My laptop(gateway nv53a) turns on but why does it only indicate "starting windows"?
Shows the desktop is not showing at all it only restarts again and again
    Sergeant:
  • 206 Answers
Hi
The boot up files have become corrupt
you have to get the windows install disk
to match the windows installed on your
PC/laptop
Boot from disk and when its loaded it will give
you the choice to install or repair
chose repair and follow the promts
reinstall boot up files and then restart
if it still dosnt start
repeat process and this time
reinstall master boot record MBR
and restart
if that dosnt start you will have to
reinstall windows
My laptop(gateway nv53a) turns on but why does it  - 25671898-m35oz4jvdfvvmght4a51n0jl-3-1.jpg or
or
My laptop(gateway nv53a) turns on but why does it - 25671898-m35oz4jvdfvvmght4a51n0jl-3-10.jpguploads/images/25671898-m35oz4jvdfvvmght4a51n0jl-3-10.jpg" alt="25671898-m35oz4jvdfvvmght4a51n0jl-3-10.jpg" class="h_mi" />
cheers
Posted on May 28, 2015
easyq
  • 144 Answers
SOURCE: booting up
Try to start up with the windows XP CD in the drive, it will give you some options to reinstall or repair XP. If this doesnot work, ensure that your BIOS will startup from CD.
Posted on Aug 18, 2008
  • 13 Answers
SOURCE: my windows xp laptop is having problems loading,
The setting for 'Automatically Restarting; in the event of an error is enabled. You can 'disable' this setting (maybe) in order to begin troubleshooting the problem.
How long do you have at the desktop before it reboots?
Can you do this?
power on the laptop
when you get to the desktop
Right mouse button click the 'My Computer' Icon
Choose properties, Advanced, Startup and recovery tab
In System Failure uncheck the box titled 'automatically reboot'
Click 'OK'. The change requires a reboot.
Or
Power on laptop and keep pressing the F8 function key until you get to the Windows XP startup menu. choose 'Safe mode'. boot to desktop and do the above.
these options only allow you to view the dreaded Blue Screen of Death BSOD which may help you understand what condition is casuing the problem. The path to resolving it may be harder and more difficult than simply reinstalling the operating system(software problem) or it may point to a hardware failure which sucks.
Reinstall the O/S using the supplied os disks from DELL. Install the 'new' O/S to a folder like Windows2, this is called a parallel install and allows you to login to the laptop and access all the data files stored there that you never backed up.
Posted on Oct 13, 2009
  • 478 Answers
SOURCE: I reformat my gateway netbook from xp to windows 7
Ok I will give you the simple way to correct this problem Goto start you will see (start search) on the bottom of the screen type in MSCONFIG hit enter this will bring up the config window find the boot tab open the tab you will see 2 lines one with xp the other windows 7 delete the line for windows xp and there you go
Posted on Dec 09, 2009
P Lipponen
  • 379 Answers
SOURCE: I need to do a System Restore on a Gateway 7322 Laptop
try running this virus FREE prog No cost- removes too...: http://www.f-secure.com/en_EMEA/security/tools/online-scanner/
Posted on Jun 29, 2010
benwabnick
  • 2404 Answers
SOURCE: laptop randomly shuts down and shows a blue screen saying
Make sure you don't have any unecessary programs loading up into windows when your laptop boots up. The next time the system randomly reboots check to see if the laptop feels a bit warmer then normal. Could be that your air vents are being blocked by dust. That would cause the air not to flow properly. Take a can of air and blow the vents clear so the air can flow properly and that would take care of the problem.
Posted on Jul 05, 2010
Gateway ethernet controller driver
Use a USB flash drive on the computer you can access the internet on and save the driver files onto it. Then transfer them to your Gateway NV53A laptop.
How to Save Files to USB Flash Drive
Jun 28, 2014 | Computers & Internet
  1. Plug a USB key into a computer you can access the internet with
  2. Get updated drivers from manufacturers site
  3. When prompted to save download choose the USB drive letter which you should see in My Computer/Computer on your 'desktop' screen.
  4. Save file(s) and them remove the USB key when safe to do so.
  5. Insert USB key into your Gateway NV53A and either run driver installer directly from USB key or copy files onto your Gateway.
How to Save Files Using Thumb Drive eHow
Black screen flash bios
You don't need to access the BIOS to format your laptop. Put the Windows disk in the optical drive and then select format when you reach the correct prompt.
May 06, 2013 | Gateway Computers & Internet
Delete hardrive on a gateway nv53a
To delete a harddrive you would go into BIOS Setup, and remove.
(Main menu, or Standard BIOS options (setup)
Was there a previous harddrive, you installed a new one, and the old is still showing up, or what is going on?
http://support.gateway.com/s/notebook/2010/gateway/nv/nv53A/NV53Asp2.shtml
My intel indicates press F2 to enter BIOS Setup.
The best method I've found is;
AS SOON AS you press the Power On button, start tapping on the F2 key.
You may hear beeps as you do.
Those are Stuck key Error Code beeps, and it is you that is doing it.
Ignore them.
If you do not know how to navigate in BIOS Setup, or save changes; post back in a Comment.
Totally way off? Post back in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Acer Gateway NV53A36u
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Black screen
I had the same problem. Leave your laptop on the charger until the light turn blue. Then turn it on to see if it woks. Other is to switch your roms around.
Aug 15, 2012 | Gateway NV5378u Notebook
How can i restet my gateway laptop back to the factory settings? ml6714 with windows vista.
Hi and welcome to FixYa!
To factory restore your gateway;
Shut down the computer,
Restart it,
As soon as you press the power button to start it,
Immediately start tapping the F10 key,
This will bring up an options menu,
choose repair your computer
choose system recovery,
It will do all the work from there.
Also, depending on your Gateway, you may have to use ALT F8
Another way to do this is
Click Start on your desktop.
All programs;
Gateway;
Gateway recovery management;
Click Restore;
A pop up will appear,
click yes and then start.
If you have your computer on password, it will prompt you to enter it.
When the computer restarts;
Click next two times when the Restore from factory default appears
Click OK
Click OK again in the box that appears and wait for the computer to restart.
This may take some time, but another box will appear it will say 'set up windows'
Click next (license and agreement will come up)
click next again
Enter user name (and pic if you want and wallpaper)
Click next
Click use recommended settings
Set your date and time
Select location in the next screen
click start to finish it.
Let the computer finish the rest for you and you are set!
If my solution helped you, please rate it! You do not have to be the original poster that asked the question, it only takes a second and doesn't cost anything! All opinions and ratings are welcomed!
KittyTech
Mar 28, 2011 | Gateway Televison & Video
I have a gateway laptop and when I start it up, it will show the windows start up screen and then the screen goes black. How do I fix this?
Something to try:
Power Off computer. Turn it back ON then when you see gateway logo start tapping on the F8 key and it will take you to Windows Advanced Options. Select safemode and press enter. If it ask you to select a Operating System just press enter. You will see white text. Once you get to the icons on your desktop It will state that it is running in safemode click on yes, then go to
Start Menu then All programs then Accessories then System tools then System Restore. Select to restore to an earlier date then in the calendar select a bolded date at least a week ago. Follow the prompts and your system will restart. This does not hurt to try. Hope that helps.
Oct 26, 2010 | Computers & Internet
Last night,when I was uploading via bluetooth through my cellphone,the notebook froze and I just turned it off.After a few hours I turned it on and the windows was kinda reading the program,but when it was...
The problem is due to file error when you abruptly shut down the Notebook.
Start the PC by pressing F8 upon boot up.
Select "Last known good configuration that works"
Check if it has solve the problem.
If the problem still persists, try system restore under system tools.
Feb 08, 2010 | Gateway LT2001u Netbook
Gateway 450ROG Laptop was downloading a video when the screen slowly went all white. I had to power off. I waited a while reloaded the battery and powered up. I got the windows didn't power down right....
You must go through the safe mode and uninstall your graphics driver and install another one, may be you will find more compatible driver with your graphics card and your windows copy on gateway website.
Jan 31, 2010 | Gateway 450ROG Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
