Question about Singer Sewing Machines
I need to see a diagram for a Singer 368 bobbin case
  • Singer Master
  • 638 Answers
When you get to this web site just type in Singer 368 bobbin case and the picture will pop up.
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
Posted on Apr 30, 2015
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 4 Answers
SOURCE: Replaced Singer 5932 bobbin case, need help. *pics*
there may be uneeded friction occuring. are you sure you inserted it correctly? sorry. photos aren;t appearing. but it may be that it is the wrong type or in the wrong place. do some trial and error and fit it into different positions on the bobbin runner
Posted on May 11, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
chrismyers67
  • 53 Answers
SOURCE: how do i replace the bobbin case in singer machine
When you insert the bobbin case, make sure the "knub" on the bobbin case (#1) is just to the left of the position finger bracket (#2). It should sit in there nicely and you should be able to spin the hand wheel freely.
Let me know if you need more help,
Chris
Posted on Jun 07, 2010
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
Diagram of bobbin casing for singer 1036 creative touch?
Try a brand new needle and verify it is installed correctly. Rethread the machine, top & bottom.
If the machine continues to miss the bobbin thread, most likely the timing is off. Search for sewing machine timing or take it for service.
Singer 1036 parts diagram Google Search
May 25, 2017 | Singer Sewing Machines
Singer 9420 bobbin case diagram
http://www.singerco.com/uploads/download/452_5_8_10_16_22_dial.pdf is the manual for the machine. The bobbin case is a single piece, and looks like: http://www.sewingpartsonline.com/bobbin-case-body-singer-383913-901.aspx?gclid=COqlw9-9yL4CFQqPfgodiC8A6g I don't know of a diagram of it.
Dec 22, 2013 | Necchi Sewing Machines
Could you check to see if that is the correct model number? I cannot find anything on a Singer 9420.
Dec 22, 2013 | Singer Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
Jun 09, 2012 | White Sewing Sewing Machines
My singer futura ce100 bobbin case (the metal part that actually holds the bobbin) keeps popping out. I do not know how to put it back in correctly in the seat. There is no diagram anywhere for that. It...
It may be that the silver square object in front of it is to tight. I had this happen and I loosened that up with small screwdriver and put bobbin case back in and it helped. Had to play with it for a while. Or It may be that the bobbin case has chip out and need to replace that.
Aug 12, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a Singer model 4562 T sewing machine, and threading the bobbin, the bobbin case just kind of popped out. I've tried just sliding it back in, but no matter which way I put it in it doesn't seem to...
The bobbin case is designed to be removed for cleaning. Take off the needle plate if it is still on the sewing machine. Make sure that the needle and presser foot are fully up. Guide the forked end of the bobbin case under the feed (more or less centered). Then pull the bobbin case under the rim of the position plate. Pull on the side opposite the forked end of the bobbin case. With a small screw driver, turn the lever (at about 10 o'clock on a 12-hour analog clock) towards you. This will lock the bobbin case into place. Make sure that the bobbin case isn't locked too tightly. It still needs to move slightly as the bobbin turns and the needle comes through that plate.
Replace the needle plate and lock it down. Then insert the bobbin and close the slide plate. The manual shows the procedure to remove and replace the bobbin case on the 4562 on page 39. Singer has the manual on the support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/435_5_8_10_16_22_dial.pdf .
I hope this helps.
(I hope that the locking lever hasn't broken. That may require a service person to solve the problem. I'm not entirely sure where that lever is connected to the machine. Some Singer part diagrams are here: http://www.singerco.com/support/replacement-parts-chart . The 4562 may use the same diagram as the 4572, http://parts.singerco.com/CPpartCharts/4_4999/4572.pdf .)
Jul 01, 2017 | Singer Sewing Machines
How do I replace the bobbin case in singer machine 7442. The manual diagram is minimal and I replace it incorrectly and just got it out after several attempts. Can't seem to get it aligned proper;u
Chris
Jun 07, 2010 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
64 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
