Why does flame roll out of the burner chamber when gas to the burners is stopped?
  • Cris Allen May 01, 2015
    Additional Comments as Requested to help analyse the problem with my natural gas, forced air furnas, Carrier Mdl 58GS100-2, series 203, is 25 or so years old. Burners are in good condition. However, as the burners are shut off you can hear and see the boom of combustion and the flash of flames from across the room. These flames roll out of the combustion chamber and up a few inches. Thank you for your help.
    Top Expert:
  • Heating & Co... Master
  • 42,712 Answers
The fire is held clear of the jet by the fact that the gas is coming out too fast for the flame to burn back to the jet
when you turn the gas off then the flame burns back all of the residual gas
Best have it checked out by an accredited gas mechanic.
Posted on May 02, 2015
Buffalo12980
  • 625 Answers
SOURCE: Medallion Vermont Casting model CF9080
sounds like the regulator. there isn't much of anything left to go wrong! the gas comes out of a very small orifice in the burner tube and mixes with atmospheric air before being burned at the jet.
Posted on Feb 03, 2008
burzerko
  • 254 Answers
SOURCE: portable radiant convector heater -burner slightly faulty
you probably need to adjust the primary air mixture. There should be shutters on the front of the burner assy. If this does not correct the problem you may have dirty burners themselves. you could remove the burners and drag a wire brush across them to clean. but do not drills the openings unless you use a r&m bit
Posted on May 30, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Empire DV-35 low heat low flame
Check your gas pressure, You could have a gas valve problem or you could have a restriction in the air intake.
Posted on Sep 09, 2009
  • 12173 Answers
SOURCE: Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
Posted on May 31, 2010
SOURCE: Goodman down draft Gas furnace, red led flashes 6
Hello Try looking for a tiny TAN colored (button) near the front of the burner rack.It will have a wire in & out of it.In the middle there is a small tab/button.Push that in you will hear a click.That is the rollout switch.Check the vent/exaust pipe for blockage/draft to determine the cause of the switch tripping.The switch is a SAFTEY and repeated trips means there is a problem.
Posted on Sep 08, 2010
Oven sounds like a jet engine
I can't help much...
When a gas burner sounds like a jet engine the chances are the gas is burning inside the mixing chamber.
The gas jet directs the gas into a mixing chamber where it is mixed with the correct quantity of air before being emitted from the burner where it produces those nice blue flames. Sometimes, for a reason I don't know, ignition will cause the flame front to pass through the holes in the burner into the mixing chamber and the jet engine sound is heard. There will still be some flames from the burner but they will be weak and anaemic.
The problem used to be very common in the days of coal gas but it has almost disappeared with the use of methane.
I suggest you remove the burner and ensure it is clean inside and out and is a good and close fit against the gas jet and there is nothing restricting the air inlet of the mixing chamber.
Apr 22, 2017 | Magic Chef Ovens
Propane heater burner has flames coming out the side heating chamber
This points to 2 things blocked burners ,or blocked heat exchanger eithe rway this should be turned off now ! and get a gas fitter to look at this as this would give off fumes .
Jan 30, 2013 | Dayton Heating & Cooling
The gas flame on my 4 burner Chambers stove top is very high. How do I adjust it?
Now That the range operates like new, learn to use it. Don't die.
Jul 06, 2017 | Kitchen Ranges
Ge gas range oven burner flames perfect, broiler flames rolling & orange
Anytime the flames on a burner aren't blue or "perfect" as you say... it means that there is an improper mixture of gas to air ratio... this is usually caused by either and obstruction..such as spider etc or grease... and is almost always the problem is located at the venture which is where air and the gas come together...try blowing that burner out real good with compressed air.
OR the same problem in mixture happens when the burner is wore out..corrosion causing the holes to enlarge or close up... in that case you need a new burner.
So I would "clean the fire out of it" and check for obstructions and corrosion
Hope this helps
Jun 22, 2012 | GE Kitchen Ranges
Water heater goes out
The burner needs to be adjusted
Mar 13, 2017 | Water Heaters
I HAVE A BRAND NEW LF24-75A HEATER WITH LP KIT INSTALLED AND WHEN WENT TO START UP UNIT THE LAST BURNER IS ROLLING OUT WHITCH IS CAUSING NOT TO SENSE A FLAME. WHAT WOULD CAUSE THAT?
roll out from a burner chamber would be caused by a blockage or crack. the crack would only roll out when the heated air fan comes on. and then 1 more thing.if they forgot to install the orifice you could be dumping to much gas into that chamber
Feb 07, 2011 | Heating & Cooling
Burner lights. Flame pulls away from burner and sensor. Unit shuts off
The first thing I would do is check burners to make sure they are clean. Often if rust particles or carbonsoot come loose from inside of the heat exchanger they can partially clog burner opening which causes increase in gas pressure to fewer ports.This can make the flame roll out of burner compartment shutting off flame rollout switch.With burners off turn thermostat down so that furnace won't come on and inspect burners. If they are dirty you can use shop vac with crevice tool to clean most of them. If needed the burners can be removed for cleaning. Usually all you have to do is raise up on the back end of burner and slide it backwards to clear air shutter and burner orifices and then remove. Clean one at a time and put them back in the same position they were in.When they are all back in furnace reset flame rollout and check furnace.
If burners are not dirty then I would have service tech. check gas pressure and repair as needed. Hope this helps you. Thanks
Dec 14, 2010 | Honeywell Heating & Cooling
Flame rollout sensor keeps tripping
sounds like your burners need to be cleaned, you will need to pull them out and clean the rust out of them. the rust builds up on top of the burners and when you gas valve opens and fills the burners full of gas you will have a roll out of flames. hope that helps.
Dec 30, 2008 | Heating & Cooling
Adjusting goodman propane burners
Yellow flame can also mean inadequate gas pressure. Do you have a manometer? If not, call your gas company for a check.
Oct 09, 2008 | Goodman GMS90703BXA Heater
Flame backlash
The burners have an adjustable vent in the front that may have been moved. Also the vent pipe may be inadequate, that is why the roll out switch that you by-passed tripped. If you replace the switch that was by-passed I bet the over flaming stops,as the gas will quit overflowing. Most of these switches have a little reset button on them so look at it next time before you by-pass the wires.
Jan 05, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
153 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
