Question about Coffee Makers & Espresso Machines
Is it leaking water because of a broken thermostat?
  • Coffee Maker... Master
  • 1,267 Answers
A thermostat if broken would probably prevent the boiler from heating, unlikely to cause a leak though.
For a more informed answer try us with a brand and model, we are running blind on this side.
Posted on Apr 30, 2015
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Nov 25, 2012 | Rheem Water Heaters
I have a 98 grand marquis it keeps overheating I changed my radiator,thermostat and intake manifold the car will drive well then start to overheat and once it overheats all the antifreeze will leak out
This could be a broken head gasket, cracked head or block.
Pull the thermostat back out and you should be able to see water flow through the radiator. Make sure the water pump is working.
Were does the antifreeze leak from?
Sep 08, 2011 | 1998 Mercury Grand Marquis
The bottom heating element keeps blowing breaker and bottom of heater is filling up with water around heating element
If there is enough water around element and lower thermostat, it's going to blow the breaker. If you don't have leaks at the pipes above, it's probably time to replace the heater. If the leak can be found and repaired, there may be hope for the heater but, if it is leaking past thermostat, you probably have a crack in the threads. Make sure, if your going to work with the wiring of the unit, that it is turned off and, if it is on, make sure you're careful and not standing in water. You could quite possibly have a cracke or broken tank.
Jun 25, 2011 | Rheem Water Heaters
Engine keeps overheating
I'd start with replacing thermostat (that's the most common fault) Other possibilities; waterpump,leaky hose, radiator cap (not holding pressure), fan belt broken. I'd inspect for belt & leaks - if good replace thermostat.
Feb 28, 2011 | 1998 Cadillac DeVille
Where is the thermostat located on a 3.0 liter engine? Don't know if the water, pump or thermostat is leaking.
Follow the top radiator hose back to the engine. There is where the t-stat housing is.
If the thermostat is broken in the closed position the engine would overheat rapidly. If it was broken in the open position the engine cooling system would not reach normal operating temperature and the heater would produce only warm air.
Take the thermostat out and put it in a pan of water on the stove. When the water gets to around 200 deg F, the thermostat should open. If it doesn't it needs replaced. Observe carefully that you have not installed the thermostat upsidedown. Spring-side to the engine
May 13, 2010 | 1998 Ford Windstar
Car overheated alot of water leaking out the
First find exactly where the water comes from.
broken hose or hole in radiator - if no leaks here then :-
broken / loose drive belt to water pump - sign is no heat to internal heater
thermostat stuck - heats up and overheats quickly. water from exits rad cap area
also check radiator cap - should be sprung to contain water under pressure, usually these are very reliable
check oil filler cap [inside of] - should be oily and grey/black If it has a covering of what looks like soft brown aireated jelly then possibly hear gasket or other internal engine leak between water & oil ways. The excess pressure from engine will force water out of rad cap area . A compression test with variable readings for between cylinders will confirm this. Hope its not this. It's expensive
Sep 07, 2009 | 1999 Oldsmobile Intrigue
Car is overheating
2 Inspect Belt Incorrectly routed, adjusted, tensioned, missing, or worn water pump belt(s). grey_line.gif 3 Inspect Oil Pan Gasket - Performance Ruptured, cracked or leaking radiator hose. grey_line.gif 4 Inspect Radiator Cap Worn or damaged radiator cap grey_line.gif 5 Inspect Thermostat Thermostat stuck closed grey_line.gif 6 Inspect Fan Blade Broken, missing, or defective fan blade(s). grey_line.gif 8 Inspect Water Pump Damaged, worn or leaking water pump. grey_line.gif 9 Inspect Intake Manifold Plenum - Perform Leaking water pump gasket. grey_line.gif 10 Inspect Cooling Fan Control Faulty cooling fan control or circuit. grey_line.gif 11 Inspect Cooling Fan Switch - Radiator Faulty radiator cooling fan switch or circuit. grey_line.gif 12 Inspect Engine Temperature Sensor Faulty engine temperature sensor or circuit. grey_line.gif 13 Inspect Temperature Switch Damaged or faulty temperature switch or temperature switch circuit. grey_line.gif 14 Inspect Fan Clutch Worn, loose or faulty fan clutch. grey_line.gif 15 Inspect Ported Vacuum Switch Damaged, leaking, or faulty ported vacuum switch. grey_line.gif 16 Inspect Radiator Obstructed radiator core or radiator cooling fins. grey_line.gif 17 Inspect Head Gasket - Performance Head gasket leaking coolant into cylinders here is a list of things to check Shaun
Nov 17, 2008 | 2000 Cadillac DeVille
1997chevy expresss van leaking water pump and intake gasket leak
you need get the water pump change. seal broken and it is probably stop working.
check the thermostat when you at it. it probably need change too.
Nov 12, 2008 | 1997 Chevrolet Express
Coffee Makers & Espresso Machines Logo
56 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
