How can i set the hands - Computers & Internet
  • 3,957 Answers
Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
Posted on Apr 29, 2015
How to return product KX-TG9333T purchased Premium Store.com. Item is same as already have. Thought it would be an upgrade.
The hand set never worked since I bought it. All other hand sets work as well as the base. I would like you to send "free of charge" a replacement hand set as well as the base for the hand set Hand set which never worked has #OGBXBO61363 UNDER THE BATTERY COVER. wE TRYED REPLACING BATTERIES SWITCHING BASES ETC.
Oct 17, 2011 | Panasonic KX-TG9333T Trio Cordless Phone
Tip
Lock and Track your Stolen Mobile Hand Set Through IMEI Number
Do you know your mobile’s IMEI number? Just press * # 0 6 # in your mobile hand set, IMEI number will be displayed in your mobile hand set.
Keep the IMEI number safely at other place. This IMEI number is unique number for each mobile hand set. In case your mobile hand set will get stolen, you can track or unlock your mobile hand set through IMEI number.
First track your mobile through IMIE number here www.trackimei.com and report theft or loss.
If your mobile hand set got stolen, you need to do following things.
1. Submit FIR for your mobile loss, give details of hand set model, color, IMEI number etc.
2. Ask your service provider to track the mobile phone, your mobile phone will be tracked only if the thief are using your mobile hand set with any sim card. If the thief is keeping your mobile switched off, your service provider can not track the mobile hand set location. You should not expect muck cooperation from service provider or police to locate your phone.
3. If you are unable to find your mobile number, insure that at least your mobile handset is locked. The thief can not use (misuse) your mobile with any sim card. You should ask mobile service provider to lock your mobile through IMEI number.
on Jul 13, 2010 | Cell Phones
When I pull out the crown to the second place, the alarm time does not match the watch set time. How can I correct this?
Imbahe,
Here is the procedure to make the alarm time match the you you have set for the main watch time:
2. ALARM HAND ADJUSTMENT
Hour hand Minute hand
B
ALARM
hour hand ALARM minute hand
B Press repeatedly to set ALARM
hands to the time indicated by the
main time hands.
? Set the ALARM hands to the time the main
time hands indicate.
* The ALARM hands move quickly if
button B is kept pressed.
Then press the crown all the way in when finsihed.
Your watch is caliber 7T62. You may download a complete settings instruction manual for this caliber here:
http://www.seikowatches.com/support/ib/index.html
The instructions you need are on page 3 of the manual. I hope this will fix your problem with the adjustments. If you need more help, please let me know.
Regards, Bill
Sep 16, 2010 | Seiko Coutura SNA341 Wrist Watch
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    How do i set the the 24 hour hand in a rolex 16758
    Yours is the original GMT Master. The GMT Master II allows the GMT hand and the regular hour hand to be set differently but not on your older model. On yours, the regular hour hand the the GMT hand are fixed so that if the triangle on the rotating bezel is at the top, the GMT hand will indicate local time. To indicate time in a 2nd timezone, rotate the bezel to orient the time to the GMT hand. There's a copy of the original instructions posted at: http://www.rolexforums.com/showthread.php?t=45269
    Apr 30, 2010 | Bulova Watch
    I have a Aerospace model watch and am having difficulty in adjusting the digital time to be equal to the minute and hour hand time.
    Its best to change on the hour.Stop your watch so that the second hand is pointing to 12.
    Move the hands to the time i.e 10am then advance the minute hand 5 mins past the hour, then turn it back to 10am, when the time comes push set and your hands are set.
    I think you might have not moved the minute hand forward 5 mins and back.
    You can now set your digital time from your hands setting.
    Oct 22, 2009 | Breitling Aerospace Avantage E7936210/G606...
    I have a dual handset GE 2.4 GHZ telephone set. The main hand set works but the second hand set will not work, it just beeps and shuts off.
    Swap batteries and see if second hand set will work. Can get new battery or a different hand set on eBay.
    Sep 03, 2009 | GE Lands Phones
    Changing the hand time only w/o changing the digital time
    For Casio Waveceptor:
    --- A
    ( ) Button Reference
    --- B
    Set in correct order:
    1) Hand Home Position
    2) Digital Time Set
    1) Hand Home Position:
    Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
    Press B to exit Hand Home Position mode and enter Timekeeping Mode.
    2) Digital Time Set: (hands will self set when done)
    Press and hold B for 5 seconds to enter setting mode.
    Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
    <Order of Items to Set>
    GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
    <Setting each Item>
    GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
    Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
    Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
    For each item, Press A to advance, and B to set.
    Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
    Good luck,
    Techjoel
    May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    "hand" icon flashing
    It's likely your photos are blurry from camera motion, caused by taking a hand-held photo with a slow shutter speed, rather than out of focus.
    The hand icon flashes when you don't have enough light to take a crisp (not blurry) photo without either using a tripod (or a flash). The reason for a flashing hand is you can't "hand-hold" the camera at the current settings - you need to use a tripod. If you are "zoomed in" (on a telephoto setting for your lens) you can sometimes get a crisp hand-held photo if you "zoom out" to a wider angle setting on the lens. (You need a steadier hand to hand-hold a telephoto lens setting than a wide-angle lens setting.)
    You may have changed a setting that sets the ISO (the normal setting would be "auto") and if so, if you change the ISO to a high number, or to auto, this will help you take better photos in low light. Check your camera's user's manual to see how to check/change the ISO.
    When you have more light the icon will stop flashing. If you need to take hand-held photos in low light then you need to use flash, or get a better camera that has better low light capabilities.
    Dec 14, 2008 | Nikon Coolpix 5200 Digital Camera
    Computers & Internet Logo
    41 people viewed this question
    David Payne
    David Payne
