Question about Troy Garden
What kind of oil do I need for a troy - ilt 675 series
    Champion:
  • 225 Answers
Do you mean a briggs & stratton 675 series engine? if so it SAE 30 oil
Posted on May 03, 2015
RonInFla
  • 86 Answers
SOURCE: Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Posted on Apr 18, 2010
  • 11 Answers
SOURCE: how do you prime a troy bilt 675 pressure washer
if you dont see a primer bulb then you must start it in choke mode after running out of fuel
Posted on May 31, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Have a Troy ilt with
Hi and welcome to FixYa, I am Kelly,
I doubt it is a head gasket. First check to make sure the oil level is not over-serviced. Then if the oil level is correct and after 10 minutes it is still smoking you will have to remove the breather assy on the side of the head where the valves are and clean the reeds with solvent. (might require a good soaking) The crankcase is over-pressurizing causing oil blow by via the valve stems. Sometimes you will experience up to 4 minutes of oil smoke if you have tipped the mower in any direction other than flat. If that is what caused your oild smoke episode it will clear and there is nothing you need to do other than let the engine run. If it easily repeats the smoking after running for a bit routine you most likely have a sticking crankcase / valve breather reed. Cleaning it usually will correct the excess smoke problem. You should be able to remove the breather without removing the carb for cleaning.
If you have a head gasket failure the engine simply will not start. Since the engine is an overhead valve design it is possible to have a head gasket fail but..... highly unlikely unless someone has done recent maintenance on the valves and disturbed the head gasket. I have not seen a honda head gasket failure that was not induced by someone doing maintenance on a cylinder head. The design of the head even with minimal bolt tightening torque will allow the engine to run just fine and not ruin the head gasket.
Should you require more information I will need your exact engine model number from the crankcase of your engine just aft of the oil fill tube on the base of the crankcase.
Thanks for choosing FixYa,
Kelly
Posted on Dec 29, 2010
  • 87 Answers
SOURCE: Troy built 675 series will
have you checked the quality of the gas? is it old from last season? open the gas cap and smell the gas,does it smell like varnish? If your gas is bad it wont start because it has lost it"s flamability.also you don"t what to use old gas because it can damage your engine by causing your valves to stick or freeze up...If your gas is bad you need to drain your fuel tank and carb and replace it with fresh gas..You might want to go and get some fuel stabalizer at the auto store or wal mart and add it to you fuel can you use to fill you mower. That way your fuel will be good for up to a year when stabalizer is added to your gas..Have you checked for a spark at the spark plug? remove the spark plug from the motor, plug the spark plug back into the plug socket and lay the spark plug aganst the muffler, pull the pull start cord and look at the end of the spark plug for a bright blue spark. You might want to do this in the shade to be able to see it. If you don"t see a spark , i would try a new plug first and see..if still no spark then your ignition coil has gone bad,that is the whole unit from your spark plug wire to the coil..check these items first,,,
Posted on May 26, 2011
  • 6468 Answers
SOURCE: troy bilt lawn mower were spark plugs go in striped and wont tighten
you can get a spark plug thread repair kit at a auto parts store
Posted on Aug 14, 2012
Troy bilt lawn mower were spark plugs go in striped and wont tighten
Aug 12, 2012 | Garden
Troy Bilt 675 Series manual
Try internet search w/full detail like you used in question plus specifics like model number. That worked for me w/my lawnmower manual search.
Jul 09, 2012 | Garden
Need owners maual
Contact Troy Bilt directly and request one.
Jan 09, 2012 | Craftsman Garden
I have a Troy Bilt 2550 psi Power Washer with a Briggs and Stratton 675 Series, 190cc engine. Could you tell me what kind of oil I should use.
Best oil for small engine for most moderate climates is 30wt non-detergent. The pump can use mineral oil (air compressor oil ) sold at most auto stores and lumber outlets.
Jul 02, 2011 | Garden
What kind of oil do you use in a troy-bilt pressure washer Model # 675 190cc 6.75
I would recommend valvolene srraight 30 weight unless you are using in cold,below 30 degrees F. Then I would go to 10W 30 Thank you. I have used valvolene products for over 30 years in all my four cycle equipment and I have never had an oil related problem.
Apr 21, 2011 | Troy-Bilt Garden
What kind of oil do I use in my 675 series engine
4 stroke synthetic is most likely what you'd want to run if it's a new unit to yourself. Otherwise any 4 stroke motor oil is fine, you can find it at any retailer that sells small engine machinery.
Apr 21, 2010 | Briggs & Stratton Gas Pressure Washer...
Apr 17, 2010 | Garden
Troybuilt 675 hp lawn mower doesnt start
self propelled not working on troy built 675 series bought 5/08. The belt is still on.
Jun 17, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
121 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
