Question about Krups XP4030 Espresso Machine
Neither water nor steam coming out from never used espresso machine.
I bought older, but never used Espresso Machine. The machine was originally packed. Never taken out from the box. I was trying to run water first. Nothing. Then I read I should descale it. So I unscrewed the brewer filter. This was hard, the screw didn't want to come off. I purr some Cola on it and left overnight. In the morning I was able to unscrew it. I'm trying to run water through it. Nothing. No water No steam. See on YouTube: https://youtu.be/6M0VAdsFjYQ I was trying this: http://www.ehow.com/how_6747977_troubleshoot-valve-krups-espresso-maker.html All of these: http://www.fixya.com/support/t440390-no_water_flow_even_though_descaling And this tip as well: http://www.espressorepair.com/helpful-hints/ Any suggestions? Should I open the machine?
  • 1 more comment
  • Filip Witkowski
    Filip Witkowski May 02, 2015
    I opened part of the machine. I see that water goes to first plastic pipe, but it's not sucked in by the pump. See this YouTube video https://youtu.be/0yiqJzkQiJ8) and attached pictures.
  • Filip Witkowski
    Filip Witkowski May 03, 2015
    Thanks for the tip; however I've tried and nothing.
  • Ross Keen May 03, 2015
    It seems as if the pump valves may be stuck then. Oftentimes once you manage to force some water through the pump it will begin to work. You may need a stronger force than you are able to manage with your mouth. Do everything you can to avoid pulling the pump out, I am fortunate enough to have a decent workshop with an air compressor but I have done the hose and mouth trick in the past.
I was having the same problem after not using the unit for a while. When turned on, the pump would start but, no water flow. I tried blowing water through a tube however that did not work. However I did notice water leaking from bottom of machine. I took the chance of opening the back with removing just 3 screws. I found that the tube connecting to the reservoir (connection on left) had a rip/hole. It takes patience and needle-nose pliers to remove the clamp and hose. I cut the existing tube after the hole and replaced the tube with clamp. Voila the water started to pump through and it worked like new.
Posted on Jan 27, 2016
  • Krups Master
  • 1,231 Answers
From the sound of your You Tube clip the pump is running but it's probably dry and not pumping for some reason. Before I pulled it apart I would try and force some water into the pump. You may find that a piece of garden hose is roughly the right size to engage the tank seal. About a foot of it should be enough, engage the hose, fill it with water, operate the pump like you did in the video and blow as hard as you can into the top of the hose. With sealed lips like you are filling a balloon. If that doesn't work then I think you are doomed and will need to open it up and find where the water stops.
Posted on May 02, 2015
dutchman05
  • 487 Answers
SOURCE: After moving from MI to
OK this is the problem which you see in more machines when not been used for a while.
you will have to prime the machine. As far as I know you can get warm water from this machine too. first decrust the brewing head as that can be one of the problems. if you still have the maintenance booklet it is picture 21 ( i think)
If this one is equiped with the warm water function press the hot water knob and let it run through. If not try to make a cup of espresso with fresh coffee. This should work
Posted on Apr 21, 2008
  • 279 Answers
SOURCE: Krups XP5020 manual
Try Krupsusa.com and click on "instructions" they have it there.
Posted on Sep 18, 2009
SOURCE: No water flow even though descaling
I KEEP having this problem... everything is in place, but no espresso. Nothing comes out the brew head. I have found multiple fixers for it. One: make sure you have water in the tank and that the tank is firmly pressed down (this was the most embarrassing of the mistakes I made), Two: try a slightly courser grind of espresso. On my Black & Decker burr mill, I have it on the 3 (of 12) to finest settings. Tamper only a little bit... not too hard. Three: when the flow is just not happening, try running some steam through the nozzle to see if you can get things moving along. Once I ran the steam through... it sputtered and coughed for a few seconds then steamed normally, then cooled it back down and the espresso came out fine. This was the most recent fix.
Posted on Dec 07, 2009
  • 3 Answers
SOURCE: No espresso coming out.
The problem with the XP4050 is the two safety valves that the water goes trough on its way to the coffee head. They are plastic and some of the parts will just become brittle because of the hot water and the contamination they gather. With my XP4050 they just broke and parts of it were in the rubber tubes that go to the waste tank.They are also very cheaply constructed compared to the more robust parts of this machine. The water to the hot water/steam head does not have these valves and has a completely different routing. I am currently trying to fix the machine with just one valve and parts of the two valves that are still good. Fingers crossed....
Posted on Jul 20, 2010
SOURCE: Recently my Krups 4050 espresso machine starting b...
It needs a new flow meter. I replaced the one in mine and now it works fine. I took the old one apart and the little magnet inside is a ferrite magnet which rusts over time when it comes in contact with water ( duh). If the new one does this I am going to just replace the little magnet with a rare-earth magnet which will cost about $1 or less and shouldn't rust out. I am wondering if the company changed the magnet in the new flow meter so this doesn't happen or if planned obsellesants, just last long enough to get it out of warranty, is the company's motto. The new flow meter was around $30 when the added the $9 for shipping.
Posted on Nov 19, 2011
Sirena Espresso Machine powers on but will not heat up and water not priming
After weeks of trial and error, I have found the solution, to prime the Starbucks Sirena Saeco Espresso Machine (woohoo!!!!!!!!!! ). You do not need to disassemble this machine, it will not heat unless it is prim WARNING: machine must be STONE COLD before attempting this! 1. Get a large syringe (Without a needle of course, I used a 60ml one I bought at a pharmacy for $3.) 2. Fill the water tank full 3. Pull off chrome tip on the steam wand to expose the black plastic jet where steam comes out. 4. Place the tip of the syringe onto the tip of the black plastic steam jet on the machine. 5. Push the power button ON. 6. Turn the steam knob clockwise all the way until the pump starts. 7. Press the syringe onto the jet firmly to seal the connection, and simultaneously draw the plunger out. 8. Quickly, release the seal and eject the air in the syringe out (into open air not into the machine) 9. Repeat steps 7&8 until water draws into the syringe. 10. Go make yourself a cup of coffee and celebrate that you overcame the flaw in this machines design that renders most of them to the rubbish heap.
Jul 12, 2015 | Saeco Starbucks Sirena Espresso Machine
Water is coming through steamer instead of espresso spout
There is something prob scale keeping the steam valve open it needs to be disassembled cleaned and inspected , they can wear out and need replacement
Aug 18, 2014 | Saeco 00034 Incanto Sirius Super Automatic...
Die Cast 800ESXL Espresso Machine: Breville 800 EXL espresso machine pump not working...
I have the same problem. I used my machine for one day to test it when I had it brought into Vietnam then packed it while our house was being built.
Now it won't pump water or produce steam.
To add insult to injury Breville advice "They don't give service manuals to the public"
May 17, 2010 | Breville Die Cast 800ESXL Espresso Machine
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
Can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
No water
I had the same exact problem -- the water basket simply needs to be pushed down harder.
Dec 12, 2008 | Breville ESP8XL Espresso Machine
Wet grounds
What you see is condensed stem comming out and no water. The pump is not sucking from the tank as ther is an air bubble in suction line. Still want coffe and don't want to clean your machine??? Flick up the lever with no group in place. Steam comes first then nothing. Pump is running and - voila - water comes as air bubble is gone. (Specially the first cup , never the following ones.) Now put back the group and brew your espresso. The machine is full of scale and neds total clean - by hand./// Olev
Jun 13, 2008 | ECM Giotto Espresso Machine
Just bought the Saecco Incanto s-class de luxe machine
lol there is a water button on it. Press that first and than turn the steam knob
Mar 19, 2008 | Saeco Incanto Classic Espresso Machine
Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
Krups XP4030 Espresso Machine Logo
346 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
