Question about Grandstream GXP2124 4-line Enterprise HD IP Phone
One of our phone stopped working and says that there is no connection when we attempt to make a call. It will not receive any calls and all line lights have turned off.
Our HP Officejet 5600 won't receive faxes.
Here is the answer to your question.
Error code 244 can mean any of the following things: :
1. You or the person sending the fax pressed the STOP key , causing the session to stop before completion.
2. The fax machine on the other end determined that there is an incompatibility with your machine and the one you are sending to and stopped the fax session.
To fix this you can try the following things. Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Make sure the fax machine you are sending to can accept and use polling.
  • Select a slower "receive" speed.
  • Enable or disable the ECM setting.
Error Code: 232
1. Can mean that a communication failure has happened between the two machines.
2. It may also mean that the user of the FAX machine you are sending to has pressed the STOP key
3. If call waiting is enabled, it may cause this error. Disable call waiting on your phone line, if you have a fax machine connected to it. The click or beep on the line that indicates you have a incoming call, can STOP a fax session.
4. Another cause of this error code is that the power was interrupted to the machine you are attempting to send a fax to.
Things you can do to solve this problem: Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Try disableing ECM. However, this may reduce the quality of your faxes.
  • Ask the person you are sending the fax to to set the machine to receive at a slower speed.
  • Try the fax again at a different time, incase it is a problem with the phone line.
  • If you phone lines are old, or there is static on the line it may cause trouble sending a fax.If this is the case you will need to contact your local phone company or whoever is responsible for servicing your phone lines.
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Connecting problems
Is it set to auto receive, is the tel line plug into socket marked line not tel. Is it used on a dedicated line, no extensions, if using ADSL you must have filter on line. If plugging standard phone in place of fax is dial tone heard and line is noise free, can you ring and speak fine on line using a phone. Is machine set to correct dial format for your country ie pulse or tone. When did it stop, have you had storms, phone work done, has it worked on this line before? I take it it copys ok is that correct.
My bet is A noisy phone line or B set to manual answer. More info equels better help, but I am short of free time now..
Feb 02, 2009 | HP LaserJet 2840 All-In-One Printer
My phone does not ring when a call is received
I've found this to be a problem with regular phone lines (POTS) and Uniden phones. Uniden phones do not seem to support 90v @ 20hz ringing voltage / frequency. They work fine in every aspect except for ringing. These phones do work well with voip, where you aren't connected to the telephone company and have calls routed over the internet. The boxes that handle the voip calls generally produce less than 90v and work well w/ Uniden phones.
Dec 18, 2008 | Uniden TRU8885 Digital Answering Machine
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Connecting additional telephones
The only other way around is to fit a double adapter into the phone line socket and plug fax in one and the phone in other, this way both will ring and allow you to make or receive calls on the seperate handset
Sep 07, 2007 | Office Equipment & Supplies
Daily calls
TiVo-powered DVRs will attempt to make the daily call at approximately the same time of day as it was last able to connect successfully. This means that if you set up your DVR initially around 2 PM, or if it failed during an overnight call and retried during the day (and got through one day around 2), it will continue trying at that time every day. You are not able to use the phone line while it connects -- it uses the same type of modem that your computer uses to connect. The good news is that you can indeed reschedule the next attempt, but it's not exactly a setting you can change -- stay up late, and force it to connect manually overnight. If it completes normally, it will make the next attempt the next night at the same time, on its own.
Jun 28, 2007 | Humax T800 TiVo 80-Hours Video Recorder
Lexmark X6150
Make sure the wire from the wall is plugged into the port marked "line" and not "phone". Also try plugging a regular phone into the wall and make sure you can make and receive a call. It could be a phone line problem.
Jun 05, 2007 | Lexmark X6150 All-In-One Laser Printer
Grandstream GXP2124 4-line Enterprise HD IP Phone Logo
249 people viewed this question
Top Grandstream Lands Phones Experts
David Burbee
David Burbee
Are you a Grandstream Lands Phone Expert? Answer questions, earn points and help others
