Question about Cub Cadet Garden
How do I can the oil filter on my 1999 cub cadet model # 1440, also what filter #, what type of oil does it take and how many quarts are required?
Sent to email rgorman16@hotmail.com Thank You, Rick
  • 3,960 Answers
Please download the manual from here: http://ccmanuals.info/pdf/1440%20&%201641%20Owners%20Manual.pdf
The information you require is contained in the manual.
Posted on Apr 30, 2015
  • 97 Answers
SOURCE: oil light blinking
Screw a test gage in the engine where the electric sending unit is. Check to see what the pressure is cold and after it is warmed up. It may be a bad sender.
Posted on Mar 17, 2009
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
  • 202 Answers
SOURCE: how do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Posted on Jul 08, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
I need a deck belt diagram for a Cub Cadet model 1440 garden tractor?
Request the belt diagram for model 1440 directly from the manufacturer/distributor.
Apr 20, 2018 | Cub Cadet Garden
Oil change
Take the old one out and get the numbers off of it or take it with you for reference. The amount of oil is probably 3 quarts but that can be looked up on cub cadet site.
Jul 26, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Looking for the sensor schematics for a cub cadet series 1000, LT1050 hydrostatic lawn tractor. anyone help me?
Try looking at the directional lever at the Transmission. The PTO for the deck will shut off when shifting into reverse. You may have to simply disconnect or jumper the reverse switch depending on if it is normally closed or normally open. Try it both ways to see what works. Also check the engine oil level, The low oil level switch will shut the engine down if more than a quart low.
Feb 27, 2018 | Cub Cadet Lawn Mower Deck Drive Belt...
Cub cadet 1440 oil all over engine, in carb, and plugs come out black with oil all over them
Is it coming from the Breather hose? try taking out the air filter and see if that stops it. If air filter is clogged , it will cause Crank Pressure.
Also check oil level if too high it will do this. Sometimes the carb will let gas past and into crankcase filling teh crankcase above 'Full' mark
Sep 25, 2013 | Cub Cadet Street Sign- tractor lawn riding...
What type of oil and how much do you use in the Cub Cadet 1440?
It would take 3 and 1/2 pints of Cub Cadet Engine oil (Recommended):
SAE 30 for temps > 40 degrees Fahrenheit
10W30 for temps 0 - 40 degrees Fahrenheit
5W30 for temps
Sep 27, 2010 | Garden
Transmission oil ? for cub cadet tractor
Mar 23, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
78 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
