Where can I find the telephone receiver for this phone
  • 3,957 Answers
Unable to assist you without some additional information, such as the manufacturer make and model of the unit you are asking about. You can Google search the manufacturer make, model and words telephone receiver for some additional assistance.
Posted on May 01, 2015
Why does keep blingin of message received, and no message received...
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 18, 2014 | Uniden DECT 6.0 Cordless Phone
Blinking Red light
If you've never received a call at all, this first message may just be a welcome message from your telephone company.
Dec 20, 2013 | Uniden DECT 6.0 Cordless Telephone...
Can not phone out or receive phone calls bt say my line is ok, my broad band works ok but not my phone
When did it start?
You haven't mentioned what you hear when you lift the receiver and try to dial out.
Please try this: (A process of elimination.)
- Unplug your modem from the telephone line.
- Plug your telephone directly to the telephone line without going through the line filter.
- It should work OK. If the phone is not defective, you should hear a clear dial tone.
- Now connect your phone through the line filter and try to use it again.
- If it does not work then you need a new line filter for your telephone.
- If it works, then re-connect your modem back to the telephone line like it was before.
If the modem knocks out your phone again, please contact the modem supplier.
May 31, 2011 | Office Equipment & Supplies
If i connect the telephone like to magic jack then how the telephone shall be in loop
dnojhap
When you connect your phone line to your receiver, your telephone will still operate as normal. The receiver will only use the phone line when you order PPV or VOD movies and when the rentals are updated to our system, otherwise the phone line is idle. I hope this helps.
Ray Calo
DISH Network
Feb 28, 2011 | Televison & Video
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
Cannot receive phone calls on a dsl setup
There must be DSL Spliter inbetween telephone line & Wi-fi modem. Please check whether you have connected telephone instrument line with that Spliter or not. According to me, Telephone instrument should connect to telephone line option on DSL Splitter to use same telephone line as internet as well Telephone.
Mar 03, 2010 | Computers & Internet
No dial tone, cannot receive or phone out. Phone
First check to make sure that the phone line is working. Unplug the telephone cord from teh telephone (Do not unplug it from the wall as you will want to make sure the telephone cord is good also) Plug in another phone and see if it works, if it does the problem is the phone, if it doesnt the problem is either the telephone cord, or the wiring in the wall or the jack.
Jun 29, 2009 | Uniden 5.8GHz Dual Cordless Phone
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Receive code
In cases where the telephone line is also used as the fax line, the receive code allows the user to receive a fax upon answering the phone without going to the unit and pressing start. By default, the receive code is *9*. That means that pressing *9* sequentially on the telephone activates an automatic fax response form the unit. It needs no setup, except making sure the telephone line from the wall is connected to the LINE outlet in the unit and the remote telephone is connecte to the EXT outlet.
Be blessed.
Aug 07, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
