Question about Home
When taking a shower the shower cuts out, no water comes out of the shower head, also the lights on the shower unit go out but the pull cord light stops on.
The shower is 18 months old Type (Mira Go) Thanks
brainyass
  • 242 Answers
SOURCE: Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
Posted on Oct 23, 2008
  • 659 Answers
SOURCE: The on, off switch on my electric mira sport
You need to replace or have a certified tech replace the switch.
Posted on Mar 21, 2009
  • 127 Answers
SOURCE: WATER DELIVERED FROM SHOWER HEAD NOT HOT ENOUGH
I think some shower valves have a safety setting to prevent burning. maybe you could adjust that to be hotter.
Posted on Jun 23, 2009
  • 150 Answers
SOURCE: I HAVE A JADE 11 ELECTRIC SHOWER WITH A PULL CORD
Renew the pull cord switch
Posted on Apr 10, 2010
bloues
  • 56 Answers
SOURCE: I have a Mira Sport shower 12 mounths old. Water
if the water is leaking out the head, unscrew the head and put thread tape on arm of shower were the male thread is and make it tight again, if the arm ... unscrew the arm and put thread tape on the male thread of the arm and screw into feamale thred that is an the wall. if not 1 of those are the problem , clarifi and all give u a solusion
Posted on Jul 08, 2010
My Triton Millenium shower just stopped working mid shower. Power lights went off. Have checked fuse, power ok but will not switch back on. Any ideas.
there is a cut out unit on top of the element *** unit which is to prevent damage to elements if the water supply fails but i have 3 of these fail down to use have checked the triton spares and the only show it with the element unit cost over £100 you can bi pass it with out any problems just make sure always turned off at pull cord when not in use or phone to see if you can just buy the cut out if you cant its shame on them good luck spares number 08449800745
Jan 10, 2011 | Home
Pull cord light went off and shower stopped in mid flow. children stand in shower fo over 10 minutes, did they burn it out?
Are you in a house that uses a well system for water? It would need power to make water pressure.
Check the circuit breakers in your electric panel. If any of them is tripped off, reset it and see if the pull-cord light comes back on.
Nov 10, 2010 | Home
No running water from my shower
Check water lines to shower and make sure that there is no blockage or water cut off to it. Valve itself could be bad also or blockage inside it.
I f it is a tub & shower unit the diverter may be bad or stuck in place restricting water flow. Some are push button on the valve or a pull unit on tub spout to send water to shower head.
Cut water off and remove to inspect for reason not functioning correctly.
Remove shower head to inspect for blockage. The srceen may be stopped up for the shower head. Remove turn water on and see if any flow comes out shower arm.
May 19, 2010 | Home
Shower was working now its not only had it a few months no water coming out no light on but pull cord light is on
Check the electrical output from the pull cord switch to the shower. Both live & neutral
Mar 31, 2010 | Home
When I turn the faucet to hot ,water comes out of the shower without pulling the shower pullup
either to much water pressure to unit or pull up is clogging /damaged if u have separate valves on water supply start at half way and work ur way open or close till water doesnt come out of shower head
Feb 15, 2010 | Moen Posi-Temp Single HandleTub And Shower...
I need the manual for a Rinnai Infinity 26 hot water system
you can get it off the rinnai web site they have a spot on there to get the internet manuel,, but from what you are saying you may need to adjust the thermostat, or the temp, remember even though you will have endless hot water it still takes the smae amount of timed for the hot water to get to your faucet,, not only that make sure your shower heads aren't holding back to much water pressure, if you don't have enough water going thru the unit it will not stay lit, if will come on and go off, judt to dstisfy the unit,, make sure the filter is clear, on the cold side there is a cap screw if you take it off there is a screen in side you just pull it out and clean it and reinstal it,,
Jun 25, 2009 | Rinnai Digital Remote Water Heater Control...
No water coming out of shower
First you should check the screens st the ends of the hose to be sure they are not clogged. The shower head as well. Otherwise it could be the water control valve, solenoid or thermal cut off.
http://www.theshowerdoctor.com/shower-spares/gainsborough/energy-2000x.html
Mar 02, 2009 | Home
Oct 08, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
147 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
