Question about Cycling
Where can I get Kulana Opala bike info? - Cycling
Gs140341992 bike frame cooler not known. Make and model
It's impossible to give you any info on a bike with only a serial number. In most cases the only info available IF you know the make is the year it was made. The make and model are on the bike - if they're gone then it does not matter. For more info see my tip: How to determine the year value etc of your bicycle
Aug 30, 2017 | Schwinn Cycling
I have a ralegh bike and it has 3836 stamped on it what year is the bike ?
Too little info. What number of speeds, model name on bike, other decals, picture, etc. Don't get your hopes up for value. For more info see my tip:
May 30, 2017 | Cycling
I need an owners manual for a kulana tandem bike
Bicycle owner's manuals are usually quite generic and consist mainly of safety warnings and basic info that you can get anywhere, but your best chance is to contact a retailer that sells them (Walmart, etc.). Just Google "Kulana tandem"
May 09, 2017 | Kulana Cycling
Friend has an old Mongoose BMX bike FC1F266612 any info? such as year? Thanks
Google "Mongoose serial number" - the same thing anyone here would have to do, as there is no central database for bike serial numbers. Other than your own curiosity it's not important to know what year it is. Also, please note that when asking for "any info" it is helpful to give some info, such as a model name, what type of equipment, picture of bike, etc.
Apr 25, 2017 | Mongoose Cycling
How do I adjust the seat on Kulana Riviera 26" Ladies bike. It's too low.
There's a bolt near where the seat post goes into the frame. Loosen the nut, raise the seat (careful to note the max insertion line) and tighten the nut back down.
Jan 13, 2017 | Kulana Cycling
Identify bmx 24 inch bike
This might get you started: http://bmxmuseum.com/bikes/info/187/
Sherri
All In One Computer Repair McHenry IL
Mar 07, 2016 | Cycling
What size bike seat post does Riviera Kulana have?
there are about 20+ seat post sizes out there. Your best option is to take the bike to your local bike shop and have them measure it and provide you with the proper size (about $20-100 depending on quality and materials), a new saddle will run you in the same price range. If you don't have a local bike shop, you can measure the inside diameter of you seat tube using some micrometers, make sure you use a metric one as all bikes are measured in metric denominations. A couple common sizes these days are 26.8 and 27.2 but there are many different sizes and each bike manufacturer will use multiple sizes throughout their line of bikes.
Sep 04, 2014 | Cycling
Need to download owners manual for everlast 5000 exercise bike
I don't have the complete manual, but I do have a PDF of the page that explains how to input info into the computer, if that would help you. What I need is info about the power cord for this bike since I didn't get one when I was given the bike.
Jan 15, 2013 | Exercise & Fitness
I have a Kulana Sun Fire 26 inch bicycle. Someone stole the seat, including the seat post, what parts do I need to buy to replace the seat?
You'll need the seat and seatpost (duh) and possibly the hardware to secure the post to the frame. Since there are a lot of different seat post sizes out there, your best bet is to take the bike to a bike shop who can size out the frame for the right post and help out with the parts you'll need.
Jun 12, 2011 | Cycling
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
