I ordered this item and used it once, the second time I used it, it had a real loud noise and the first time is very quiet. How do I return it and get a different one?
  • Washing Mach... Master
  • 932 Answers
Lydia,
You did not specify what type of item you are referring to and you are posting under washing machines. If you are referring to a washer, than you need to contact wherever you ordered it and ask about getting it checked out under warranty. Most washers carry a one year warranty so it should be covered if that is what you are referring to.
Posted on Apr 29, 2015
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
Our phone just started getting a humm loud noise you cant even hear your other party talk?
if you have the manual Check it to see what you have to do to change the channel the phone is using you may need to try several different ones before you get a quiet line. If you don't have the manual do a google search with you Phone brand and model # for owners manual.
Hope this helped
Jan 19, 2015 | Lands Phones
I have a kenmore elite total care flex king size capacity plus quiet pak2 oasis that makes loud noises like a airplane when its in the spin cycle Model #110.28032701 which parts should be change?
If the washer is roaring during spin, the bearings are bad and you will need to replace the outer tub assembly.
Here is the part to order.
The part comes with a 365 day, any part, any reason return.
Nov 03, 2012 | Kenmore Washing Machines
My new GE over the range microwave works fine but has a loud buzzing/humming noise when in use
This sound you describe is not normal and should be checked quickly, even if it means returning the item.
Mar 27, 2012 | GE SpaceMaker Microwave Ovens
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    I just bought a new frigidaire refrigerator. I plugged it in and it began to emit a large loud humming noise. It almost sounds like something is vibrating inside. Is this normal for a branc new fridge?...
    It depends....it may be loud for a hour or so, but should quiet down as it cools...
    There is an explanation for this, but it is very long and would involve intricate details about refrigeration systems...
    If it does not quiet down after a 1/2 day then call the place where you got it and return it...
    heatman101
    May 10, 2011 | Frigidaire Refrigerators
    Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
    No longer "ultra quiet" huh?
    A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
    Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
    Aug 30, 2009 | Frigidaire Dishwashers
    There is this sound like a valve tappet or chain noise on my 98
    they have a problem with the oil pressure relief valve chattering from cold for a few minutes, a simple fix to change for a new modified item with shamfered edges on valve to eliminate noise
    Jul 15, 2009 | 1999 Porsche Boxster
    Question about Vance and Hines quiet baffles
    about 3-5db but you must remember db is not a linear scale but logirythmic. basicallyy the baffles will remove the harsh rasp off the pipe and make them deep in sound, when cold they will be as loud as normal but once they have some heat in them they quieten down
    Nov 20, 2008 | 2003 Harley Davidson XL 883 R Sportster
    RCA Wireless headphone triggers off after 35 seconds of operation
    ya the volume of your source is your issue.
    if it is too low, the unit cuts out after 45 seconds or so...
    crank up the volume and turn it down on your headset
    Mar 16, 2008 | RCA WHP140 Consumer Headphones
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
