Question about Samsung Refrigerators
Power went out now back on. Samsung rs261mdwp has 1 blinking light on freezer side. What is this and how to fix?
  • Samsung Master
  • 4,655 Answers
Usually when there is a power failure or surge the PCB printed circuit board can be damaged on old or new refrigerators. It is just one of the problems associated with electronic controlled refrigerators. Your model has a=> DA41-00669A Control Board Unplug and examine to see if there are swollen capacitors or burn marks. You cannot always see damage to the board so if not then return the control board. I'm here if you care to ask questions. Compressor and fans stop? Cooling stops? Let me know by answering my post here, Thanks John T. Appliance 911
Contact
power went out now back on. Samsung rs261mdwp has  - 25671658-uauuxz0y3yudqzl2negau2zd-2-0.jpg
Posted on Apr 30, 2015
We had. n ice storm snow etc. Went thru about 15 times of power outage. The freezer side isnt cooling. Ice maker stopped. I have tried unplugging...plugging back in. Finally got ice maker to turn back on...
you have spent $1395.00 on a machine you hate
most people get rid of it after the first $500.00 bill as new fridges cost around $1000.00 and you get 2 years warranty
smart people with new fangled fridges power them through a quality surge protection device as well
Jan 23, 2018 | Samsung Refrigerators
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
The light on the freezer side keeps blinking but refrigerator side not working flashing
possible the freezer needs a recharge of freon . only a repairman can assist with that .
Sep 06, 2015 | Samsung RS261MDWP Side By Side...
Ice maker set up
it takes a couple hours for ice and not as long for water to chill .
Feb 09, 2015 | Samsung 26 cu. ft. Side by Side...
How do I adjust the temperature to make the refrigerator cold
usually there is a control knob inside the fridge just turn it to colder and see what happens
Feb 03, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
It dosn't cool
try unplugging and back in . or turn breaker off then on
Aug 29, 2014 | Samsung RS261MDWP - 26 cu. ft. Side by...
Fan malfunction in the freezer samsung rs261mdwp
If your questioning is how to replace it its no easy task. It involves removing everything from the freezer and all the shelving. The back inner panel of the freezer compartment and then removing and replacing the fan. Followed by reassembling everything.
Jul 25, 2014 | Samsung 26 cu. ft. Side by Side...
The freezer door wasn't closed properly overnight 2 nights ago and it still didn't cool properly after the whole day yesterday and today. There was a noise which I didn't recognize but now in retrospect...
Is RS261MDWP the correct model number? If you left the freezer door open there is an excess amount of frost covering the evaporators because moisture was drawn inside and has frozen on the evaporator and is too much for a normal defrost to get all of the ice off and drain into the pan below the refrigerator. It may have also frozen over the condensate drain and not allowing the water to drain. You may need to clean the drain hole and defrost the refrigerator manually and insure the evaporators are clear of backed up water. If you don't there is a chance the refrigerator will continue like this until you do. Let me know what the status is so I can help.....Sea Breeze
Does your model have two evaporators?
Aug 05, 2013 | Samsung / RS261MDWP
Samsung refrigerators
if the filter is dirty enough to where it stops the flow of water then yes.a replacement of the filter should fix the problem for you
Aug 19, 2012 | Samsung RS261MDWP - 26 cu. ft. Side by...
Refrigerators Logo
142 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
