Question about La Crosse Technology Lacrosse Technology WS-8117U-IT-C Atomic Digital Clock with Wireless Temperature with Cherry Side Panels
How do I get a new outside temperature sensor?
    Top Expert:
  • La Crosse Te... Master
  • 34,217 Answers
You may have to order a replacement sensor directly from La Crosse.
Posted on Apr 29, 2015
My sensor isn't sending signals to main unit for outside temperature .This unit is brand new and has new batteries
  • Remove all batteries from both units
  • Install batteries in sender. Allow time for sender to initialize and begin sending signal
  • Install batteries in receiver. You should see outside temperature displayed
Dec 29, 2016 | Measuring Tools & Sensors
Where is the ambient temperature sensor located ?
images for 2008 Chevrolet HHR LT Where is the .
Outside Temperature Sensor - Chevy HHR Network
www.chevyhhr.net/forums/...hhr-4/outside-temperature-sensor-30594/
Jul 9, 2010 - I had the outside temp sensor go on my 99 Buick. I don't know where it islocated on the HHR, but it was just a plug in sensor. Take out the old, stick in the new.... 2008 HHR LS 2.2 L Auto Built: 12-19-2007. Bought: 4-26-2009 Location of the ambient engine temperature sensor.... Help ...
Mar 26, 2013
Engine Temperature Sensor
Oct 6, 2011
Outside Temp Display
Dec 19, 2008
Outside air temperature problem
Oct 30, 2007
More results from www.chevyhhr.net
Jan 25, 2016 | 2008 Chevrolet Chevrolet HHR LT
Why is there a red blinking light on outside sensor? This is only 2 weeks old and new batteries were put in then.
The red blinking light, I believe is indicating the outside sensor is transmitting the outside temperature data to main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
I have a 2005 Dodge Ram 1500 with a outside temperature sensor not working. It's always reading 54 degrees C. I have tried a new sensor and that's not the problem. Any other suggestions?
Mine was the small circuit board in the overhead console. Got one from a junk yard and swapped it out with no problems. Just make sure the plastic is warm, as when cold they break real easy.
Nov 27, 2012 | 2005 Dodge Ram 1500
Outside temperature reading -40 and outside temperature sensor has been replaced
had the same problem, it needs time to calibrate, you have to drive it over 19 miles per hour for at least 10 minutes or so and it should reset itself. I would just take it on a drive if you haven't done so yet.
May 30, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
Ext. temperature gage doesn't work on mercury montego?
Okay, the first thing is this may just be a bad sensor, the sensor is located on the front of the truck behind bumper area,Make sure the sensor is not unplugged or is touching the condenser or radiator. the sensor should be mounted so that it is not touching anything, the tip of the sensor is what reads the outside temp,
If the sensor is mount correctly and is plugged in then replace the sensor with a new one and that will solve the problem. good day.
May 06, 2012 | 2005 Mercury Montego
Our new model #00592W1 includes a low temperature adaptor that plugs into the wireless sensor. Is it necessary to use this?
I found this on another Acu-Rite manual: In case temperatures fall below -4F, bring the wireless sensor indoors and use the included low temperature adaptor by routing the wire out through a soft seal opening such as a window or door. (That way the Wireless sensor is protected indoors in extreme temperatures. Low temp adaptor is used outside to observe temperature.)
Dec 12, 2009 | Acu-Rite Audio Players & Recorders
Outside temperature display (next to a/c display?)
The ambient air temperature sensor at the fron of the car has gone bad, a new one can be obtained from any GM dealer.
Aug 03, 2009 | 1992 Oldsmobile Cutlass Supreme
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Apr 24, 2009 | Lands Phones
Out side temperature reading
Without having parts to try, this would be difficult to know what the fault is. Inside this unit there is a circuit board, and on the outside there is the exernal temperature sensor.
There are only a few things that can go wrong. There is not much that is servicable unless you can find a spare board, or a spare temperture probe. There is very little posiblity that in any practicality this unit can be serviced at the component level.
I would just go out and buy a new unit.
Jerry G.
Apr 21, 2008 | SkyScan 86742 Digital Atomic Wall Clock
La Crosse Technology Lacrosse Technology WS-8117U-IT-C Atomic Digital Clock with Wireless Temperature with Cherry Side Panels Logo
366 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
Tom Chichester
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
