Question about Electrical Supplies
Is this dimmer compatible with Cree LED bulbs?
  • 3 Answers
Hi - I have tested Varilight Pro dimmer modules such as Varilight Pro LED Dimmer Switch module which can be used as a trailing edge or leading edge dimmer so will work with most LED bulbs. Just one thing to note is that they work with a minimum load of 10 watts or 1 lamp all the way up to 100 watts or 10 lamps.
Posted on Sep 30, 2015
2 Suggested Answers
  • 3287 Answers
SOURCE: DOES THIS DIMMER WORK WITH LED LIGHT BULB
It's not quite that simple..
According to the manual for your switch, it is stated "Use with magnetic low-voltage transformers, incandescent, or 120V halogen fixtures only." Also, there is a minimum load of 40W or 40VA. Your LED lamp load will need to satisfy BOTH of these requirements. Electronic circuits are not to be "dimmed" with this dimmer - but use of either the VZE04-1L (400W max) or VZE06-1L (600W max) is supported.
You will need to provide the manufacturer and model number of the LED lamp(s) to be dimmed by this switch. Or, you can use traditional dimmers (if desired) with LED lamps that are specifically labeled as "dimmable" on their packaging.
Once the lamp model is known it will be possible to learn about their dimability assuming that they are not cheap imports with no real customer support contacts. Name brand lamps will have this support, and you can even call them yourself and inquire directly about the suitability to task for the dimmer. If the lam company doesn't know about the switch, contact Leviton with the lamp info at Customer Service: 1-800-323-8920 • FAX: 1-800-832-9538 Tech Line: 1-800-824-3005
Posted on May 14, 2012
How to disassemble a zoom focus flashlight
Ultrafire/CREE XML XM-L T6 LED 1600LM Flashlight Torch ...
? 27:39
https://www.youtube.com/watch?v=lsPdC-xgxTU
Oct 15, 2013 - Uploaded by Richard Lloyd
Here is a link to this CREE XML XM-L T6 LED 1600LM flashlightat ... 1600LM Flashlight Torch Lumen Zoomable Review/Disassembly/Mod.
CREE Flashlight - How to Fix Frequent Problems - YouTube
? 8:04
https://www.youtube.com/watch?v=zJpQAvum0bM
Dec 21, 2010 - Uploaded by motorbiking
How to repair your flashlight if the LED stops working, if it changes mo... ... Mini Cree Led Q5 Ultrafire Flashlight Torch Adjustable Focus Zoom ...
Disassemble HausBell CREE Flashlight (replace battery ...
Jan 19, 2016 | Cameras
Must I replace its 100 watt Sylvania incandescent bulb with another incandescent? What about an equivalent CFL or LED bulb?
Both will work fine as long as the light isn't on a dimmer. You can't dim CFL bulbs.
If you do have a dimmer, you can dim LED bulbs as long is you buy dimmable LED bulbs.
Which LED bulbs are best for built in dimmers CNET
Dec 29, 2015 | Minka Concept II Flush 44 Ceiling Fan by...
Can I use a dimmer switch with light bulbs whose packaging makes no mention of whether or not the bulb is "dimmable"? (be they incandescent, CFL or LED)
Most old dimmer switches do not work with energy saving/led bulbs, they will work fine with the old style filament bulbs, the newer dimmer switches will be compatible with energy saving bulbs and will indicate on the packaging!
Dec 27, 2014 | Electrical Supplies
I recently installed a lutron skylark dimmer w compatible gu24 bulbs on a 3 way connection. Everything works properly but the bulbs only dim slightly, is this normal or is something defective or improperly...
Are you using compact fluorescent? Are you sure you purchased a dimmer that is for incondescent lighting only? fluorescent lighting only? Fan motor control only? Are your lights led? I read on the instructions for one company that you can only use one dimmer on any one 3 way system. Did you put 2 dimmers on a 3 way system?
Aug 11, 2013 | Electrical Supplies
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
Dimmer to operate a single CREE LR6 LED fixtur
Simply Automated Dimmers drive standard AC loads as low as 1 watt. The work GREAT for CREE LED fixtures.
Nov 13, 2008 | Dryers
Electrical Supplies Logo
1,228 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
