Question about Garden
Witch way does connecting rod turn right or left
  • Garden Master
  • 2,478 Answers
Left
Posted on Apr 29, 2015
How do I turn the motor of a nissan pathfinder 1996 I think it'sllocked up it was stolen and came back to me low on oil and with a taping sound in the motor put did not loss compression but now won't turn...
You are probably right on your belief it is locked up.
You should be able to turn the crank by using a wrench on the alternator pulley or the water pump pulley.
Mar 27, 2015 | 1996 Nissan Pathfinder
Can t turn stearing left or right takes all my strength to turn
check out the steering connecting rod. its the rod that goes from left to right front wheels. if it is not completely straight, either bend it straight or buy a new one.
Also, could be your front axle if you dont have the cast iron heavy duty axle.
Jun 24, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When I try to turn on Mm 2000 Dodge Durango there is a really loud knocking noise under the hood.. Do you know what could be the problem?
Hi :) Well it could be that you have blowen a timing chain and the pistons are hitting the valves or a connecting rod has broke and is banging agaist the inside of the block.
Mar 28, 2011 | 2000 Dodge Durango
Witch direction to back caliber off hand brake
If you are talking about caliper pistons on the pads on rear clockwise right side counter clockwise left side if they dont back off or come out may be frozen on theaded rod in caliper. If so replacement is ness
Oct 18, 2010 | Oldsmobile Aurora Cars & Trucks
I installed a 1987 monte carlo steering column in my 30 ford hot rod i need the color code of the wires so i can conect the directional signails up
H).l-blu wire connect to left front turn signal J).dk-blu wire connect to right front turn signals K).brown wire connect to hazard/flasher relay output L).purple wire conect to turn/flasher signal M). yellow wire connect to left rear stop hazard light N). dk-green wire connect to right rear stop/hazard light P) white wire connect to stop light swirch output
Jun 25, 2010 | Cars & Trucks
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HOW TO CONNECT A PYRAMID 10 BAND GRAPHIC EQUALIZER/AMPLIFIER
It has a blue witch and a green witch?
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Feb 27, 2010 | Pyramid 10 BAND EQ 300 W WITH LIGHTS Car...
Loose frontend,little bit road wild
jack the front of your truck up and wigel each wheel.that will twll witch tie rod end is gone.it sound like you have a bad tie rod end.check the left side frist
Nov 12, 2009 | 2001 Ford F250 Super Duty Super Cab
Steering
Look under the front between the wheels at the tie rod that connects the two wheels. It is probably bent up and should be straight. If it's bent, remove it a straighten it.
Jun 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Adjusted gear shifter incorrectly. Cannot locate neutral.
Ok.
Remove the rod altogether and get the lever in the position you want.
Once you're happy with that, pick up the rod and look at it. The threads at each end are the oppsite of each-other. One is right-handed (you turn it clockwise to tighten it up), the other is left-handed.
Take the two small locking nuts and wind them on to the correct ends of the connecting rod. DO NOT force anything if it feels like it doesn't want ot go, as you will cross-thread things and the assembly will be kaput.
Offer the rod up to the connecter at the foot pedal and the shift arm and gently screw in each end at the same time. Make sure that the threads match!! ie left handed thread on the right, and vice-versa. Once happy with the position, tighten up the locking nuts and off you go.
If you get stuck, re-post here and I'll help you further.
Ride safe!! :)
Apr 10, 2009 | 2004 Honda CMX 250 Rebel
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
