Question about Air Ride Management 2006-2007 Toyota Yaris, Vitz, Belta, Platz Plug and Play Air Suspension Kit
Transmission oil filling point when you change in a Toyota Belta
When you drain where do you fill oil in a transmission
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 127 Answers
Through the filler plug . Check the owners manual or workshop manual and if ALL FAILS take it to Toyota Service for them to do the job
Posted on Jul 28, 2015
How much cvt transmission oil quantity required for toyot a belta 1000cc
With transmission Oil Filter 3.1 L
Without Oil Filter 2.9 L
Dry Fill 3.4 L
Jul 18, 2017 | Cars & Trucks
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
Changing transmission oil 1991 toy camry
OK auto. In that year the transmission fluid and differential fluid are not joined (although both are ATF), and have different drain plugs and fill points, so you have to identify them. First see here p 30 and p 54.
http://www.turboninjas.com/camry/ax1.pdf
Note the transmission (but not the diff) is filled through the dipstick tube. It is convenient to buy the ATF (Dexron II or similar) in a container with a tube in the cap which will do this easily, or use a long necked funnel. The final check of the correct fluid level in the transmission is done with the engine warm, and RUNNING. Move the shift lever right down to 1 or L, then back up to P, before checking.
Then in a car this age it is worth checking the diff fluid level is OK as well. You may even want to change it at the same time, which is a good idea. It should be level with the bottom edge of the fill hole. Also good is the have a hand pump like this
http://www.tsadvancedsynthetics.com/facts/g2039_banner_600px.jpg
Jan 25, 2013 | 1991 Toyota Camry
How to change oil in standard trasnmission in Ford Ranger 1997
remove the fill plug before you do anything. If you can not remove the fill plug there is no reason to remove the drain plug since you will not be able to fill the transmission once the fluid is drained out.
Once the fill plug is out, remove the drain plug. Let oil drain into a drain pain. Reinstall the drain plug. Fill the transmission with the appropriate fluid until the fluid starts to drain from the fill hole. Reinstall the fill plug. Your good to go.
Jan 16, 2013 | 2004 Dodge Ram 3500 Truck
I have a 2007 toyota 4runner V6. I can't find the transmission fluid dipstick
There is no transmission fluid dipstick!! This model- 2007 4Runner does not have one. It has a fill plug on the side of the transmission itself, near the top. Kind of like what a pumpkin rear end has where you fill it to the top of the plug. Same type of thing. The dealer does not want you messing with the transmission at all. My son accidently drained the Tranny fluid, thinking it was the oil plug. They told me to measure exactly how much was drained, and replace that exact amount of fluid into the fill plug. I had to buy a fluid pump!!! They warned to use only their fluid (Which I found is nothing special) and also to make sure that it was filled with the exact amount.
Dec 03, 2012 | 2007 Toyota 4Runner
Cannot locate position in motor to replace gear box oil; in 1993 5 gear manual toyota celica
  • You don't have a dip stick on this car. You have to go underneath the car and on the transmission you will see two plugs, one on top of the other. The one on top is the fill. The one on the bottom is the drain plug.
  1. To fill it you need a funnel with a hose on it.
  2. Remove the fill plug (top) and fill the transmission just until the gear lube barely seeps out and replug it.
  3. This is now the properly filled.
  4. Plug the fill hole back up.
  1. If you get a container and put it under the drain plug on the transmission and pull the top fill plug FIRST and then the bottom drain plug and let all the gear lube run out.
  2. Now plug the drain hole and fill the transmission till it seeps out.
  3. Now plug the fill hole.
  4. You just did a transmission flush on your vehicle and saved yourself $75usd shop charge.
Regards, Tony
Apr 27, 2011 | 1993 Toyota Celica
Where is the location on a 1994 honda civic ex that i would fill the manual transmission with gear oil?
Manual transmissions have a fill plug and a drain plug on the side of the transmission. The fill plug is a little above the drain plug. Pull the fill plug and fill the transmission until the transmission fluid just barely seeps out and re-plug the transmission. That is the proper way to fill it. You will need a long stem funnel to give you the room you need to fill it. Your transmission requires a 10W30 weight motor oil, just like your engine. If you have a little time and 3 or 4 quarts of oil laying around you can pull the fill plug first and THEN the drain plug and let all the oil drain out. Then plug the transmission and re-fill it with fresh oil and this is a transmission flush for your transmission. You just saved $70 shop charge doing this. I say pull the fill plug first and THEN the drain plug because the last thing you want to do is pull the drain plug first and then find out the fill plug has welded itself and won't come out and now you can't fill the transmission. Fill plug first always.
Regards, Tony
Apr 17, 2011 | 1994 Honda Civic
What maintenace Does a 2003 Toy Rav4 manual transmission need?
The manual transmission oil, or gear box oil can't last forever. It is a good idea to replace every 60K miles with a new one. Just as with motor oil, and oil change is cheap insurance. Buy synthetic oil if you can.
The manual transmission oil change is a simple procedure, but can complicated and creates costly problems.
First remove the filling bolt. In some cases this is siezed, If the heating doesn't help, you don't want a stripped filler bolt, with an empty transmission. Use WD-40 and do not use extensive force.
If the bolt still won't budge. Stop. Lower the car and visit a shop for service.
After removing the filler bolt (upper), then remove the drain bolt at the bottom.
Replace the drain bolt, with a new one, normally has a magnet, and thread it by hand after with a wrench.
Fill the gearbox with oil using a gear oil / lube pump. Replace the filling bolt and process same as with draining bolt.
If you will change the gear box oil every 60K miles this is the best insurance for your manual transmission. DO NOT FORGET TO REPLACE FILLING AND DRAINING BOLTS WITH NEW ONE.
In rare cases a rusty bolt is siezed, almost rust welded in the transmission housing, so the transmission must be removed and taken to a machine shop.
Nov 02, 2010 | 2003 Toyota RAV4
2002 toyota sienna change transmission fluid and
The drain plug is on the bottom of the transmission. Its torqued to 49 nM.
1. Remove tranny oil pan drain plug
2. Drain old fluid (roughly 2-4 quarts)
3. Reinstall drain plug.
4. Measure amount drained in a 99 cent orange juice pitcher from Walmart
5. Pour back the same amount drained using Toyota Type T-IV fluid (available in 1 quart bottles from a Toyota dealer.
6. Start engine and shift slowly through all the gears ending in Park.
7. Check fluid level on the dipstick. Add fluid, if necessary, to bring the level to a point inbetween the COLD and HOT marks on the dipstick.
8. Go for a 20 minute drive and recheck fluid level. Add fluid, if necessary, to bring the level up to,
but not beyond, the upper half of the HOT range on the dipstick.
As in 1973, NO FLUSHING is needed and NO FILTER REPLACEMENT is needed, NO PAN REMOVAL is needed. As, as in 1973 todays Toyotas have a metal mesh filter screen that doesn't ever get clogged except in rare cases of transmission operational abuse, including failure to ever change the fluid for 150,000 miles or more.
Nov 20, 2009 | 2002 Toyota Sienna
How do I change the tranny fluid in my 1998 cadillac catera
Fluid - A/T: Service and Repair
Transmission Fluid and Oil Filter Changing
REMOVAL PROCEDURE
1. Raise and suitably support the vehicle. Refer to Vehicle Lift Points.
2. Place drain pan under pan
3. Remove oil pan bolts from front and sides only.
4. Loosen the rear oil pan bolts approximately four turns.
5. Lightly tap the oil pan with a rubber mallet or pry to drain the fluid from main case.
6. Remove the oil pan bolts from rear oil pan and gasket.
7. Remove front oil pan bolts leaving one corner bolt in loosely.
8. Lightly tap oil pan with rubber mallet or pry to drain fluid.
9. Remove the following remaining components:
^ The front oil pan bolts
^ The oil pan
^ The gasket
10. Remove the oil filter bolts and filter.
11. Clean the following components:
^ The transmission case
^ The front adapter case
^ The oil pan gasket surfaces with solvent
^ Air dry
^ All traces of gasket material must be removed
INSTALLATION PROCEDURE
1. Install the gasket.
2. Install the oil filter.
3. Install the bolts.
^ Tighten the transmission oil filter bolts to 20 Nm (15 ft. lbs.).
NOTICE: Refer to Fastener Notice in Service Precautions.
4. Install the front oil pan.
5. Install the front oil pan gasket
6. Install the front oil pan bolts
^ Tighten the front oil pan bolts to 11 Nm (96 inch lbs.).
7. Install the following components:
^ Install the pan
^ Install the gasket
^ Install the bolts
^ Tighten the oil pan bolts to 11 Nm (96 inch lbs.).
8. Refill the transmission with DEXRON III through oil pan fill plug on the side of the (main case) oil pan. Fill the transmission to lower edge of oil
pan fill. Fill plug opening using and oil suction gun.
^ Tighten the oil pan fill plug to 45 Nm (33 ft. lbs.).
9. Lower the vehicle.
10. Check the transmission fluid level. Refer to Transmission Fluid Checking Procedure.
Sep 13, 2009 | 1998 Cadillac Catera
Air Ride Management 2006-2007 Toyota Yaris, Vitz, Belta, Platz Plug and Play Air Suspension Kit Logo
218 people viewed this question
Top Air Ride Management Air Tools & Compressors Experts
Timllfixit
Andrew Taylor
Andrew Taylor
Are you an Air Ride Management Air Tool and Compressor Expert? Answer questions, earn points and help others
