guard and test the unit. Ride the bike without tension and test with tension. Ensure functionality and feel of the ride. Make any adjustments if necessary
Removing and Replacing Bottom Bracket on Indoor Cycling Bike
on Mar 11, 2015 | Exercise & Fitness
Bottom bracket need replaced. needs a new crank set. what size if the bottom bracket and what size crank set is recommended, or does the bottom bracket need to come out to find the size. bought the...
impossible to tell you without knowing the bike brand and model and year, although you have provided that 1999.
If you take into a bike shop, which is the usual place to purchase the parts you need, they will be able to tell you what size Bottom Bracket will fit your bike, also what options you will have for replacement cranks and bottom bracket. This could be a very complicated issue when replacing with parts that are 11-12 years newer, the shop will be best equipped to give you all your options.
Apr 07, 2011 | Cycling
I have a jamis cross country 2.0 bike. the bottom bracket creaks. not sure why.
One or both of your crank arms are probably loose. Try pulling and pushing (pretty hard) on the pedal end of the crank arm (toward the bike and away from the bike) If it's loose, it will be apparent. The arbor of the bottom bracket is usually square on the ends, and this is tapered (the square is bigger closest to the bike) You just need the right size wrench to tighten the nut that holds the crank arm onto the bottom bracket arbor.
Oct 01, 2010 | Cycling
How do I remove the battery from my 2003 XL 1200 HD?
Remove the seat.
On the lefthand side of the bike is a small bracket that holds the battery into place.
Looking directly at the battery compartment you will find a small nut attached to the bracket.
Remove this then remove the bracket.
Carefully take of any chrome covers and store them somewhere safe.
Next ease the battery forward and remove the two bolts attaching the battery to the bike.
Finally lift it out carefully as not to damage the bike.
May 07, 2010 | 2003 Harley Davidson XL 1200 C Sportster...
My bike was sitting for a while before i bought it i wanted to clean up the carbs but cant get them all the way off. i need to know how to remove the throttle and choke lines
Choke cable - The cable nipple attaches to a bracket on the choke shaft, pull on metal end of the cable (where it goes onto the carbs) until the bracket has moved enough to disengage the nipple (hold bracket, release cable & disengage)
Throttle cables - Loosen the cable adjuster at the twist-grip all the way. Next loosen the 4 clamp screws holding the carbs on, disconnect the vacuum hoses, then remove carbs lift them up & disconnect the cable nipples from their holders
Et Voila !
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
Apr 27, 2010 | 1990 Suzuki GSX 600 F (Katana)
Got saddle bags and rigid supports for my 95 intruder and have removed seats, but have no idea how to attach brackets/bag. any help, I'm lost, thanks
if there are bolts holding the rear fender to the frame at the side of the seat (2 on each side), remove these 4 bolts and offer up the saddlebag brackets. the bolts then go through the ends of the brackets and then back into the frame of the bike and then on in to support the rear fender.
It might be an idea to purchase longer bolts as they may not be long enough with the added depth of the saddlebag bracket.
make sure they are tightened up as the bolts also hold the rear fender to the frame of the bike and if the rear fender is allowed to move it will crack the plastic.
hope this helps
Nov 06, 2009 | Suzuki VS 800 Intruder Motorcycles
Bell child seat (carrier)
p100645reg.jpg The top should anchor to the seat post bolt, the bottom two should clamp onto the rear triangle. you should have the seat, a spoke guard, two clamps, and seat post bolt mounting bracket. if you received all the pieces. Hope this is of some help. Ed
Apr 27, 2009 | Bell Sports Deluxe Child Carrier
Is parkway receiver mount bike carrier right for mercedes s320
hi,better to consult your dealer,if your model can fit your bike carrier,dealer have a special equipment manual for every mb model
Mar 22, 2009 | 1999 Mercedes-Benz S-Class
Baby Gear Logo
117 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
