Question about Thermador CM302U Electric Double Oven
3 problems: WHEN I TURN THE OVEN OFF, FAN STOPS WORKING SOMETIMES OVEN CONSTANTLY BEEPS. I CAN STOP BEEPING BY OPENING AND CLOSING THE DOOR HARD OR BY TURNING OFF BREAKER WAITING FOR THE OVEN TO COOL.
When oven overheats, oven shuts down. sometimes oven will not respond to engage Lower Oven.
  • Bob W
    Bob W Apr 29, 2015
    Should the fan continue to run to cool the oven after the oven is turned off? If yes, what is the likely issue? When the oven is turned off, the fan stops.
    Top Expert:
  • Thermador Master
  • 10,875 Answers
FIRE DANGER!!! GET RID OF IT!!
Posted on Apr 29, 2015
Our Thermador oven starts to beep when you shut it off and the way we are getting it to stop beeping is to set up a fan in front of the open oven to get it to cool. This stops the beeping after 10 m
Check if the internal ventilation fan is running. It is intended to cool down the oven exterior. Some units made 2004-2007 can overheat during self-cleaning.
Oct 14, 2014 | Thermador C301U Electric Single Oven
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
CAN NOT CONTROL BOTTOM OVEN
I assume yiu had the electronic oven control repaired. Sometimes the touch pad also goes bad. I have had to replace them at the same time. If the oven indicator lights showing the oven being on shows up on the display it could be that the thermal fuse behind the oven has gone out. this in in the common line and will shut down both ovens at the same time but you will get the control panel to respond to the touch pad.
Nov 23, 2013 | Whirlpool RBD305PDS Electric Double Oven
I'm getting a constant beeping sound and a F1
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Aug 10, 2011 | Magic Chef 9112 Gas Double Oven
My oven door is locked closed. Also, it reads F8 and beeps. In order to stop the beeping, the cancel/off button must be hit. When I do that, the fan turns on for about a minute and then stops and goes back...
The control board runs self checks about every 10 seconds to check the oven codition,and what the F8 error code means is it has detected a problem with the control board itself and it needs to be repalced
Gene
Aug 04, 2011 | Jenn-Air JJW8430D Electric Double Oven
Oven shut off - no power- checked circuit breaker no problem. oven came back on thye next day and is working fine. is this an overheat problem -is there a circuit breaker on the oven that resets? what...
This sounds like the thermal overload operated and turned the oven off. The overload is generally located in the top of the oven cavity. Remove the top cover and you should find it. Sometimes it open circuits the active supply and sometimes the neutral. Sounds like it may need replacing.
Feb 15, 2011 | GE Profile JTP18 Electric Single Oven
Hi, I have 90 AJC 06 GC. AEG single oven. At thhe moment when the oven is turned off the cooldown fan will not turn off so I have to turn it of at the main fuse box. Also sometimes the oven turns itself...
The oven cooldown fan will sometimes run for 10 to 15 minutes after turning the oven off. This enables the outer shell of the oven to cool down. Most ovens also have an inbuilt thermal overload in the outer shell. If the temperature in the outer shell gets too hot it will open circuit the oven power until it cools down a bit.
Feb 10, 2011 | AEG Ovens
Oven lights and works fine till it reaches set temp then panel goes blank and oven shuts off
Check the cooling fan inside of your control panel. Most likely the computer board overheats and shuts itself down.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 25, 2011 | GE JGRS14 Gas Single Oven
Open Questions:
See all Thermador CM302U Electric Double Oven Questions
Thermador CM302U Electric Double Oven Logo
145 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
