Question about Food Mixers
Cant get the bowl off - Food Mixers
  • Food Mixers Master
  • 1,259 Answers
We are still stuck unable to help without brand and model.
Posted on Apr 30, 2015
I cant locate a manual. I do not know how to remove the bowl.The Berkel BX20t Mixer
Hello Angela, can you please construct a new query and post again. please include details of the make and model of the mixer, that way we can search
Jul 18, 2015 | Food Mixers
How do you attach bowls to mixer
The bowl sits on a round plate. If the bowl cannot sit properly, moce the round base a notch on the right to give more bowl space.
Nov 27, 2013 | Kenwood Food Mixers
When raised to do whipping my professional 550 hd mixer attachment does not scrap the bowl to mix properly
You can adjust the mixer bowl up and down slightly. If you lower your bowl and look at the back you will see a little screw, it looks like a flat head screw and it is on the "neck" of the mixer.
You can raise and lower the bowl by adjusting this cam screw. You can tell that your bowl is adjust correctly by attaching the flat beater and put a dime in the bottom of the bowl, the beater should just barely touch the dime and move it around the bottom of the bowl.
The beater will not scrape the sides of the bowl, if you are wanting the sides of the bowl scraped I would recommend the Flex Edge Beater made by KitchenAid which is basically a flat beater with a rubberized edge which will scrape the side of the bowl as it rotates.
Here is a link to the flex edge beater on our website: http://www.mendingshed.com/kfe6l.html
Let me know if you have any other questions.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
Kitchenaid mixer glass bowl broke. I need a replacement. I have a 4c mixer. Do you know where I can find one?
The glass bowl for the 4c mixer is much different than the bowls that are currently available. Your best option is going to be to find a used bowl off of eBay.
Your other option would be to replace the bowl lock plate and buy a new bowl for the mixer. I have had a few customers say this works, and I have had a couple say that replacing the bowl lock plate and bowl did not work. So you can give this a try as well.
Mar 28, 2013 | KitchenAid Food Mixers
Bowl is stuck in stand - can't get it out. It won't turn clockwise or counter clockwise.
I know they have to turn COUNTER CLOCKWISE to come off the base. Sounds like "magilla the gorilla" put it on the base. Just keep at it. You might try putting some ICE in the bowl to "shrink" the bowl.
Dec 31, 2010 | KitchenAid K45SS Classic Stand Mixer
Why does my sunbean mixmaster bowl don't spin?
the spinning plate under the bowl does not have any power to spin the bowl; it only aks as a "lazy susan" carousel that allows the bowl to turn from the movement of the material being wipped in the bowl.
the beaters are purposely off-center of the bowl in ordwer to create a dragging motion of the material in the bowl, thus pulling (that is, spinning) the bowl slowly. If the beaters are not off to the side of the bowl, you will not get the pulling/spinning motion. Also, if the plate under the bowl does not move very easily, then the bowl will not spin. You may have to remove the spin plate and clean the center pivot for the plate to move freely. Good Luck, Macgivor.
Nov 27, 2010 | Sunbeam 2346 Heritage MixMaster Series...
My h 600 will only run when i hold the start button as soon as i let go it stops
If it has a bowl guard on it then the problem could be either the bowl height switch or the side switch on the contactor. If it does not have a bowl guard then the side switch on the contactor is the problem. If it has a bowl guard, make sure the bowl lift is operating the bowl height switch. The bowl must be all the way up to operate the bowl height switch.
Jun 09, 2010 | Hobart H600 Stand Mixer
Cant raise and lower mixer bowl worm gear and nut is striped how
How could we possibly know what you are capable of doing?
Apr 15, 2010 | Hobart H600 Stand Mixer
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
N50 Hobart mixer is not switching on
Very strong possibility that one of the safety switches has gone bad. I've found, on the last one I worked on, that the safety at the back of the bowl, where the guard hits, when in place, was bad. Drove me crazy trying to find it.
Good luck and hope this helps.
Mar 31, 2009 | Food Mixers
Food Mixers Logo
97 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
