Question about Epson Office Equipment & Supplies
Epson Perfection V300 trying to scan and create a PDF document. Get message that Ver 2.7 or greater required.
What is causing me to get that message?
  • Epson Master
  • 3,957 Answers
Download updates from here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=113127&infoType=Downloads
Posted on Apr 30, 2015
Epson v300
Make sure you have Adobe acrobat or similar installed so that you have PDF available on the PC. It may also be in the software for the Epson. I had a scanner a few years ago whose software excluded PDF and I ended up installing new software of a generic printer / scanner to use Adobe PDF
Jun 07, 2012 | Epson Perfection V300 Film Flatbed Scanner
How to stop epson v300 noise when scanning
clean it and check for striped gears unplug first might have plastic shavings in bottom if gears are striped
Apr 01, 2012 | Epson Perfection V300 Film Flatbed Scanner
Problem scanning film with EPSON V300
check if upper cover remove for film scanning, bulb must be visible upon scanning in negative or positive film.
Feb 04, 2010 | Epson Perfection V300 Film Flatbed Scanner
I'm having trouble scanning B&W documents with my Epson V300. The edges of the letters in the text are jagged and hard to read and there is what appears to be a crease or fold in the document when the...
You have two options for scanning text. You may explore both of them and see which is better for you. Either way, you will have to make friends with manually changing the scanning settings, because simple presets often are not suited for every case.
First is to use Grayscale mode, and a minimum resolution of 200dpi. This should give you satisfactory text quality. If you want to print the text afterwards, 300dpi would be even better. You may want to increase contrast, to get the letters more defined and eliminate most of the background toning.
Second is to use Black and White (monochrome) mode, but in this case you need to set the resolution higher, preferrably to 600dpi. Also in this case you will have to play with the Black/White threshold in order to eliminate background "dirt" appearing as black artefacts.
If you scan the documents in order to process them with OCR software, usually the OCR application will give you suggestions on how to set the scanning parameters to obtain good results.
Jan 24, 2010 | Epson Perfection V300 Film Flatbed Scanner
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
Just installed the Epson V300 scanner but when I switch on the scanner I get a message that it is not communicating with the computer. The hardware is shown in my device manager list.
First check Epson site for latest driver for your operating system. Try turning on scanner before the computer is turned on. It could be old driver on USB chipset from Intel needs update. A normal problem I have encountered in the past with Epson Scanners
Nov 08, 2009 | Epson Perfection V300 Film Flatbed Scanner
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
I require instructions for using an Epson 1250 scanner
Hi
please check this link for scanner instruction
http://ftp.epson.com/pdf/pr125_/pr125_pg.pdf
or
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/PERFECTION%201250%20SERIES-_E
you can scan any document in very easy way by the MS PAINT.
just type MSPAINT in RUN command then go to FILE menu then FROM SCANNER OR CAMERA
Thanks
Veeru _india
May 08, 2009 | Epson Perfection 1250 Flatbed Scanner
By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
May 03, 2009 | Epson Perfection V500 Flatbed Scanner
Epson 4490 Photo - multiple PDF pages
Hi. Yours probably scans as soon as you have a document in and you double-click, right? I went through this. Double click on the Epson Icon. Make sure the mode preference at upper right is changed to professional. It may start scanning and you have to wait until it's finished to scan again. When you start in professional mode, it brings up a rectangular menu--you probably didn't see this one before (I didn't before changing to professional mode). Now press scan. This gives you a "file save" choice. Chose the location you want. Under the location choice is the Choose Document type option--this is the second key--save as PDF. Now it will bring up that add a page, edit or save file. Professional mode, save as PDF.
Dec 15, 2007 | Epson Perfection 4490 Film / Flatbed...
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
