Question about Samsung DVD-VR357
Why does it have no power?
Can it be repaired?
Where can I get repair on a Rascal Little Rascal made by Electric Mobility
  • Mobility Scooters - Parts and Repair - US Medical Supplies www.usmedicalsupplies.com > Parts and Repair - Table of Contents Learn more about the parts and components of your electric mobility scooter, and get troubleshooting tips and maintenance guidelines for getting the most out of your ...
  • Wheelchair and Scooter Repair - Nationwide In-Home Repairs wsrsolutions.com In-Home Wheelchair and Scooter Repair. Wheelchair and Scooter Repair™ (WSR) is a nationally accredited repair company with an A+ rating from the Better Business Bureau.
  • Mobility Products - Electric Scooters Power Chairs and ... www.electricmobility.co.uk A bit about us... Welcome to Electric Mobility Euro Limited. If you are thinking of buying, or already own an electric scooter, power chair or riser-recliner, then ...
  • Mobility Scooter Repairs, Servicing & Maintenance mobilityrepairsuk.com Mobility scooter repairs Nationwide. We are the U.Kb s most trusted servicing, repair and maintenance provider also offering insurance, warranty and mobility scooter ...
  • Power Chair Repairs & Electric Mobility Chair Repairs www.mobilityrepairsuk.com/power-chair-repairs.html We provide nationwide power chair repair. Our onsite mobility chair repairs and electric wheel chair repairs are guaranteed.
  • Electric Wheelchair Repairs - In Motion Services www.inmotionservices.ca/#!electric-wheelchair-repairs/cmmz We will happily repair mobility scooters, powered and non powered wheelchairs, and any other home healthcare equipment that needs servicing.
  • Sales, Servicing and Repairs of Mobility Scooters ... www.mobility-services.co.uk Servicing and repairs of mobility scooters, wheelchairs and stairlifts from RB Mobility. Friendly, fully guaranteed, door to door service call 01923 710055
  • Service Repair Shop Technician for Mobility Scooter, Power ... www.easymedonline.com/service-power-wheelchairs-and-scooters Service and Repair for Mobility Scooters, Electric Wheelchairs, Recliner Lift Chairs ... If you need to locate a repair shop / technician near you click here...
  • Sidney Scooters, Scooter Rentals, Scooter Repairs, Sidney BC sidneyscooters.ca Sidney Scooters is a specialized dealer of electric mobility products. Our purpose is to help customers achieve greater freedom and independence.
  • Mar 04, 2016 | Electric Mobility Health & Beauty
    No power no light
    check cord for damage, while plugged try wiggling wire in different locations and watch for power, if you see power replace cord, if no power replace machine
    press the helpful button and check links below
    Drip Coffee Maker Problems HowStuffWorks
    How to Repair Coffee Maker How to Repair Small Appliances Tips and...
    Coffee Maker Repair How to Repair Small Appliances
    Jan 30, 2016 | Coffee Makers & Espresso Machines
    Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
    Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
    www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
    ShopJimmy
    $19.94 - ‎In stock
    This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
    Common TV Repair for Emerson, Sylvania, Philips ...
    ? 5:35
    https://www.youtube.com/watch?v=nQHWrJJg4Mc
    Oct 11, 2013 - Uploaded by Tampatec
    ... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
    What Causes a Blown Fuse in TV Sylvania LCD - YouTube
    ? 15:31
    https://www.youtube.com/watch?v=4P_0aLDZgBY
    Jan 01, 2016 | Televison & Video
    Dell stuck in power safe mode
    A blinking power light is not indicating power safe mode, it indicates a failure of the power supply board in the monitor. Here is a link to repair guides that show how to open and repair the power supply boards in the Dell E173 series of monitors;
    http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/
    I hope this helps,
    Apr 08, 2012 | Dell E173FP 17" LCD Monitor
    Hi I got PMP3000 and all of a sudden in the program smoke came out of the unit and I unplugged the Mixer...I have given it to repair and they saying the Main power SMPS has blown out..they charging too...
    Sorry... you likely have one of the power amp channels bad as well. One does NOT replace the power supply, instead repair it. You need a competent repair shop. I can tell you what parts are blown on the supply. They cost about $30 max for parts to repair the power supply. There usually is about $15 of parts blown on the amp that caused the problem and significant labor to repair the amp portion. If the smoke was dark or heavy, it was likely from the 0.03 ohm metering resistor on the bottom of the amp circuit board that caused the original problem. If one replaces the power supply and turns power on they will find one side of the amp doesn't work and MAY blow the power supply again immediately. I have repaired several of these units and have walked others through the repair sequence as well. You can contact me directly by email for more info if you need it. Unless you can find a competent repair shop that replaces components, including work on surface mounted boards, the cost of the module parts AND availability will preclude repair. The amp module is another $155 after the power supply is repaired if a channel is bad and one chooses to replace rather than repair.
    Apr 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
    I was presented a 32"
    The power supply board is repairing right the tv should work find and a external power surge protector,will protect it from a power surges in ur home.The repair warrenty,should cover u at leat 6 moths and $300 is a fair price,if extended the life of the tv power supply board for a few years.
    Dec 02, 2010 | SVA-USA HD4208TIIIBU 42 in. HD-Ready...
    Replaced my lamp, when i push power it powers up for a few seconds then shuts off and the red lamp button comes on again.. wd 62725
    Thats usually caused by failed capacitors on the Power board. The mitsubishi repair kit called the V26 Chassis DLP DM / Power repair kit will often repair that. Its available from www.tvrepairworld.com and contains the capacitors and the CD with repair instructions.
    Nov 05, 2010 | Mitsubishi WD-62725 62" Rear Projection...
    Psp spot repair in mumbai :- 9819767710/9867635653 ?
    what was that????don't u have any better prob. to ask.....
    Jan 23, 2009 | Microsoft Xbox 360 Console
    AC adaptor for 32 inch Protron TV
    It seems a lot of people are having problems with the Protron power supply. I’ve been able to repair all the ones I’ve seen so I’m confident I can fix them. I don’t sell the replacement power supply but I’ve heard about the ones on EBay. They seem to be a mishmash of two power supplies (12vdc and 24vdc) wired together with the proper connector. This should work but it just doesn’t sound very clean looking to me and they end up costing $150.
    I’ve been charging between $50 and $100 to repair these power supplies. My recommendation would be to send me the power supply I’ll check it out and unless it’s unusually damaged it will cost $50 plus shipping to repair. If I can’t repair it I’ll return ship it and only charge for shipping.
    I will guarantee the repair for 1 month. I don’t know what’s causing the power supplies to fail so I can’t guarantee it any longer than that. My feeling about the reason the Protron power supply stops working is two part; could be overheating due to lack of proper ventilation to the power supply; or the TVs power requirement is overdriving the power supply.
    Feel free to contact me if you have any questions.
    I repair these at my work, so here’s the shipping address:
    Dave Simpson
    23372 South Pointe Dr.
    Ste. B
    Laguna Hills, CA 92653
    Also, I’m set up for PayPal.
    dave@thola.com
    Sep 10, 2008 | Protron PLTV-32 Television
    Samsung DVD-VR357 Logo
    57 people viewed this question
    Henry  Thomas
    Henry Thomas
