Question about Boating
Will the 145843 work with my Datamarine CW360?
My transducer needs some repair and if this would replace it that would be better.
How to repair
Is the buglight still working? I simply take a blade of grass and place in between the wire cages to make electrical connection and verify transducer is not defective. If you don't get a spark quickly your transducer may be burned out as I cannot keep one working due to larger insect getting in unit and overloading the transducer.
May 22, 2014 | Stinger 1 Acre Bug Zapper
How do i replace shift silinoid in a automatic trans
Shift solonoids are internal and require pan removal
Nov 28, 2012 | 1993 Dodge Dakota
Speedo cuts out
Transducer, no that is not part of the system. Have the system fault codes run with a scanner if no codes are present then the speedo is defective and you will need to remove it and send it out for repair.
Sep 27, 2012 | Cars & Trucks
Transducer is throwing up a large Rooster tail.I installed it to instructions
Might help to tell us what kind of boat - deep V hull 22 ft.? bass boat with shallow V hull? Some need the transducer closer to the centerline of the vessel while others do better more outboard, Naturally they need to be flush with the hull no matter where they are located. Depending on the transducer, you could also try properly mounting it inside the vessel near the transom. Good new is you are getting good info from it. Cheers Pete
Nov 16, 2017 | Humminbird 586c
I want to see the schematic diagram of humminbird fish finder transducer, my fishfinder won't operate. if i plug another unit of transducer, the my fishfinder operates normally.
Hi Greg and Ernesto:
Re-stating the obvious, your transducer is not working but you know that the sounder is.
I would start by checking to see if your transducer works on a different sounder. That's just a double check to confirm that it really is not working.
Then I'd try to isolate the problem:
- Plug (couold be corroded or damaged)
- wire (could be broken)
- Transducer (could be defective)
Since these are sealed units, I'd be checking with the supplier to try to find a replacement. Hopefully they are not too expensive, and time spent fishing is better than trying to maybe save a few dollars, especially if you're taking out charters.
Best of luck.
Sep 01, 2010 | Humminbird Fishfinder 525 406260 1
MY RAYMARINE A65 CHART PLOTTER/ FISHFINDER HAS NOT BEEN WORKING , THE CHARTPLOTTER WORKS FINE , BUT THE FISH FINDER WONT PULL UP BOTTOM OR ANYTHING . I LOOKED AT THE LITTLE BOX THAT CONNECTS TO THE...
Likely your DSM25 (that little box that connects the transducer to the display) will need to be rebuilt. The red LED is saying that there is an internal fault with the unit. You would need to send the unit in for repair through Raymarine (as there really is not anyone else who can do it), and they would have to replace the main circuit card in the box. I believe that they are charging either $150 or $175 to repair those now... but likely the only way you will get that one to work again.
Jul 27, 2010 | Raymarine A65 Combo GPS...
My marine speed transducer needs to be replaced. I have a Beneteua 351 which is 16 years old. I have cleaned the transducer several times and then reinstalled. It will work for a couple of minutes and then...
Yes. You need to make sure you get the same transducer though. With you system being that old, you may have a transducer that is old where there is not a direct replacement. You need to make sure you get the correct transducer. You may need to get a "flapper" kit to update your housing to the new style.
Jun 15, 2010 | Raymarine St300/P371 Speed Nylon Thru Hull...
Lowrance X-136DF Fishfinder Not working
Hello Keneth,
Is The transducer In Side the Hull Or Mounted On The Transom?
If Inside Remove It And Re Fit It Using Epoxy Glue Ensuring No Air Pocket Between transducer And Hull.
If transom Mounted Replace Transducer.
Hope this Helps
Gordy
Nov 30, 2017 | Lowrance X136df Fishfinder With Dual...
Water temp is not working can that be fixed?
Double check you have a good connection from the transducer data cable to the back of the display unit and that the pins are not corroded or anything similar. If the temp has never worked at all, it may be because the transducer you are using doesnt have a temperature sensor onboard and you will need to get one that does have this feature. If it did work previously and you checked the pins/connection (as per above) then the transducer is faulty or has developed a fault. There is no real easy fix and it will most likely be far cheaper just to buy a new transducer than to have the current one repaired by Eagle. I think new trasnducers are about $60-$70.
Mar 30, 2010 | Eagle Fishmark 320 Portable Fishfinder
Depth finder problem
The problem is not so much the flat bottom, although they are prone to this problem. The way the sonic waves have to travel through the water is affected by turbulence, especially by air bubbles and cavitation, and by the transducer actually leaving the water, which happens frequently on flat bottomed boats. The best solution to this is to have the unit mounted through the hull so it is completely flush with the hull surface - often they are mounted with a surface flange on the outside of the hull which although thin still causes cavitation around the transducer at higher speeds. about 14 knots will usually interfere with the accuracy of the readings on most hull shapes - forward looking sonars perform usually better. Another thing to check is that the transducer is actually seating right in the housing, if it is not flush with the flange then you have problems - even half a millimetre is too much. check no muppet has painted the transducer with antifouling paint - that never helps, also check if there is a build up of marine growth on or near the transducer - a smooth hull will always keep your depth working until a higher boat speed. if the transducer is growing stuff itself then gently scrape it off - be really careful not to scratch the surface. There are now available non-sonic depth sounders, especially ulf radio signal devices, but I have heard no good reports about them, last i saw they were very expensive and maybe they experience other problems at high speed. there also have been towed devices available that may suit your needs better, although probably a lot of trouble in shallow waters. If you can borrow a waterproof video camera, you could mount it behind (not too close) the transducer, this would be a pain to do, but it may give you an insight into what part of the hull if any is causing the problem (tie the camera to the top of the boat securely in case the mount fails) Hope this helps, sorry but your dealer is not totally wrong :)
Sep 25, 2006 | Lowrance M68C GPS Receiver
Boating Logo
91 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
